FlyPT Mover 3.7.0.21
  1. evgenymcp
    evgenymcp Member
    185Coins
    I would like to express my gratitude to the developer. Today, I tested the Bass shaker in the Mover, and it works. I adjusted it to the engine speed and the road surface.
  2. JCM
    JCM New Member
    125Coins
    Hello @pmvcda
    I know you may have plenty on your plate...I am trying to control a very simple rig on Fly PT using only 3 actuators
    You surely already know it, its a "3 RPS"
    The first joint is revolute -passive
    The second joint is prismatic -active
    The last joint is spherical -passive
    Its very similar to Rotating 3DOF (3RRS) which already exists in FlyPT.
    I was wondering if you had any idea how I could set up this type of rig in your software ?
    Maybe some trigonometric transformation on the Rotating 3DOF rig type could do the trick?
    Any idea for even a quick & dirty solution, this would really help.
    Thank you for your kind help as always,
    Sincerely
  3. pmvcda
    15,848Coins
    I will add it for the next release. It's an easy one i think.
    Meanwhile you could try to add with 3 actuators but i think it's not going to work because you cant limit the motion of the bottom joint.
    But without yaw sway and surge it might work.
    Now you can use two poses on the actuator, one for the rod and one for the housing, use pose just in the rod
  4. JCM
    JCM New Member
    125Coins
    Awesome!!! I will try this hack in the meantime
    Looking forward to your release so I can configure it properly (enter base radius, platform radius, actuators stroke and other parameters)
    Thank you man, you are a legend ! :thumbs
  5. mhsimmer
    mhsimmer New Member
    18Coins
    Thanks for your replies. I am still banging my head against the wall and can't get LFS to link up with Mover.
    I have opened all UDP ports in the firewall and even tried temporarily disabling it; still no luck.
    Thanks for the tip about the patching of LFS I had not done this. I try and it still doesn't work.
    How does Mover know where to patch files? I ask as I had installed LFS more than once and just wondered if a path is wrong somewhere. I also notice that even without LFS installed the patching seems to be allowed even though no LFS files are there, what does patching do and how do I know it has worked?
    Can I ask what version of LFS you are using? I am on 0.7G and mover 3.7.0.21.
    Any help is very welcome. I have my actuator moving with Mover and the noise/loop source so know it works.
    Thanks in advance.
  6. mhsimmer
    mhsimmer New Member
    18Coins
    Also in addition to the message above. I notice in your screenshots when using LFS the Connect/Disconnect button is red. My one is always yellow. What does this mean?
