Misanthrop's spontaneous racing sim project (3DOF+Surge+2xTL)
Discussion in 'DIY Motion Simulator Projects' started by Misanthrop, Feb 13, 2024.
  1. Misanthrop
    Misanthrop Active Member
    988Coins
    I've spent a lot of the last few weeks driving and adjusting Simhub. I'm going to make an explanatory video in German at least in the future, I've already bought some decent material for this. I am always amazed at how well Simhub simply works.
    After a lot of road vehicles I have now worked out the settings for autocross and offroad, this took some time, I will probably make a preset available here in the future.
    At the weekend I added the handbrake and shifter and at the same time re-routed all the cables. I also printed cable clips and holders for all PSUs, so everything is now much tidier. I don't think much of cable channels and boxes, in my case they would only work to a limited extent and wouldn't look any better.
    I have published a few files on Printables. These include holders for Simagic Hub and PSU, as well as E-Stop and an adjustable Vesamount.
    The button box is currently being redesigned because I'm not satisfied with the look. Additionally, I will disassemble and re-grease my actuators this weekend and check for wear or damage in the process, so far I still have no failures since the first assembly, so I am very happy with my design and the chosen parameters when printing.
  2. Misanthrop
    988Coins
    Changed a few things again. The mouse and keyboard now have their place and my “button box” is almost finished and has already taken its place. Buttonbox contains a Streamdeck XL, emergency stop for the Simagic Base and Thanos motion controller and the 3 buttons for the Thanos controller. 20250216_213513.jpg 20250216_213539.jpg 20250216_213830.jpg 20250216_213844.jpg
    Really happy and there will be not many changes or updates in the future. Now it´s time to drive and enjoy.
  3. Misanthrop
    988Coins
    Small Update, maybe for some people interesting which have an Surge Axis but don´t want to build an additional motor driven Belt tensioner.
    The rubber bands will pull on the Belts when the Surge Axis is moving while braking. Works great and the strength can be changed. It was only an sideproject the last 6weeks to get motivation again and i wanted some experience how it is do drive with belttensioner. In my opinion it´s no gamechanger or anything else and don´t know if i will use it a long time
  4. Deleted member 51784
    Have you tried VR? I could only imagine the immersion your rig would provide with it.
  5. Misanthrop
    988Coins
    Tried it and sold it after few weeks again. The best immersion is useless if you can only use the VR glasses to a limited extent due to motion sickness. I often drive long distances or several races in a row, i.e. hours, so triplescreens are much better and more enjoyable. I didn´t like the resolution and performance, in my opinion the biggest immersion killer.
    Also with motion you need a lightweight VR headset, like the Bigscreen Beyond 2, but I don't want to spend so much money only to find out that I still don't like it.
    Many people are arguing that they have the best immersion with VR, especially from people which never tried both. But there is a reason why almost all e-sportler or top split driver are using triplescreen.
  6. Misanthrop
    988Coins
    Something different...after the belttensioner works really good.
    I had a big interest in the new Conspit 300GT Wheel but i don´t want an coiled cable and after watching an Video about Dan Suzuki´s QR System, i got the idea to adapt the VRS USB-passthrough on the Simagic Alpha Ultimate Base. Simagic doesnt want to sell their Slipring and Wheelbase QR with PCB at the moment, so i have to use the VRS one.
    After taking first measurements and some cad designing, it would fit the base really good without any big issues. Only two parts has to be printed and it should be done.
    Why i don´t buy an other base with usb-passthrough? I simply don´t want, because every other base would be an compromise for me.
  7. Mill2077
    Mill2077 New Member
    76Coins
    Those seat belt rollers look great! Is there any chance you could share the stl?
  8. Misanthrop
    988Coins
    Not at the moment, because I am not completely satisfied with the design and have a certain expectation of myself before I publish data on Printables.
    Small Updates of my Rig:
    I finished the Desin of the USB-Passthrough and printed the parts with XPETG, should be fine for the application.
    And yesterday i changed my Surgeaxis from 5mm to 10mm Pitch. There were different Reasons for it. I wasn´t justified completely how the axis reacted and tested many things like 220V, 100V, aggressive settings and washout effect(Simhub). I even took apart the axis, re-greased it, and completely realigned it to make sure the rig wouldn't warp under stress because the ball screw made some noise lately. Since I had been ordering from a cheap Far East online retailer anyway for the USB passthrough project, I also ordered a ball screw with a 10 mm pitch.
    And i was surprised how well this turned out. It´s silent again and can be much more violant if you want it. Additional with the Washout-effect in Simhub it´s finally like i want it.
  9. Misanthrop
    988Coins
    I changed the Design and have published them on Printables: https://www.printables.com/model/1418782-roller-for-belttensioner
    I am working on different Improvements on my Rig at the moment.
    • I designed my own Simagic Compatible PCB´s. So i can use 50/70mm QR´s in combination with USB-Passthrough(no need to buy the more expensive QR-A)
    • Had some Time to improve my Belttensioner Rollers
    • Finished the second Version of my Adjustable Vesamounts, which are now usable with Motionrigs(want to attach my Triplescreen on my Motionrig, instead of an seperate Stand)
    • Designed two Housings for an Iflag, had the parts for it lying around for a long time
    • Gurt Umlenkung oben v4.png Vesa Mount Triplescreen v2.png 20250906_160958.jpg
  10. Misanthrop
    988Coins
    My USB-Passthrough Conversion is finished and works great, additional I designed my own Simagic compatible PCB´s, because I didn´t like the available solutions.
    Converted all my Wheels to NRG-style Quickreleases and all the Wheels have now the same Height(Distance from Wheel to QR)
    Now waiting for the final parts to get my fanatec wheels usb converted. Then also this project is finished.
    After that i will rebuild my Stand for my Triplescreen, need to buy some bolts for it next week.
  11. Misanthrop
    988Coins
    Last update 4months ago, time is flying.
    I had the motivation to change small things of my qr pcb design, now waiting for the pogopins to arrive and to solder them.
    Last weekend i came up with an idea to get the horn working on my round steering wheel. Since i am using an 40mm Spacer to get the same height like my other wheels, i got the idea to design an wheelhub with few buttons, However, the aim was to ensure that this did not detract from the simple look of the steering wheel. Why I decided against many of the available versions.
    It should be simple as possible. No shifter or clutch paddles. As invisible as possible. Should include some Buttons, an Rotaryswitch and an Funkyswitch.
    Tuesday i had to drive 5Hours by train to a customer and started to design an universal hub. Both arms can be turned 25° to fit it at different wheels or just to get the best button position. Two Buttons on top of the Hub, one Rotaryswitch and one funkyswitch. Powered by an Arduino Pro Micro.
    All ordered Parts should arrive the next few days. When i´m satisfied with everything, i will publish this design at Printables.
    Already thinking about an second Version with opensource or buyable shifter paddles and more buttons on top of the arm, but for this i would need more motivation and time.
  12. Misanthrop
    988Coins
    My wheelhub project is almost finished. After i changed the parts for easier assembly i uploaded the files on printables: https://www.printables.com/model/1573108-simanthrop-wheelhub-70mm-qr
    4Buttons and the Horn, Rotary Encoder with push button and an Funky Switch with all his functions(Rotary, 4way, push button).
    And i broke my very first part of my motion system. It sits on top of the rails and because of some changes mechanically and very harsh surge and sway movements, it broke after some time. Funny that i already thought it will be the first part which will break, would design it differently in the future.
    Printed it again in PLA(just to mess with some people which are thinking pla isn't sufficient at all) with different settings and it's already working again several hours.
  13. Misanthrop
    988Coins
    Finally i rebuild my Triplescreen Frame. The Parts were laying around since many months. Decided to have them still static, but much more rigid now. For two years, it had been nothing more than a quickly assembled temporary solution.
    Also i finally found an company with proper aluminum extrusion profiles in my Area. Build an Baseframe with 15x60mm Extrusions and changed some things at my TL system(just improvements i had in mind, not because they were needed). Also i reduced the Stroke of both Actuators to 300mm instead of 380mm(150mm to each side).
    I use the TL System mostly for Sway Effect(30mm Range) which are far better and faster compared to Sway/Roll. TL itself i only use for Dirt Oval.
    And i finally finished my second Flag, to have them on both sides. I will use these for all cars with round wheels for Flags, Spotter, Redline and with GT-Wheels only as Flags.
    More and more i get rid of every "temporary" solution to get it to a point with an overall nice finish. It will never be an beautiful Rig, but i want to have it to a point, where it´s easy to work on it and nothing annoys me or is more complicated as it should be. Especially because i will move in another apartment next year again.
    And so that I don't get bored, I've started to realize an idea that I've had for a long time. Since I wasn't convinced by the Active Pedals, whether DIY, Simucube, or Moza, I've now started to design semi-active pedals. I like the feel of SRP pedals, especially on the brakes, but unfortunately I find the price unreasonably high. My goal was to create pneumatic pedals that can be used both offline and online and, when used online, have all the advantages of active pedals without the disadvantages.
    I will print the parts the next few days(only 4). Pedal, Pedalplate, Loadcell will be used from my P2000 Pedals. Everything else will arrive in March.
  14. vistol5100
    vistol5100 New Member
    392Coins
    It looks spectacular! The only downsides are the footprint it takes up and the noise it makes. Since I live in an apartment, I can already imagine the neighbors complaining. But other than that, it looks amazing, and the immersion must feel incredible
  15. Misanthrop
    988Coins
    The Footprint is only 2m², it´s not much more compared to usual Simrigs, since my Rig is much narrower compared to other Rigs and the noise got much less since i use 10mm Pitch for Surge.
    You don´t hear the vertical actuators with headphones, it sounds much worse when you film it.
  16. Misanthrop
    988Coins
    I designed and build an super cheap Belttensioner. The Idea and Software is from Marvin and mairapp.com.
    All Files are available on Printables. Its working with two 150kg rc-servos and an Arduino Nano.
    Working on an second version already with an build in PSU since the table psu stopped working after some time racing(Don´t know if only mine was faulty or it will be an general problem).
    My semi active pedals are still in progress, after i tried to assembly the first few parts i realized that the BOM list and documentation of the diy active pedals is wrong and outdated....so changed my design and had to print new files. It will sit on my shelf till i get new motivation.
  17. Jon Amico
    Jon Amico Member Gold Contributor
    521Coins
    Thanks for posting the Seat belt Tensioner info and Link.. mairapp.com Awesome Stuff!! Been waiting for someone to post a DIY Thread!!!
    And very rad Build!! Thanks for posting!
    Love it!
