Project - 6DOF/Hexapod rotating actuators - New rig
Discussion in 'DIY Motion Simulator Projects' started by Sim2000net, Mar 11, 2026.
  1. Sim2000net
    Sim2000net New Member
    40Coins
    3DOF, Arduino, 6DOF
    Hello everyone,
    I am pleased to share with you my new project. I have built and setup a new 6DOF Hexapod rig with rotating actuators controlled by an Arduino R3 Uno card through FlyPT Mover.
    Some adjustments are still needed....
  2. Sim2000net
    40Coins
    3DOF, Arduino, 6DOF
    The rig is driven by 6 86HB250 motors coupled to 20:1 planetary reducers and driven by HBS86H Hybrid Servo Drives
  3. Sim2000net
    40Coins
    3DOF, Arduino, 6DOF
    Some more photos
    20260310_215153.jpg 1000028690.jpg 20260310_215153.jpg 1000028690.jpg 20260310_215133.jpg 20260310_215153.jpg 1000028690.jpg 20260310_215133.jpg
  4. 毛大大
    毛大大 New Member
    36Coins
    How much does it cost?
  5. Sim2000net
    40Coins
    3DOF, Arduino, 6DOF
    I bought all the parts separately and have not yet calculated the total amount. I will do it once it is finalized.
    The seat however can be bought on the internet on sites such as Amazon (cost ~$700). There are cheaper alternatives for sure but that one fits better :)
  6. boy
    boy New Member
    97Coins
    Hello, this is a great project. Do you plan to open-source it?
  7. Sim2000net
    40Coins
    3DOF, Arduino, 6DOF
    Sure. Yes I will open source it. In the meantime, let me know how I can help.
    Fist thing first, you need 4080T aluminum profile for the base:
    3 pieces 400 mm long
    3 pieces 750 mm long
    I will try to make a sketch for you if you need it.
    Cheers
  8. boy
    boy New Member
    97Coins
    Thank you so much, I would be very grateful if you could. Is there anyone who wants to work on this project with you?
  9. boy
    boy New Member
    97Coins
    Is its chassis too light, causing it to bounce during movement?
  10. vistol5100
    vistol5100 New Member
    151Coins
    Still, 700 dollars is a good investment to get a motion system; it's much cheaper than the most affordable system on the market
