Question Qubic System QS-H13 Seatmover
Discussion in 'Commercial Simulators and Peripherie' started by Sky_Rock, Mar 6, 2026.
  1. noorbeast
    154,762Coins
    +11,196 / 57 / -2
    I expect it would be possible, depending on what T slot frame is chosen and that it is deep enough for the Qubic motion system to be mounted without protruding below.
  2. Sky_Rock
    Sky_Rock Member
    184Coins
    Which profile would you recommend, in this case ?
    It doesen't matter if it's expensiver.
    Thanks a million for your help
    154,762Coins
    +11,196 / 57 / -2
    My suggestion would be to make direct contact with Qubic and verify mounted clearances when using their mounting bracket for the unit, which is listed as being 23.09cm total height, while also clarifying what aluminum profile is in the website pictures.
    From the pictures given the mounting brackets are just right angles bolting to the side it would not be hard to fabricate those for any desired height on a T slot framed rig.
    I am not sure why you would want to have an aluminum frame directly on a floor, without either a rubber mat or adjustable feet to prevent damage.
  4. Sky_Rock
    Sky_Rock Member
    184Coins
    I didn't say, I want to have an aluminum frame directly on a floor
    I already have a rubber mat ( PC chair with bass shaker and Buttkicker )
  5. Sky_Rock
    Sky_Rock Member
    184Coins
    Is it allowed to copy paste here something, what a guy from Qubic wrote ( e-mail )?
    Thank you.
    154,762Coins
    +11,196 / 57 / -2
    You could convey advice you have been given but not paste an actual email that has things like names and email addresses, as the latter attract spammers.
  7. Sky_Rock
    Sky_Rock Member
    184Coins
    Not names, email address....
    Only what the guy wrote
  8. Sky_Rock
    Sky_Rock Member
    184Coins
    Okay, the guy wrote
    Let me answer your questions directly.
    Would removing the wheel and pedal frames affect the QS-H13 stability - no. Not at all. The H13 sits on the aluminum profile base underneath it, and that is what keeps everything rigid. The front cockpit section (wheel mount, pedal tray, monitor arm) is a completely separate structure that does not connect to the H13 in any way.
    Can you keep the wheelbase on the desk and pedals under the desk - yes. This is actually how seat movers are designed to work. Your body moves with the seat while the controls stay fixed. That relative movement between you and the wheel is what creates the sense of G-forces.
    One practical thing worth knowing since you also use your PC for Photoshop, video editing and other work: the QS-H13 does not have electronic brakes. It holds its seated position using the motors themselves, which means it needs to stay powered on while you are sitting in it - even when you are not racing. If you turn off the power, the seat will slowly settle under your body weight. The good news is that the power draw for just holding position is negligible, well under 1 EUR per month. But it does mean the H13 and QubicManager need to be running whenever you are using the seat, whether for sim racing or just working at your desk.
    Should you buy the P1X Pro for this - honestly, I would not. You would be paying for a full-size cockpit and only using the rear seat section. What you actually need is much simpler - a compact base frame made from a few pieces of 40x40 or 40x80 mm aluminum profile, roughly the footprint of the seat, holding the QS-H13 and the seat on top. That is it. The image you labeled "My ideal setup" is close to this concept - take away the front wheel and pedal section and what remains is essentially the base you need.
    Which profile to choose - this is the part that is hard to solve over email. The exact frame dimensions depend on the seat you pick (mounting pattern, width, weight), the sitting height you want relative to your 70 cm desk, and whether you plan to mount the QS-BT1 right away or add it later. Getting these wrong means rebuilding, and that is exactly the kind of frustration you want to avoid "
  9. Misanthrop
    Misanthrop Active Member
    970Coins
    You will end up pushing around your wheel and pedals when they are not connected to your seat.
  10. Sky_Rock
    Sky_Rock Member
    184Coins
    What do you mean ?
  11. Sky_Rock
    Sky_Rock Member
    184Coins
    Another guy, with knowledge, adviced me
    " I would not recommend separating Wheelstand from Seatframe due to stability issues. You are risking that the seat frame moves backwards when hitting the brakes and using H13. This is why I keep on suggesting to buy a rig with Wheelstand and Seatframe. But at the end it is your decision.
    If you want something narrower than the suggested FGT Elite, take the Next Level Racing GT Elite Racing Simulator Cockpit - Wheel Plate Edition and you are close to your images "
    That's why I'm confused. Both have knowledge.
  12. Misanthrop
    970Coins
    Your seat and wheelbase should be directly connected with each other.
  13. Sky_Rock
    Sky_Rock Member
    184Coins
    This attached image called WORKSTATION SIM RIG_ Have a look, please.
    If I could bring it close to my desk, with those two marked frames and the wheelmount frame should be about on the same level with my 70 cm high desk, I mean, so I can reach everything I have on the desk, without problems.
    If I can do this, everything will be perfect.
    What do you think, guys ?
  14. Misanthrop
    970Coins
    This will only work without an seatmover
  15. Sky_Rock
    Sky_Rock Member
    184Coins
    Why would a seat mover be an issue?
    Thank you.
  16. noorbeast
    154,762Coins
    +11,196 / 57 / -2
    My compact rig has been kicking around and located in many places for over a decade, here it is in my old office setup, which I think is somewhat similar to what you have in mind, though I mounted the wheel, wind simulation fans and keyboard tray on an articulated arm to the desk itself with audio controls underneath:
  17. Sky_Rock
    Sky_Rock Member
    184Coins
    Thank you
    Yes, something like this.
    Is it a motion platform?!
  18. noorbeast
    154,762Coins
    +11,196 / 57 / -2
  19. Sky_Rock
    Sky_Rock Member
    184Coins
    Wow. Thank you so much.
    You said, it's not going to work ( as I want it, close to the desk) but your first 2 dof seems to be. The wheelbase is on the desk.
    I'll have to read again, carefully, the entire thread you opened.
    And I'm a bit confused about your seat.
    No Qubic BT1 belt tensioner?
    154,762Coins
    +11,196 / 57 / -2
    I did not say it could not work, I think you are referring to this earlier post:
    My rig was initially built in 2014 and has been configured a number of different ways and places in its life, with another one pending once I build the new garage as its new home.
