Question Qubic System QS-H13 Seatmover
Discussion in 'Commercial Simulators and Peripherie' started by Sky_Rock, Mar 6, 2026.
  1. Sky_Rock
    Sky_Rock New Member
    58Coins
    Hello everyone,
    I want to purchase the QUBIC System QS-H13 Seatmover, I've never used a seat mover or a motion rig, before.
    I want to ask you some questions about. Would it be possible to mount that way, so I can keep my wheelbase + wheel, pedals, joystick and HOTAS, as they are now ?
    I want to keep my desk, I have a lot of stuff there.It's a very heavy and great quality wooden desk.
    70 cm height, 150 cm wide and 75 cm deepth.
    What I want to ask : which kind of seat / frame would you recommend ?
    As an example, I attached here an image. I'd like to have it similar with this, but I don't care about the frame for pedals, joystick , wheel, etc.
    Only the seat, standing on the QUBIC System QS-H13 and in the front, just no frame for wheel, yoke, joystick, pedals, etc. So, as small as possible.
    Please help me with some advices. Thank you so much, in advance.
    154,448Coins
    +11,181 / 57 / -2
    As I understand it the QUBIC System QS-H13 Seatmover is a compact design and can be integrated into existing fixed peripheral arrangements: https://qubicsystem.com/product/qs-h13/
    An upside of doing that, as opposed to a full frame arrangements, is that a 2DOF rig will generate additional motion cues in the wrists and ankles when used that way with fixed pedals and wheel.
  3. Misanthrop
    Misanthrop Active Member
    928Coins
    The worst thing is to adjust the seat height compared to your desk. The Seat should be as low as possible on the Seatmover! But it doesn´t look like the Seatmover has adjustable Feets.
    The pedals must be securely screwed in place, otherwise you won't be happy.
    I strongly recommend to test an Seatmover beforehand and in best case compare 2DOF and 3DOF systems with each other.
  4. Sky_Rock
    Sky_Rock New Member
    58Coins
    Thank you for your reply.
    How high is the seat height, approximately?
  5. Misanthrop
    928Coins
    Since we don´t know which seat and seatmounts you want to use, how could we know?
    Just read the FAQ on their homepage, an important point:
  6. Sky_Rock
    Sky_Rock New Member
    58Coins
    Yes, it must be mounted to a stable aluminium profile cockpit. That's what I'm looking for.
    Would the Dardoo 4080 be okay ? Can I mount it without the wheel frame ?
    DX Winner 2 is another nice option.
  7. Sky_Rock
    Sky_Rock New Member
    58Coins
    Yes, the pedals are screwed, thats why I'd like to keep them as they are.
    Same, with the wheelbase.
    I could find a way to make everything a bit higher, that's not a problem, at all.
    I know, Google Ai isnt trustworthy 100 % but...... it says :
    Yes, you can use the Qubic System QS-H13 with your wheelbase on the desk, as it is a "seat-mover" system designed to move only the driver's seat, keeping the wheel and pedals stationary.
    Here are the key details regarding this setup:
    • Decoupled System: The QS-H13 operates independently of the steering wheel and pedals, making it ideal for users with limited space or those using a desk, NLR Wheel Stand, or a fixed aluminum profile rig.
    • Immersive Experience: Even with a stationary wheel, the system uses fast 2DOF (pitch and roll) motion to simulate G-forces and car movements.
    • Software Compensation: The Qubic Manager software allows you to tune the motion, and some users prefer to deactivate sustained roll/pitch to avoid an "unnatural" feeling when the seat moves while the wheel stays still.
    • Compatibility: It is designed to work with most racing chairs or directly onto aluminum profile cockpits.
    Important Considerations:
    • Stability: Since the platform creates violent vibrations on curbs and rapid movements (like braking), you need a very stable desk and a securely mounted wheelbase (e.g., direct drive) to handle the increased immersion without shaking the desk itself.
    Yes, my desk is very sturdy, I'm using it the Simagic Alpha Ultimate ( at 100 % torque and 75 % FFB and everything is perfect )
    Same goes for the pedals. They are mounted, stable, I can't push them away, no matter how hard I press the pedals.
  8. Misanthrop
    928Coins
    Do yourself a favor and don´t use AI Bullsh*t.
    154,448Coins
    +11,181 / 57 / -2
    We are so lucky to have an amazing community here who have direct real world experience and a willingness to help other navigate the many nuances of DIY motion rigs and peripherals.
    I think it also likely that what AI relies on with respect to DIY motion sims and peripherals in all probability includes scraping this site, but in addition to the site terms there are other possible legal complications in doing so, such as myself having a very specific licensing provision in my signature on every post since joining in 2014, and it would take dedicated work and resources to comply with that given my 15k+ posting history across most threads on Xsimulator.net.
  10. Sky_Rock
    Sky_Rock New Member
    58Coins
    Ok, I will never use again, Google Ai "
    Something like this, is what I'm trying to have.
    154,448Coins
    +11,181 / 57 / -2
    As per my earlier comment:
    It looks like the QUBIC System QS-H13 Seatmover can easily be integrated into an Aluminum Profile rig of suitable dimensions: https://qubicsystem.b-cdn.net/wp-content/uploads/2025/09/QS-H13_back.mp4
    That being the case you could look at buying one of the many available Aluminum Profile based commercial offerings, or design what you want, order the related Aluminum Profile and hardware then bolt it together. There are many free and easy to use software tools for designing with T-Slot aluminum extrusion, just do a quick search for 'aluminium profile design software'.
  12. Sky_Rock
    Sky_Rock New Member
    58Coins
    Something like the one from the attached link, would be great.
  13. Sky_Rock
    Sky_Rock New Member
    58Coins
    Would one of those two seats work, with BT 1 Qubic Belt ?
  14. Silas
    Silas New Member
    82Coins
    DC motor, 6DOF
    For a compact setup, a lightweight racing seat with universal rails (like Sparco or Recaro-style) works well. Just make sure it can mount directly to the QS-H13 and adjust for your height.
  15. Sky_Rock
    Sky_Rock New Member
    58Coins
    Something like this, would be perfect for me.
  16. noorbeast
    154,448Coins
    +11,181 / 57 / -2
