2DoF 24V Wheelchair Build
Discussion in 'DIY Motion Simulator Projects' started by Garrett, Mar 14, 2026 at 14:38.
  1. Garrett
    Garrett New Member
    Saturday
    40Coins
    Like many, have played driving and flying games in the past but nothing beats a sim rig for stability and comfort.
    Bought a cheap Dardoo sim rig from Amazon. Made the front speaker support where the monitor normally goes for surround sound.
    Picked up a PS VR2 a couple months ago and have enjoyed the experience.
    Went to an indoor go-cart track a few weeks ago and they had professional grade 2DoF driving sims. Got looking at the construction, a quick Google and found this lovely site.
    Happen to see @Captain Jack's build using the same sim frame. So, all credit to you Captain Jack for the concept. And the motivation credit goes to @Halloween2go after watching your videos.
    The tubing and universal joint were purchased from Amazon. Wheelchair motors should arrive any day from Ebay.
    Welding of the frame is almost complete, just need to make the motor brackets and hall effect brackets. I work for a laser company and a handheld welding system with wire feed.
    Appreciate this site and all the great info!
  2. Jon Amico
    Jon Amico Member Gold Contributor
    414Coins
    Looking forward to the build!! Post pics soon! ;)
  3. Garrett
    Garrett New Member
    Saturday
    40Coins
    A few pics.
  4. Garrett
    Garrett New Member
    Saturday
    40Coins
    Found this when looking at how the brake assembly works.
    These are the same motors that will be used for this build.
  5. Garrett
    Garrett New Member
    Saturday
    40Coins
    I'm a welder for a major industrial laser company so we have some cool toys to play with.
    For this project using the handheld welding laser with wire feed and a cutting laser set up.
  6. Garrett
    Garrett New Member
    Saturday
    40Coins
    Brakes on the motors were removed, they were weak and would fail to fully lock to prevent motion.
    Motor mounting brackets completed.
    Still looking at options for a lever arm from the motor to the heim joints. Once that is finalized can set the position of the motor mounts for welding. Heim joints should be delivered later today.
