Rotary servo 3DOF platform
Discussion in 'DIY Motion Simulator Projects' started by Vasilii, Dec 30, 2024.
  1. Vasilii
    Vasilii New Member
    Russia
    65Coins
    Hello, dear colleagues!
    I would like to apologize for my text, I use a translator.
    I decided to fulfill my long-standing dream and build my first 3dof platform for motion simulation.
    To begin with, I built a 3d model in SolidWorks:
    As drives, I chose the 80ST-M02430 servo drive (A1-SVD15 driver) with a NMRV063-50 worm gear (1:50):
    80st.jpg nmrv063.png photo_5_2024-12-29_21-49-55.jpg photo_8_2024-12-29_21-49-55.jpg photo_15_2024-12-29_21-49-55.jpg
    After completing the working documentation, I placed an order with the factory. The parts were manufactured quickly:
    photo_4_2024-12-29_21-49-55.jpg photo_12_2024-12-29_21-49-55.jpg photo_7_2024-12-29_21-49-55.jpg photo_6_2024-12-29_21-49-55.jpg
    When the parts arrived, I started assembling. There were no difficulties with the assembly: photo_26_2024-12-29_21-49-55.jpg photo_27_2024-12-29_21-49-55.jpg photo_9_2024-12-29_21-49-55.jpg photo_14_2024-12-29_21-49-55.jpg photo_25_2024-12-29_21-49-55.jpg photo_20_2024-12-29_21-49-55.jpg photo_17_2024-12-29_21-49-55.jpg photo_19_2024-12-29_21-49-55.jpg photo_18_2024-12-29_21-49-55.jpg photo_32_2024-12-29_21-49-55.jpg photo_30_2024-12-29_21-49-55.jpg photo_31_2024-12-29_21-49-55.jpg
    I use Arduino UNO as a controller. I found the servo drive connection diagram to the Arduino, the Arduino code, and the servo driver parameter settings on the @Lebois website. Thank you very much, my dear friend!
    At the moment, I have not yet purchased a SimTools license (I will definitely buy it later) and am trying to use FlyPT with the DIRT 3 game. The platform moves, but there are some problems, such as uncontrolled sharp rotation of the drives during platform operation (I will upload a video a little later). I understand that I need to configure filters, but I have not yet figured out all the FlyPT program settings.
    After setting up adequate platform movement, I am going to install the chair and the Moza R5 kit.
    I would like to note a significant drawback of worm gear drives - this is a "knock" (noise, impact) when changing the direction of rotation of the servomotor. This happens due to play in the gearbox engagement. At the moment, I do not know how to reduce this "knock". Has anyone managed to solve this problem?
  2. Aerosmith
    Aerosmith Active Member
    self employed
    2,907Coins
    3DOF, AC motor
    Nice work! The knocks caused by the backlash of the gear will hopefully disappear when there is enough weight on the rig to ensure that the gear is always biased in the same direction.
    • Old Old x 1
  3. m50b20
    m50b20 Member
    112Coins
    Until you got 2g+
  4. Vasilii
    Vasilii New Member
    Russia
    65Coins
    To test the reduction of knocking caused by backlash in the gears, I loaded a platform weighing ~ 130 kg (me and my girlfriend). The sound has become a little quieter, but still significant.
  5. Vasilii
    Vasilii New Member
    Russia
    65Coins
    What do you mean?
    154,166Coins
    +11,174 / 57 / -2
    Pragmatically, the longer the lever attached to the motor the more pronounced any inherent backlash will be.
    A small amount of positive weight bias can help mask backlash, but will not eliminate it it, particularly with a fast powerful rig.
  7. Vasilii
    Vasilii New Member
    Russia
    65Coins
    After the first test, I had to install filters: Roll, Pitch, Heave = EMALP(VALUE; 200.00)
    It is very difficult to stay on the platform without these filters!
  8. Vasilii
    Vasilii New Member
    Russia
    65Coins
    I bought a chair, belts, a standard Moza R5 kit and an aluminum profile.
    I assembled a simple cockpit in 1 evening. It is comfortable to sit in the chair, but I want to change the angle of the pedals.
    Tonight I will try to fix the cockpit on a movable platform (with the possibility of longitudinal adjustment) and do a test switch-on.
  9. Vasilii
    Vasilii New Member
    Russia
    65Coins
    What are the specifics of using Arduino Leonardo (atmega32u4) as a platform controller with FlyPT Mover?
    I uploaded the sketch to Arduino Uno (atmega328) and it works fine, but the same code does not work on Leonardo. The serial connection freezes.
  10. Luis miguel dolz
    Luis miguel dolz New Member
    - 4Coins
    Motion platform
    Hello Vasili, i love your design. I have a question please! The conector with the cranck and the " arm" have you design by your person or have you buy it?? Im talking about the conector with hexagonal part and circle part that its conected to ball bearing cranck and the vertical arm. THankyou so much! you can share me please? i have made other project little bit difference like you but this kind of join its good!
  11. ESIGAERO
    ESIGAERO New Member
    34Coins
    Hello Vasili! I am very impressed with your simulator and was wondering how you managed to achieve such high-quality 3D rendering?
  12. Vasilii
    Vasilii New Member
    Russia
    65Coins
    Hi! I use SolidWorks for 3D modeling.
  13. ESIGAERO
    ESIGAERO New Member
    34Coins
    Would it be possible to get your SolidWorks design file? It's the best I've seen, and I don't think I'll ever be able to create one as good as yours.
    Thank you very much in advance!
  14. Vasilii
    Vasilii New Member
    Russia
    65Coins
    Hi!
    I've uploaded the zip archive. The model for SolidWorks 2023 is located at /3DOF/3dof_063_xsim.SLDASM.
    I've also added the step file, it's in the root of the archive.
    Download the model from Google Drive
    • Useful Useful x 2
  15. ESIGAERO
    ESIGAERO New Member
    34Coins
    Thanks you very much!I've sent the access demand, i wish the best for you and your projects.
  16. Vasilii
    Vasilii New Member
    Russia
    65Coins
    I allowed access to the file without asking for additional permissions.
  17. Dmitrii24
    Dmitrii24 New Member
    24Coins
    which gearbox did you use, and what is the gear ratio?
