DD-Wheel with Hoverboard Motor
Discussion in 'Direct Drive Wheels' started by Benu, Jan 21, 2019.
  1. Alex410
    Alex410 New Member
    22Coins
    @Radje748 It seems to be written in many places that the main thing is power, if so that would mean they are equal.
    At the same time, I think that the higher the voltage, the lower the current, and thus the less the heating... but this reasoning might be flawed. Aren't all hoverboard motors for at least 42V? I bought a motor separately, and I don't know what voltage it's for. Although I've just looked at it more carefully, it says 36V, that's strange.
    So it turns out I bought a 48V power supply for nothing...
  2. Radje748
    Radje748 Member
    287Coins
    Just try it... what I mentioned, I have a 24v power supply running on 20v. So in your case...48v Power supply with a 56v board and a 36v motor... I would say... try it on 30-35V and test it.... Assuming that you have an adjustable power supply...
    The DD-Wheel is very...very strong...you will never use it on 100%... or your name must be popeye ;)
    I am running it on 40% and it is already very strong....
  3. maxcodl
    maxcodl New Member
    53Coins
    hi i had a doubt
    why did you get the 56v version? will it work with a 24v powersupply?
    gemini said that i should buy the 56v version of the board instead of the 24v to be safe because it thinks that higher voltage means the board wont get fried or shorted out during some crazy event
  4. BigBert
    BigBert New Member
    22Coins
    DC motor
    Hi I’m fairly new to electronics outside of ohms law so I wanted to ask if I’m on the right page with my parts list for my hoverboard motor sim build.
    I picked up 2 (36v) hoverboards that are 5inches on the OD that the tire sits on. I got them for 25 bucks but unluckily they have 20 mm stators and magnets with what looks like 4 strand windings, not the best but that’s what I’ve got.
    The parts I plan on ordering are:
    - Meanwell 12v 350w power supply
    - 24v ODESC 4.2
    - 2048p rotary encoder (NPN meaning I have to use pull up resistors on the signal lines??)
    - other miscellaneous stuff like a wireless board for wiring up buttons
    My main questions:
    - should I keep looking for a motor with bigger stators and magnets, is it necessary?
    -should I go with the 12v 350w (~15A) meanwell power supply, or should I go with their 24v 350w (~30A) supply. The price is nearly identical and I’ve seen posters say that they usually turn down their 24v supply to ~19v and have no issues with sluggish responsiveness while also reducing risks of the odesc failing over time.
    I understand that with higher Volts you get more speed out of the motor, and with higher amps you get more torque, but I’m concerned that for drift sim applications 12v 30A might not be enough to keep up with going lock to lock accurately.
    Also, if I were to go with the 30A supply would I be exceeding the 10N-m max rating for 20mm stators mentioned on ffbeasts guide. Their ratings were measured at 15A so I’m curious.
    I plan on using my rig for sim drifting and most people recommend 8N-m for that, but I would like to have an idea of how far I could push it if I were to ever do F1 sim or something of that nature.
  5. BigBert
    BigBert New Member
    22Coins
    DC motor
    Correction: I flipped the amps of the power supplies in my questions section but too late to edit it
  6. maxcodl
    maxcodl New Member
    53Coins
    sorry for the late reply
    where did you get the motor tho? from a hoverboard or any supplier? and for the powersupply, i have no idea cus for now im using a laptop charger (64w) and for some weird reason, i feel like its more than enough for me but i might buy a proper powersupply later in the future.
    as for your question, ive seen people saying having a bigger motor is better because of high torque and proper heat decapitation and many saying no body is going to use above 10nm, but for me personally, i dont think i need that much power from the wheels cus i get tired easily. you should find someone with the sim racing setup and try it out and see if you want more torque or not. if yes then look for a better motor and powersupply else you can stick with what you have. i hope this is what you wanted to know cus im brain dead rn and ill tell you if you have any other questions
  7. Misanthrop
    Misanthrop Active Member
    988Coins
    This is a discussion which will be never end i think. Same with Clipping....
    Ofcourse for most people are 15Nm enough, BUT it doesn´t mean you will not benefit from higher torque. The Slewrate with higher Torque is much better, which will result in more Details and controllability. This becomes even more important with heavier steering wheels, such as all the overhyped and overpriced steering wheels with fancy screens, which significantly increase inertia. The diameter of the steering wheel also becomes increasingly important. A round steering wheel with 15 Nm may suddenly feel much too weak, whereas a 280 mm GT wheel was much too strong.
    The same applies, for example, to different settings and profiles. Many people have the world's best settings, better than anyone else's, and everyone else should use them in their opinion. However, many people forget that these settings change significantly as soon as you use a different steering wheel, and end up complaining about oscillations.
    It will always be better to reduce an overly strong base than to use one that is too weak and constantly on the verge of clipping. This can be applied to pretty much everything in the technical field.
  8. Radje748
    Radje748 Member
    287Coins
    Just build and test. the feeling of the hoverboard wheel is different compared with a normal direct drive. and do not underestimate NM feeling and the strength... 10 NM is more than sufficient, especially with fast movement...I have tested above 15NM...not playable.... just way too much....
  9. Robinj
    Robinj New Member
    58Coins
    2DOF, 3DOF
    how is it different from a normal direct drive ? In a good way or in a bad way ?
