Showroom Compact AC Servo 6DOF Rotary Stewart platform
Discussion in 'DIY Motion Simulator Projects' started by knaufinator, May 26, 2020.
  1. truyentu
    truyentu New Member
    32Coins
    3DOF, Arduino
    hello,so the phoenix branch will need a new pcb,right ?
  2. knaufinator
    knaufinator Active Member
    Simulation Engineer
    akron,ohio
    1,941Coins
    AC motor, 6DOF
    No — last weekend I started making the old PCB compatible with the new workflow. The latest phoenix branch has a desktop app that controls both the Mini and the old PCB. The firmware auto-detects which board you're building for based on the build target:
    • idf.py set-target esp32 → PCB v1
    • idf.py set-target esp32s3 → PCB v2
    Pinouts and drivers are configured automatically — no manual defines needed. No new PCB required.
    The goal for the new PCB (v2) is faster step rates, more precise timing, and Ethernet control — but the old PCB is still supported.
    Important caveat: this is all purely in testing right now. I have not attempted to run it on the actual rig yet — so far it's only communicating between the ESP32 and the desktop app (serial handshake, geometry config, etc.). I intend to do real hardware testing on the rig later this month. As well ive got my first order of parts for the new pcb to test a single motor out with.
  3. SGUDrago
    SGUDrago New Member
    53Coins
    AC motor, Arduino, Motion platform, 6DOF
    Sorry I didn't find the information, somehow I thought I need a motor with brake. But I don't find that in the description. Are your Motors Equiped with brakes?
  4. knaufinator
    Simulation Engineer
    akron,ohio
    1,941Coins
    AC motor, 6DOF
    No brake is needed or used on my rig, and that seems to be the case for most — if not all — builds using this design.
    In practice, it hasn’t been an issue. When power is removed, the swing arms naturally and smoothly settle into the low position. The movement is gradual, not to abrupt or jarring — at least in my experience with my setup.
