Question how to link simtools with vr headset and steam VR
Discussion in 'VR Headsets and Sim Gaming - Virtual Reality' started by William816, Oct 21, 2024.
  1. William816
    William816 New Member
    48Coins
    Hello everyone, I have a little confuse about the VR simulation. please support if you know my questions:
    1. there is no problem about the output from simtools to normal computer game(means no VR)\
    2. I download the openVR compensation, and find the interface. however, how to connect openVR compensation with simtools and my VR headset(occulus quest 3)?
  2. Alvaro George Menendez
    Alvaro George Menendez New Member Gold Contributor
    Sydney NSW Australia
    81Coins
    I am currently building Dr ADHD aka Kevinski 4DOF Motion Sim that he has posted on YouTube, and will be using a Pimax XK8 when I'm finished ( hopefully) .. Have you worked out a way forward for you yet ? Is Motion Compensation possible? I have purchased a WITmotion wt901C in anticipation that somehow will work.
  3. Thierry59191
    Thierry59191 Member
    - 76Coins
    4DOF
    I'm currently looking into motion compensation myself. I went from a 2-DOF setup with two actuators to a 4-DOF setup with five actuators, and now I feel the need for this compensation.
    At first, I used the Pimax software along with one of my controllers, but it's way too sensitive and not adjustable with filters. I found this video from LeBoisRacing, which explains it quite well, but I haven't had the time to try it yet:
  4. Royal1180
    Royal1180 New Member
    22Coins
    Thanks for your video, it's exactly what I was looking for, tired of teleporting lol
  5. Thierry59191
    Thierry59191 Member
    - 76Coins
    4DOF
    You're welcome! I can't help much with my skills, but when I find something interesting, I don't hesitate to share it :)
  6. Royal1180
    22Coins
    Hy, I followed the video, but it's not easy. I haven't managed to achieve much so far. I'll give it another try with a fresh mind tomorrow. But I need to figure it out with the SRT80 and 200mm of travel, it's complicated not to teleport inside the car :nerd. Did you try on your side?
  7. Thierry59191
    Thierry59191 Member
    - 76Coins
    4DOF
    I haven't tried yet. I'm retired but still very active on the side. I'll give it a try when my son visits, and I'll keep you posted :D
  8. Fahim
    Fahim Member
    553Coins
    Do you need base stations for the pimax crystal for VR? FOR MOTION compensation?
  9. Alvaro George Menendez
    81Coins
    Hi Fahim... I have an Pimax 8KX so not 100% sure about the Crystal.. but I use stations for VR Motion compensation.
    The Pimax Crystal does support motion compensation, but it seems to require some additional setup. You may have to mount a controller on your motion rig to enable proper tracking. Some users on Reddit have reported that motion compensation is available within the Pimax Play client but may require manual adjustments.
    See if this video helps ...
  10. ggbro
    ggbro New Member
    24Coins
    so in order to get motion compensation in simtools how can we do it
    154,256Coins
    +11,177 / 57 / -2
