Showroom Budget Compact 6DOF Universal VR Flight / Racing rig - MSFS, SMC3, FlyPT, Transducers, Controls
Discussion in 'Commercial Simulators and Peripherie' started by Ronan Design, Oct 11, 2024.
  1. Kibiu12
    Kibiu12 New Member
    - 46Coins
    Hi guys, I am also building @Ronan Design amazing 6DOF with the 24V - 350W motors and 2x 1200W power supplies.
    Control box same dimensions and mostly same components as original but with 3x dual channel 20A Cytrons MDD20A due to the bigger motors and additional 4 channels relay module as per @Martwana , for which I please ask the electrical plan to connect this one :sos. And then planning to use @OrtiMai @Sebastian2 modified code.
    I will post a quick photo showroom of my build if @Ronan Design grants permission with only photos and major changes to original design like bigger motors and my fixed 8020 extrusion profile rig on top, hopefully it will move all that and the extra Xmas food :D
  2. OrtiMai
    OrtiMai Member
    151Coins
    That sounds well designed, with the right thoughts and conclusions. I wish you a good progress.
  3. OrtiMai
    OrtiMai Member
    151Coins
    Feel free to use the improved stoppers. @Ronan Design (you might consider to use them in your package as well)
  4. Kibiu12
    Kibiu12 New Member
    - 46Coins
    Hi @Martwana would you mind sharing the electrical diagram of the second relay board how it connects to the rest? Also the relay boards 5V supply how is done? Thanks in advance
  5. Kibiu12
    Kibiu12 New Member
    - 46Coins
    Hi @Ronan Design in you download pack there is no instructions on how to connect the Deek-robot meters to the motors / power supply. I am still a noob on electrical stuff, considering I am using the 350W motors with 2x 1200W 24V power supplies and 3x Cytron MDD20A could you please advise how to connect them properly to ensure correct readings?
    I also have the impression that these meters might not be good enough for the 350W motors. I share my ECB and the deek-robot connection diagram I found online.
    Thanks in advance
  6. OrtiMai
    OrtiMai Member
    151Coins
    Are you familiar with how to measure current and voltage?
    There are videos on youtube how to connect them. Pay close attention to them and make sure, you understood how to aviod a high potential difference in your measurement system. Otherwise your cable will explode. If you're not sure, your welcome to share your drawing and we can try to review it. I think, the most important learning is, that you don't connect the white measurment wire to the PWM-side of the controller, but on the steady power supply.
  7. SchorschXxX
    SchorschXxX New Member
    - 34Coins
    i also want to build such a sim rig. But i need to check the dimensions first befor i buy the plan.
    Can someone tell me the dimensions of this build the ground triangale, hight until the seat mount etc. ??
    THX
  8. OrtiMai
    OrtiMai Member
    151Coins
    Hi
    Hi Schorsch,
    if you have a Cube of 2m in each direction, you should be good.
    Feel free to write me a private message in German as well.
  9. HyperJoel
    HyperJoel New Member
    2Coins
    Been working on my version of this build as well. Sticking pretty close to the plans as written for now, currently on the hall effect sensor setup. So far so good.
    Wanted to add a couple findings I haven't seen mentioned here or in the build guide:
    1. The connectors for the motors are 6.3mm 4p automotive connectors. Using those connectors will work way better than sticking wires into the motor connectors or stripping the wires.
    2. I had slight misalignment issues with the provided hall effect sensor arm model. Maybe just my cheap printer being inaccurate. A carefully applied heat gun will soften the PLA enough to allow the slight adjustment needed for centering without having to modify the file and reprint.
    AP1GczP7oyS5WCR3KOX0zhowK3lyebRvMfhis-b5fhqzeIIaHO0ZXF0TylYQBAw1204-h903-s-no.png AP1GczNBviGkproBTX6F3JMnzwuAl8IUcfOBWpPPrdmncHwctppHJC6crtwDagw1185-h889-s-no.png
  10. OrtiMai
    OrtiMai Member
    151Coins
    Thanks for sharing. No. 1 is very helpful. No. 2 I did the same. I think I mentioned here already. Heat it up a bit and let it relax, that it sits perfectly. This is very importand for a well working rig.
  11. Kibiu12
    Kibiu12 New Member
    - 46Coins
    Thank you, I have checked various video and I think I understood how to connect the Deek Robot.
    I made a quick schematic attached the way I understood it, would you mind checking it?
    Now what I am left to understand is the connection of the second relay board as Martwana did then I can power up everything as the both base and top platform are all done.
  12. Kibiu12
    Kibiu12 New Member
    - 46Coins
    Hi @Ronan Design @OrtiMai, I practically finished everything, I am missing only to upload the code to the arduinos and glue the motor arm hall sensors. I tried to power it up but for some reason 24V are not reaching the Cytrons MDD20A, if I bridge the relays directly to the cytrons I am able to move the motors manually with the buttons only in one direction, which I guess is normal.
    The relay outputs 24V and the fuses also have 24V so the only thing it could be causing the issue are the rectifiers, I did connect them as per instructions, at least it seems I did properly. Are you able to please help on this issue?
    Thanks in advance
  13. OrtiMai
    OrtiMai Member
    151Coins
    I'm not 100% sure, but I think from your description, that you're facing the safety function. To prevent, that you get in any harmful situation, the engines get only powered, when they are in the designated area of angle. Please review the safety function in the code intensely and see under which circumstances the engines are powered up. Of cause, the hall sensors need to be assembled, as the sensor feedback is part of the safety function.
    Does that help you?
  14. Kibiu12
    Kibiu12 New Member
    - 46Coins
    Not really, with the self test button on the cytrons the motors should move in both directions but they move only 1 way, the other way is giving error and just make a strange noise but don't move. I saw @Ronan Design first power up video and he was moving the motors in both directions with the self test buttons without any firmware loaded in the arduinos.
  15. OrtiMai
    OrtiMai Member
    151Coins
    Yep, if the
    Well, if your motor controller is getting power, then you should be able to test it manually. FWD and REV buttons should work as you saw it in the video. Sadly I can't support you with MDD20A.
  16. Kibiu12
    Kibiu12 New Member
    - 46Coins
    Thanks anyway, maybe @noorbeast might have an idea why. I also noticed that @Martwana system is closer to mine for the dual relay module and in his system I see the rectifiers are wired differently than the original so was wondering is that could be the solution but I don't want to fry anything being so close to finish it.
  17. Kibiu12
    Kibiu12 New Member
    - 46Coins
    Attaching the electric diagram based on my configuration for review, maybe I did some mistakes somewhere.
  18. Kibiu12
    Kibiu12 New Member
    - 46Coins
    @OrtiMai blown an arduino while troubleshooting but found the issue, after blowing the arduino I had to unplug the deek robot because of space and motors started spinning in both directions, so the issue was caused by all 6 deek-robot, don't know why because it would be nice to have those to check parameters
  19. HyperJoel
    2Coins
    Oh yeah, I had missed that message, good tip!
    My setup is coming along, I'm at the point where all the arduinos are happy and all relays are enabled. Still have some more calibration to do with my hall effect sensors before powering the motors. The max/min numbers are too far apart for 2 of the sensors on the same board. 1 sensor reads roughly 200-700 while the other reads roughly 300-600, which seems farther apart than other setups. I see conversation here talking about how the numbers need to be set the same for both motors on the same arduino, but I don't see anything in the code that would prevent me from setting motor 1 and motor 2 limits separately. Still gonna try to get the readings closer with physical changes and maybe a rebuild of 1 sensor assembly, but we'll see.
    Took me a bit to understand the magnet placement, crappy ms paint recreation attached in case it helps others. The guide says "align the little hole to be on the upper side of the assembly" which confused me initially. In my words: with the arm facing parallel to the ground, align the hole to face straight up.
    I also made a quick model to hold the estop and a QY603-101 power switch on the side of the platform that could be useful to others. Can't attach an STL here so I put it on thingiverse: thingiverse com/thing:7285241
  20. OrtiMai
    OrtiMai Member
    151Coins
    Good idea! I'll print a version myself. Thanks!!!
