Question What’s the standard these days?
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by rundmg, Feb 3, 2026 at 04:43.
  1. rundmg
    rundmg Member
    Client Platform Engineer
    Pennsylvania - USA
    413Coins
    Hi all,
    It’s been nearly 10 years since I’ve been in the DIY sim racing space and I’ve been feeling the urge to come back for a while now. I imagine there has been changes in the space from the hardware I was using on my original build
    What hardware should I be digging into and researching? Any threads on here you consider must reads for someone that’s been out of the loop for so long?
    153,697Coins
    I guess the first clarification questions are what is your budget and personal experiential priorities?
  3. rundmg
    rundmg Member
    Pennsylvania - USA
    413Coins
    Don't really have a budget at the moment. Looking at 3->6 DOF setup. At this point I am trying to deduce where the rate of returns start to drop in my mind and then go from there.
    Previous build was JRKs with stepper motors, potentiometers etc. Really curious if there have been advances in other tech that make new builds possible that weren't before
    153,697Coins
    As you are considering 3->6 DOF I would suggest you research AMC-AASD15A servo controllers, which make using those servos almost plug and play for either a rotary or linear actuator rig: https://www.xsimulator.net/community/faq/amc-aasd15a-servo-controller.351/
    You can build or buy AMC-AASD15A powered linear actuators, please do research recent DIY actuator designs and builds if you are contemplating that pathway, as there has been considerable actuator refinement by members over recent years.
