DIY 4DoF motion simulator with Traction Loss
Discussion in 'DIY Motion Simulator Projects' started by the2jakes, Mar 1, 2020.
  1. the2jakes
    the2jakes Member Gold Contributor
    137Coins
    DC motor, Arduino, 4DOF
    Hi I bought them from Simukit (belgium).
  2. the2jakes
    137Coins
    Here’s a Showcase video of my project:
    Video of us having fun with it:
    Next steps: add the 4th DoF platform underneath the actual simulator, paintjob, and add my PSVR helmet.
  3. JayZ83
    JayZ83 New Member
    152Coins
    Great!
    There will be same as what i am planning .`~
    Great result on yours.
  4. the2jakes
    137Coins
    It’s been some time since I posted here. I was on another project: 4WD electric Buggy ;).
    For the last 2 days, I’ve been working on the 4th DoF of my motion sim, for Yaw. I’m using ball bearings, and a pivot at the front. It moves very well by hand. Will connect 4th motor soon to test it, and add wheels on the top of the simulator base to maintain it well towards the black base:
  5. the2jakes
    137Coins
    Done some painting and decorating to give it a finished look:
    Here it is in action, with its 4th DoF:
  6. the2jakes
    137Coins
    Hi !
    VR is now installed ;).
    I use Pimax 8KX VR helmet. 4K resolution per eye, with eye tracking for DFR (Dynamic Foveated Rendering). Here I play Assetto Corsa.
    Next steps: better cable management at the rear, and wind turbine addon.
  7. the2jakes
    137Coins
    Hi, just added a homemade handlebar to p’ay Motorbike games in a more immersive way ;)
    • Creative Creative x 2
  8. Manes
    Manes Member
    179Coins
    nice job man. Do you use SMC3 code? Can you share images of configuration of SMC3 utility and Simtools? I have problems, and maybe your configuration can help me. And nearly, i want upgrade my motion sim same yours
  9. ART FLY
    ART FLY Gettin' High on DIY :) Gold Contributor
    Bavarian State Theater, Decoration Stock Manager
    BAVARiA
    421Coins
    Yes please. I'd love to see that too.
    Please show it if you use smc3.
    Thanx in advance,
    Yours ART FLY []-)
  10. kalbasator
    kalbasator Active Member
    Kazahstan, Almaty
    152Coins
    3DOF, DC motor, Arduino, Motion platform, 4DOF
    Hey! You did very well!
    Can you tell me what springs you used?
    Were there any cases of springs popping out of their places?
  11. cyberxu
    cyberxu Member
    AME Planner
    Ontario, Canada
    522Coins
    Great Build...Love your videos. May I know the size of your 3D printed Gear for the POT and worm gear shaft? Do you have a stl. file you can shared? Thanks
  12. the2jakes
    137Coins
  13. stargazer
    stargazer Active Member
    Electrical/Computer Engineer
    Boston,USA
    811Coins
    3DOF, Arduino, Motion platform, 4DOF
    @the2jakes , would you be able to show more pictures of your traction loss implementation? i would like to see how you created the pivot and connect all the ball bearing and wheels. if you can give a link to where you bought these parts then it will be helpful too. thank you.
  14. the2jakes
    137Coins
    Sure, here are a few pics.
    For the pivot I used a part similar to this one:
    https://www.manomano.fr/p/bs-rollen...ou-de-vistf-67x67mm-32366248?model_id=6215960
    You’ll have to dig holes in the 2 plank of wood to have the same distance between the 2 planks that you have with the ball bearings, to be horizontal.
    for the ball bearing I ordered them in a french company (sorry I forgotten its name…) but they are similar to these ones:
    Make sure they are steel balls and not nylon, and try to get some that can handle a good weight (CY-30b).
    Ball bearing need to be installed on the lowest plank of wood, and steel sheets on the top one, to limit dust problems.
  15. Kenshiro27
    Kenshiro27 Active Member
    252Coins
    2DOF, 3DOF, Arduino
    Hi the2jakes,
    Very nice work and prettier simulator
    the proof that wood swith metal is still a good idea, thanks for the photos
  16. the2jakes
    137Coins
    Hi guys, a little update about the last evolution of our DIY Motion sim: we replaced our T300 RS wheel with a DIY FFBeast Direct Drive wheel. It’s a blast !
    If you’re curious, it starts here: https://ffbeast.github.io/#diy-force-feedback-wheel
    I chose to integrate all the cables inside the steering column, as I'm not a fan of cables dangling from the wheel . I also preferred to integrate the encoder into the steering column, inspired by this concept:
    https://www.printables.com/model/1326250-encoder-and-slip-ring-mount-for-ffbeast-wheel-v2?lang=fr
    I created a similar 3D model of this mount to accommodate the mini-DIN connector compatible with my Thrustmaster steering wheels, and my encoder and slipRing.
    I installed a quick-release, attached with a modified adapter like this one: https://petermakesthings.co.uk/product/thrustmaster-qr-adapter/
    so that the mini-DIN connectors of the steering wheels plug in when a wheel is installed on the steering column.
    The motor is a 5-wire Hummer type hoverboard motor (a bit more powerful than "classic" hoverboard motors, but anyway, with the power setting at 40%, I'm very happy with it).
    I know these motors well, having installed them in numerous vehicle projects: 4x4 buggy, off-road skateboard, drift kart, sled, etc. For those interested, check out my YouTube channel :
    My first impressions of using it are great!
    Now I need to look into the force feedback settings in the FFBeast configurator, as well as in the games themselves, because I'm not yet familiar with all of these settings.
  17. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    Here's a really complete and beautiful simulator:thumbs
  18. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    I actually used your model as inspiration for traction loss in my simulator, and it works perfectly, thank you!
  19. Theodore X Toth
    Theodore X Toth New Member
    Sunday
    46Coins
    Hopefully you're still around and remember details of your build which I would like to replicate. Can you give me information about shafts, lever arms, red gears, position sensing pots, etc... that are attached to the motors, please? Did you find an off the shelf source or did you machine/3d print them yourself?
  20. the2jakes
    137Coins
    Hi, I bought all the motor/gear stuff at Simukit. Now it’s on Discord. Link here:
    https://simukit.com/fr/
