Question SimTools: Source (DIY) PC Error When Installing Plugins – Need Help with Setup
Discussion in 'News' started by pikky, Sep 6, 2025.
  1. pikky
    pikky New Member Gold Contributor
    24Coins
    Hello, I need some help with SimTools. My setup: • Source PC (DIY license) → no games installed, only used as the network sender/forwarder • Target PC (Pro license) → runs the actual game (Assetto Corsa / ACC) and drives the motion rig Problem: • When I install the game plugin (for example Assetto Corsa), the Source PC (DIY) cannot run Game Engine anymore.
    • The Target PC (Pro) works fine with the plugin. Questions: 1. Do I need to install the plugin on both Source (DIY) and Target (Pro), or only on the Target PC? 2. How can I fix the Source PC so that Game Engine runs without trying to load a game plugin? Thanks in advance for your support!
    Pukpik
      406.8 KB
      86
      345.2 KB
      95
      509.4 KB
      95
    153,986Coins
    +11,162 / 57 / -2
    Please see the dual PC info in the FAQs: https://www.xsimulator.net/community/faq/dual-pc-simtools-setup.251/
    And the manual: https://www.xsimulator.net/community/faq/rtfm-start-with-the-official-simtools-documentation.117/
    Make sure the PC language is set to English Local: https://www.xsimulator.net/community/faq/simtools-language-setting-bug-change-to-english-local.233/
    And LFS is run in first person before patching for motion: https://www.xsimulator.net/communit...run-in-first-person-mode-before-patching.365/
    And be mindful that SimTools v3 does not support dual PCs, so it really is a dead-end pathway to eventually being unsupported at some point in the future.
  3. pikky
    24Coins
    Thankyou
  4. Zigmun
    Zigmun New Member
    45Coins
    3DOF, SCN6, 4DOF
    And what causes these errors?
      12.3 KB
      24
      7.8 KB
      21
      7.9 KB
      22
      26.4 KB
      23
      9.3 KB
      22
    153,986Coins
    +11,162 / 57 / -2
  6. Zigmun
    Zigmun New Member
    45Coins
    3DOF, SCN6, 4DOF
    It's sad. Thank you.
