Question when simhub is running, simtools motion stops working
Discussion in 'SimTools DIY Version' started by pikky, Dec 29, 2025.
  1. pikky
    pikky New Member Gold Contributor
    24Coins
    how can i prevent simtools from conflicting with simhub when using the same motion system (aasd/arduino)? when simhub is running, simtools motion stops working. is there a recommended setup or port/interface configuration so both can coexist without conflict?
    154,292Coins
    +11,178 / 57 / -2
  3. Silas
    Silas New Member
    76Coins
    DC motor, 6DOF
    SimTools and SimHub usually can’t run at the same time on the same motion system. It is best to use one at a time or set up separate virtual ports for each to avoid conflicts.
  4. pikky
    24Coins
    I've switched to SimTools v3 now, so I've eliminated the signal interference issue. Thank you.
  5. Henjamin
    Henjamin New Member
    40Coins
    DC motor
    'm not sure how to set up virtual ports for SimTools and SimHub so that they can run simultaneously without conflicts. Could anyone provide more detailed guidance on how to do this? Thank you in advance!
    154,292Coins
    +11,178 / 57 / -2
    Please see my earlier comment and FAQ link:
