Showroom Compact AC Servo 6DOF Rotary Stewart platform
Discussion in 'DIY Motion Simulator Projects' started by knaufinator, May 26, 2020.
  1. SGUDrago
    SGUDrago New Member
    22Coins
    AC motor, Arduino, Motion platform, 6DOF
    Hello all awesome guys
    First of all special thx to this guy I call now Mr awesome. Its crazy what you have realised and even more that you are still giving support after all these years.
    I'm really looking forward to copy your hell machine and reading/gathering information about building 6dof Plattforms for nearly 6 months now. Since my budget is very limited I have to find a solution for these superexpensive AASD15A drivers as well as for the planetary gears.
    Before I throw my mind and life completely into this project I have to check first several points:
    1. Can i use an alternative driver?
    This is the description at amazon (sorry, I'm not allowed to post links yet.)
    Ac Servo DriveHTNC-C30S-L20A-RABN-B
    I've tried to understand your controller architecture (without reading the code). As much as I know thus driver is similar to the AASD15A. But I don't know if the commands for communication are the same. Do you think it is possible to adapt your controller and software to this driver? Or do you think that it will be like developing it from the roots?
    2. I don't think I,ll be able to manage this completely on my own (especially the coding part). Do think it will be possible to rely on your awesome support?
    I think this project would help a lot of people with budget issues.
    My background:
    I'm an aerospace engineer with the possibilities to construct most stuff on my own. Only my programming knowledge is limited. But with chatgpt I have realised my own hotas with arduino. I understand the fundamentals of programming but I don't know the syntax etc.
    So what do you think Mr awesome?
  2. knaufinator
    knaufinator Active Member
    Simulation Engineer
    akron,ohio
    1,920Coins
    AC motor, 6DOF
    I took a look at the website for the driver, they do say that it works with step/direction commands for control, as one of their methods, these drivers do look like they can be used with multiple communication protocols, step/direction being one of them. you may be on your own as far as wiring them as they may/most likely are not the same, but that should be a trivial task... give or take... what is step/dir control you may ask,... just pulses ,each step the motor travels, it gets a pulse for the given direction that is indicated by the dir wire, high or low, forward or back. will take some tinkering to get the ratios and virtual gearing right, but should be dooable.
    I can help, I dont spend much time on this lately, got other bigger projects i am working on. but i can help,, suggest attempting to play with 1 motor at first, once you get it working/ characterize its ability with the pcb circuit, then the rest of the build becomes trivial.
  3. SGUDrago
    SGUDrago New Member
    22Coins
    Omg I'm already suffering at the first steps. When I open the kicad project file I can't see any symbols or connections. Am i doing something wrong? It looks like this:
  4. knaufinator
    Simulation Engineer
    akron,ohio
    1,920Coins
    AC motor, 6DOF
    at the top of the default branch (pheonix) readme - "This branch is currently a work in progress and does not yet have full functionality. It is being actively developed and updated regularly as development continues."
    What you want is the old working branch "master" not the newer Pheonix branch - direct link - https://github.com/knaufinator/6DOF-Rotary-Stewart-Motion-Simulator/tree/master
    i have been tinkering on a faster better version "pheonix", but have other higher priorities so only spend a few hours a month on it.
  5. Mmm
    Mmm New Member
    60Coins
    Thanks for making the effort of designing and building this impressive rig. Even more so for sharing the details.
    I really got inspired and while I'm no engineer and surely don't know enough about servos and different controllers etc. I do have a garage equipped with all sorts of tools which makes me think I migh actually take a stab at such project.
    I should be ok to do the steelwork but choosing the components to buy will probably need some input from the author or the others who have successfully followed in his footsteps.
    I am planning on buying a 6dof AC servo kit from Aliexpress. The motors with 50:1 gearboxes and controllers work out at about £2100 delivered to UK.
    I can't post the link yet as I've only joined the forum but I'm attaching a screenshot. It is listed under this name:
    DIY 6DOF-Rotary-Stewart-Motion-Simulator 220V 750W AC Servomotor White Driver and Helical Planetary Reduction Motor 50:1
    Is this what I should be getting in terms of closely following the project?
  6. knaufinator
    Simulation Engineer
    akron,ohio
    1,920Coins
    AC motor, 6DOF
    wow, they made a full kit! yeah, this looks like the right stuff
    its interesting, that the title even matches my github repo name - hmmmmmmm
    " 6DOF-Rotary-Stewart-Motion-Simulator"
    https://www.aliexpress.us/item/3256808046771564.html?gatewayAdapt=glo2usa4itemAdapt
  7. Mmm
    Mmm New Member
    60Coins
    It's amazing isn't it? The Chinese manufacturers don't mess about. If there is business to be made there on it.
    Does it seem reasonable price wise compared to what you have got there?
  8. knaufinator
    Simulation Engineer
    akron,ohio
    1,920Coins
    AC motor, 6DOF
    i just looked at my orders from 2020 ish, $260 per gear, $217 per driver, x 6 = 1560 + 1302, = $2808, in 202o money. the kit with 6 drivers + 6 gears, appear to be $4000 ish USD, so an increase in 1/3 of the cost, this could be due to tariffs... likely... due to tariffs , hard to say if your price is good...
  9. Mmm
    Mmm New Member
    60Coins
    Thanks man. I'll crunch the numbers and hopefully pull the trigger soon .
  10. Kenshiro27
    Kenshiro27 Active Member
    252Coins
    2DOF, 3DOF, Arduino
    Another very nice project on this site, lots of homemade items, beautiful work!
  11. tadeusz
    tadeusz New Member
    28Coins
    Hi
    Very cool project.
    Probably the best way to control the servos.
    I have a question: can I use this setup for a 3 DOF platform like the one in the picture?
  12. knaufinator
    Simulation Engineer
    akron,ohio
    1,920Coins
    AC motor, 6DOF
    This has been asked before, the logic is setup for 6 motors, it would take a rewrite of the inverse kinematic algorithm in order to support, i have not looked into actually doing this, but should be possible if you like to tinker in code.
  13. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    Hi!
    That's quite a machine. Impressive work. Remarkable fluidity of movement. Great simulation!
  14. X.STTONER
    X.STTONER Sttoner
    business manager
    lima
    152Coins
    2DOF, 3DOF, DC motor, AC motor, Arduino, Motion platform, 4DOF
    excellent work congratulations
