SimTools v3 Public Beta
  1. lysa elec
    lysa elec LYSA ELEC
    16Coins
    can you help me thanks ,
  2. notfasteddy
    notfasteddy New Member
    42Coins
    Pretty new to Simtools and having a few issues. I have looked in what I thought were the relevant threads but could do with some guidance.
    I have a 2DOF rig and got it running with simtools on LFS. However settings in the tuning center do not stay saved.
    I then changed to MSFS 2024 which is why I built the rig in the first place.
    Now I am having different problems. I posted in the MSFS 2024 thread but Noorbeast suggested I post the issues here as the maybe related to simtools v3 beta, see here: https://xsimulator.net/community/threads/msfs-2024-plugin.19114/page-2#post-259311
    Firstly I cannot exit simtools the normal way, I need to use task manger everytime to shut it down it seems to keep running in the background.
    But my main issue now is that I cannot get the MSFS 2024 plugin to run my rig. Works ok on LFS but in MSFS the rig starts up but none of the controls make any movements, I can see the yoke moving on the screen and the numbers moving (randomly) on the input line of tuning centre in capture mode but nothing moves.
    I posted all setting in the MSFS thread but can do so again here if required.
    Saving settings also does not work as well in MSFS
    I also had a number of windows crashes when in capture mode with MSFS running.
    Appreciate any assistance.
  3. lysa elec
    lysa elec LYSA ELEC
    16Coins
    i have allways the problem
    In the options menu, every time I check "open automatically with game launchers," the box is unchecked every time I restart my computer.
    What's happening?
  4. notfasteddy
    42Coins
    Just a short update on my issues with MSFS2024. I seem to have resolved the crashes as they are related to the AMD Raedon driver setting after an update.
    Other issues running with SIMtools as mentioned before still exist although I am trying other things.
  5. yvsbvn
    yvsbvn New Member Gold Contributor
    - 329Coins
    3DOF, SCN5, SCN6
    I use Simtools V3. The Dirt 3 plugin does not seem to allow the use of Dirt 3 Complete Edition. When the plugin starts, it redirects to a base version of Dirt 3 that is not installed on my PC. This base version no longer works and has been replaced by the complete version. Selecting the directory containing the game's executable file still prompts for the installation of the base version of the game.
    C:\Program Files (x86)\Steam\steamapps\common\DiRT 3 Complete Edition.
    Any ideas on how to fix this?
    Thank you!
  6. X.STTONER
    X.STTONER Sttoner
    business manager
    lima
    232Coins
    2DOF, 3DOF, DC motor, AC motor, Arduino, Motion platform, 4DOF
    Hi, I have a question. I've checked the posts and it seems the DIY license can be used in version v3, but there were some issues.
    My question is, have these problems been resolved?
    If I use my license in v3, will I be able to continue using it in v2?
    153,824Coins
    +11,150 / 57 / -2
    Specifically what problems are you referring to?
    If there are any problems experienced then post them and related details to this thread for resolution.
    You can install both v2 and v3 on the same computer using the same license.
  8. 204flightsinmotion
    204flightsinmotion Member
    227Coins
    So I have my rig all setup and testing properly in smc3. I build a motorcycle sim with an actual Kawasaki ninja. When I play motogp18 for some reason whenever I get into a crash or even bang a wall and don’t even crash the motors start pulsing and don’t stop I have to unplug the arduino usb to fix it. Super frustrating. I’ve tried putting crash detection on disable as well as turning it on with the same outcome. Any assistance appreciated
  9. notfasteddy
    42Coins
    Following on from my previous post. I reinstalled Simtools V3 beta and reconfigured my rig and FS2024 now works with my rig.
    However as mentioned before my configuration settings on max min tuning do not save in either LFS or FS2024 which means I have to reset them every time before I use the sim.
    Ed
  10. kalbasator
    kalbasator Active Member
    Kazahstan, Almaty
    170Coins
    3DOF, DC motor, Arduino, Motion platform, 4DOF
    Hi! I have a question about parking mode:
    For example, I completed a special stage in Dirt Rally 2.0.
    Then my friend wants to complete the same special stage. What will the Sim Rig do after completing the special stage? Will it enter parking mode?
    So I can easily exit the Sim Rig and free it up for my friend...
    Or does parking only work when I exit the game?
