FlyPT Mover 3.5.3
  1. pmvcda
    15,666Coins
    Try to change the USB port on the pc for one of the Arduinos
    Some usb ports share the same bus and might be saturated. That's strange, because this would be a problem in old hardware, not what we have today.
    You could try the latest build to see if this works better.
    Download here: https://github.com/FlyPTMover/Releases
    Setup is not compatible, you have to make a new one and I will have a new build this week (2 more days)
  2. Andrey Av
    Andrey Av New Member
    63Coins
    I still don't see some controls even with scaling.
    Do you have any plan when you are going to update the Rotating 2DOF rig?
    Thanks.
  3. Selfsimmer
    Selfsimmer New Member
    24Coins
    Thanks again for your help.
    There is some progress and maybe now there is more useful information.
    I was able to get it all to work... but then one set of motors stopped responding after about 10 seconds. I don't get any errors on the screen. Also no errors on the drivers which are connected to the motors.
  4. pmvcda
    15,666Coins
    Next release It's done, but need to solve some bugs in the Recorder/Player, I'm in the middle of that one...
    Hope to have it tomorrow.
  5. Erik Green
    Erik Green Member
    365Coins
    After an afternoon of searching I'm still sort of stumped. FlyPT is pretty easy to integrate with Thanos or M4S boards. What i need to do is control a single BLDC with a Direct output from FlyPT. Is there a motor controller such as the VESC Minim Odrive etc. that can accept the serial stream from Mover and output a proportional torque? If not I assume I need to have an interface board between mover and my driver?
  6. Andrey Av
    63Coins
    Updated to 3.7.0.15, rotating 2DOF looks good now.
    Thank you so much!
  7. Andrey Av
    63Coins
    Hi.
    Noticed another small bug in 2DOF rotating rig.
    The L1/L4 tooltips say "distance between two crank/rod joints" but it really draws the distance from the ujoint zero plane to the crank/rod points (and I suspect it calculates that internally the same way).
    It does not cause any issue, I've just entered 0.5x value here.
    Also the Actuators yaw/zero/tilt value fields are shifted up a bit, but it is just a cosmetic issue.
  8. pmvcda
    15,666Coins
    Corrected for next release, L1 and L4 are the distance between rods. You need to change your setup on the next release (no 0.5x)
    sorry
  9. Andrey Av
    63Coins
    No problem at all, will be glad to have it fixed, thank you for your work.
  10. Andrey Av
    63Coins
    Hope I'm not annoying.. )
    Found another a bit more serious bug - the 2DOF rotating rig doesn't save several actuator-related settings:
    Independently on how you set states of these checkboxes and save as a local or a default setup - when you load your setup later they will be in this state.
    Unfortunately I need another state of them so I have to fix it each time I load my config.
    It would be also very good to include into the next release if it is possible, thank you in advance.
  11. Trigen
    Trigen Active Member
    2,878Coins
    Just came back from a year abroad and i had to reinstall due to some errors. I noticed FlyPT_SimTools_to_Mover_InterfacePlugin.dll dosent seem to work with simtools 2.6.1 Not a valid interface plugin. Looks to be the same on 2.5.1
    I need it for traction loss. Any quick fix for this and is a Simtools 3 interface plugin out there somewhere?
