Brake or no Brake on a 80st-m02430 Servo Motor?
Discussion in 'Motor actuators and drivers' started by SpeedyBee, Jul 14, 2024.
  1. SpeedyBee
    SpeedyBee DIY 3DOF, AC Servo Ball Screw Drive
    engineer
    California
    55Coins
    I am building actuators for a 2DOF plus yaw "balanced" rig and am ordering 80st-m02430 Servo Motors and drivers. Is there any reason I might want a motor with a brake. I can see if building a 6 DOF rig where you don't want everything to sag when power is off you might want brakes on your motor, but I don't think I need a brake in my application. Am I missing something? thanks
  2. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,801Coins
    If you want youre balaced rig locked when power is off you need breakes with a free walking gearbox or ballscrew with a self cocking whormgearbox there is no need for a breake
  3. mycncshop
    mycncshop New Member
    48Coins
    DC motor, AC motor, SCN5, SCN6, SimforceGT, Motion platform
    That's a great question. For horizontal movement only, you're right—a brake is likely unnecessary. If there's any vertical component where the load could drop when powered off, then a brake would be a good idea.
  4. Wasa
    Wasa New Member
    64Coins
    I'm not quite sure about this. I'm currently working on Lebois' SRT8O actuators, and I'm looking at several servos with the same characteristics so I can save a little money, but I'm not sure whether or not I need to use a brake for a simulator with four actuators, one in each corner.
  5. Misanthrop
    Misanthrop Active Member
    832Coins
    Everyone uses Motors without Brake. You have to be sure that the Brake is always powered on and this will need additional work.
    The benefit would be, the rig will not fall down when you trigger an short or something and you can use your rig without power on the motors.
