Oasis Drive (Hp Reverb ) and OpenXR or OpenVR MotionCompensation .
Discussion in 'News' started by Flymen, Nov 27, 2025.
  1. Flymen
    Montreal, Canada
    2,470Coins
    DC motor, 6DOF
    Hello everyone!
    @pmvcda
    @SilentChill
    I have HP Reverb G2 headset and recently installed with Oasis Driver.
    My problem is that before updating (Windows 24H2), everything worked fine with SteamVR, but my computer hadn't been updated for a year.
    So I waited until the Oasis Driver came out the spring... and now Oasis driver works very well, but it's not compatible with OpenXR or OpenVR Motion Compensation. I have no communication with it, and the three-colored crosshair doesn't move to center itself with my chair (FlyPT Mover).
    I'm looking for solutions... Am I the only one?
    Solutions:
    1 - Change headsets $$$$
    2 - Revert to a previous version of Windows... no way
    Thanks !
  2. Kenshiro27
    Kenshiro27 Active Member
    179Coins
    2DOF, 3DOF, Arduino
    Hi.
    Just like you, I'm stuck with an HP G2 sink because of the Windows update. I switched to the Quest 3 to avoid the hassle, but I really liked my G2. Good luck.
  3. Hobbs77
    Hobbs77 Active Member
    Connecticut, USA
    875Coins
    2DOF, SCN5
    I also have the hp reverb g2.... updated pc from win10 to win11 24h2 mid sept after oasis driver release and have had no problems with any of it.
  4. Kenshiro27
    179Coins
    2DOF, 3DOF, Arduino
    I also installed Oasis and it works, which is great because it's the nicest headset to wear: light and comfortable. However, I can't connect the controllers.
  5. Flymen
    Montreal, Canada
    2,470Coins
    DC motor, 6DOF
    The controller are bluetooth now !
    https://steamcommunity.com/app/3824490
  6. Flymen
    Montreal, Canada
    2,470Coins
    DC motor, 6DOF
    Oasis work very well !! the problem is the Motion with 3 axe , ( sway , Surge and Heave ) others are ok !!
  7. Kenshiro27
    179Coins
    2DOF, 3DOF, Arduino
    Hi! Thanks so much for this link! Nice!
  8. Flymen
    Montreal, Canada
    2,470Coins
    DC motor, 6DOF
  9. Flymen
    Montreal, Canada
    2,470Coins
    DC motor, 6DOF
    @Wagnard
    @pmvcda
    @SilentChill
    Good news for HP reverb with Oasis drive !
    Mr. Wagnard, from Canada (Quebec), shop.wagnardsoft.com, has released a new version OpenVR-MotionCompensation with this fix.
    Merci !!!hug:
    For now, you must only use the controller as your reference tracker, because after some testing, FlyPT Mover tracker (with the red and blue cross) doesn't seem to work.
    You must disable your antivirus software to download the link.
    https://www.wagnardsoft.com/OpenVR-MotionCompensation_0_3_8.exe
