SimTools v3 Assetto Corsa Rally Plugin
Discussion in 'SimTools Plugins' started by yobuddy, Nov 19, 2025 at 01:49.
  1. yobuddy
    51,295Coins
    Plugin Posted! :thumbs
    • Winner Winner x 3
    152,659Coins
    +11,103 / 56 / -2
    Not long...all done :thumbs
    Ours is an awesome collective community!
  3. Hobbs77
    Hobbs77 Active Member
    Connecticut, USA
    869Coins
    2DOF, SCN5
    Thanks yobuddy.....It's a completely different game having motion!:cheers
  4. Titobial
    Titobial Member
    Zaragoza
    59Coins
    Hello. Does the plugin have the correct effects? Pich or roll does not correspond to the forces applied. Has it happened to anyone? Thank you!
  5. Ralf Nass
    Ralf Nass New Member Gold Contributor
    13Coins
    Motion platform
    Did you manage to download the V3 plugin? from where? I cannot find it and in the simtools application doesn't appear in the plugin manager window
  6. Hobbs77
    Connecticut, USA
    869Coins
    2DOF, SCN5
    It should be the first one in the second row of plugins, I believe.
  7. Hobbs77
    Connecticut, USA
    869Coins
    2DOF, SCN5
    Do you have the inputs setup correctly? Do they work properly in test mode?
  8. Titobial
    Titobial Member
    Zaragoza
    59Coins
    Hello! Well that's what I'm trying to do. But with my other configurations of other games, it works well for me. (each force with its effect). There is no way here...‍♂️ Because the test mode, how do you do it? thank you!
  9. Hobbs77
    Connecticut, USA
    869Coins
    2DOF, SCN5
    What motion version are you using? If you're using v3.... Download the user manual SimTools-v3.pdf
  10. Nailson Roveta
    Nailson Roveta New Member
    4Coins
    I installed the plugin (Version 3) and only Yaw and traction loss work here. I installed it the same way I installed the other games and they all work perfectly. Do you have any special tips? Thanks.
  11. Nailson Roveta
    4Coins
    I found the problem. I'll leave this document because it might help someone with my inexperience. Now everything is working. The problem was in the Min/Max Tuning tab; the Surge values were too high. I repeated what I use in Asset Corsa and now everything is working. Cheers.
  12. Hobbs77
    Connecticut, USA
    869Coins
    2DOF, SCN5
    The best tip I can give anyone is to read the v3 manual. :!
  13. Joao Costa
    Joao Costa New Member
    18Coins
    Hi, first, thanks for the great work that you guys have done here.
    • I tested this new v3 plugin, and some feeback
    • I have little few details from it, need to increase a lot the axis range to actually feel anything
    • Surge seems not working
    • Vibe is also not working for rpm at least
    I have some experience using simtools, and to be honest doesn't seems a configuration issue, but could be something that a miss somewhere. Anyone here is experiencing similar issues?
  14. Nailson Roveta
    4Coins
    :thumbs
  15. Nailson Roveta
    4Coins
    I think it's the same problem I had. See my post above. Cheers.
  16. Nailson Roveta
    4Coins
  17. Titobial
    Titobial Member
    Zaragoza
    59Coins
    Hello! I can't find the Assetto corsa rally plugin for version 3. Not even the repository. Can anyone guide me or send me the link? Thank you in advance!
  18. Ralf Nass
    13Coins
    Motion platform
    https://simtools.us/plugin_library/
  19. Titobial
    Titobial Member
    Zaragoza
    59Coins
  20. Joao Costa
    18Coins
    yes but limits are fine. the current values that i saw in that table are very low, close to 0
