SimTools v3 Public Beta
  1. pasquereau
    pasquereau New Member Gold Contributor
    6Coins
    Scn6 for traction loss
  2. Tino.Sturlic
    Tino.Sturlic Member Gold Contributor
    199Coins
    Hello all,
    I am trying to switch to Simtools 3.
    Installed it on a laptop (windows 11) so I can copy all settings from my main rig and test before the transition.
    I have MDBOX interface. Installed the plugin, selected the right port. Windows is detecting interface as USB serial port.
    When I hit "Test Settings" I get error: "unable to start interface"
    Whatever I do, I cannot get it to move the actuators. Any help would be appreciated.
    153,884Coins
    +11,154 / 57 / -2
    Perhaps others have more up to date information but my understanding, based on the advice of @Thanos, is that unfortunately the Syntron MDBOX protocol is unknown, instead the recommended replacement is the AASD-15A servos with the AMC-AASD15A motion controller: https://www.xsimulator.net/community/threads/how-to-interface-an-sc-mbox-v3.17113/#post-228753
    You can check that alternative out in the FAQs:
    https://www.xsimulator.net/community/faq/amc-aasd15a-servo-controller.351/
  4. Tino.Sturlic
    199Coins
    I think something was misunderstood. I am not trying to connect to Syntron drive.
    I have Thanos interface in between. The setup was working but sometimes I would have to restart Simtools couple of times for it to start and occasionally the motion would just stop.
    I was having a problem with interface not wanting to start like from the first day I bought it. Sometimes I would have to restart Simtools 5 times or so for it to start. It was becoming worse and worse and now I cannot start motion at all. Note that I have second interface that is behaving exactly the same way, so I doubt it's a hardware issue with the interface itself.
    This is why I finally decided to move to windows 11, as I believe (hope) this is a software issue inside windows.
    153,884Coins
    +11,154 / 57 / -2
    As there are a number of them do you mean the @Thanos AMC1280USB Motion Simulator Controller: https://www.xsimulator.net/community/faq/amc1280usb-motion-simulator-controller.336/
  6. Tino.Sturlic
    199Coins
    Here is a picture of the one I have. I do not know the exact marking.
  7. Tino.Sturlic
    199Coins
    Can anybody help with my issue? :(
    153,884Coins
    +11,154 / 57 / -2
    Hopefully @Thanos will chime in when he has a spare moment.
  9. kiennt
    kiennt New Member
    - 70Coins
    4DOF
    Hello everyone, I'm having a problem connecting SimTool v3 to the game Forza Horizon 4. I've already set up the port, but my simulator rig is not working. Other games work and function normally. Please help me
    NOTE: Currently, all the other games I have installed are working normally, except for Forza Horizon 4 which isn't recognizing DOF. Specifically, in the SimTools interface, I see a green wifi-signal-like icon for FH4, which is not the case for other games. Additionally, I am playing the Microsoft Store version of FH4, not the Steam version. Thanks, everyone
  10. yobuddy
    51,535Coins
    You don't need the UDP Relay set up at all, unless you need to send a copy of the games data to other software. Know that sending the data back to 4123 will create a endless loop. Please remove the UDP relay and give it a go.
  11. Racer54098
    Racer54098 New Member
    105Coins
    Motion platform, 4DOF
    Raceroom Racing Experience has been many main sim for a long time. I works really well with my simrig and SimTools. Now it's getting an update, hence this post. I really hope RRRE plugin will get an update, which obviously is needed.
    Upcoming Changes to RaceRoom’s Shared Memory API – September 24th Update
    "On September 24, 2025, RaceRoom will receive a major update that introduces fixes and improvements to the shared memory API [...] the shared memory block will no longer be backward compatible. This means that third-party apps, dashboards, motion rigs, and other tools that rely on the shared memory API will stop working correctly unless they are updated.
    If you are an app developer using RaceRoom’s shared memory interface:
    • The documentation and a sample program can be found here: RaceRoom Shared Memory API on GitHub
    • To help with the transition, we can provide early access to a game build that includes the updated shared memory structure. If you would like access, please join our discord and head over to the #Apps channel where you also can participate in the conversation and submit your own wishes and requirements for further modifications of our API.
    We encourage all developers to update their tools ahead of the September 24th release to ensure a smooth experience for their users."
    LINK TO THE NEWS POST
    I hope this is the right place to share this news.
  12. VFX Pro
    VFX Pro Member
    Los Angeles
    431Coins
    Motion platform, 6DOF
  13. VFX Pro
    VFX Pro Member
    Los Angeles
    431Coins
    Crap, just noticed someone beat me to it... sorry for the duplicated post.
  14. yobuddy
    51,535Coins
    Thanks guys for the heads up :thumbs.
    I will start an update to the plugin tomorrow morning, as soon as we get access to the updated game.
    Chat soon!
  15. kiennt
    kiennt New Member
    - 70Coins
    4DOF
    Hello, should I delete the current plugin and reinstall it? After installation, should I test it in the game right away without needing to add any information in the port section on SimTool?
  16. yobuddy
    51,535Coins
    You will not want to use the port relay settings for the game, please click reset and close the UDP relaying form.
    Take a look at the data page for the plugin, as it shows some in game settings that need to be done.
    https://simtools.us/plugin/?varname=388&color=0e97dd
    Please let me know how it goes!
  17. VFX Pro
    VFX Pro Member
    Los Angeles
    431Coins
    Thanks for looking into it and good luck making the plugin work with the new API. I'm dying to get back on my motion rig using RRE :)
    • Optimistic Optimistic x 1
  18. Racer54098
    105Coins
    Same here. I've been racing only Raceroom this years, it has been amazing. I come from AMS2, and nowadays, I don't open any other simulator than Raceroom, as it is such a well-balanced package and works well with my motion sim. Can't wait to get back in.
    I had a little problems with jerky/sharp movements but I believe I found a reason for it. Roll rate and Pitch rate were high because of capturing data but after I lowered those rates to one digits (like 3-4), motion works really well. I have a RacingCUBE.
    It was a really challenging problem. There were clattering noises coming from the simulator, while driving straight on a flat part of the circuit, or turning only slightly. I didn't understand why. But when I made one last change and reduced the roll/pitch rates (70->3), the situation changed for much better. After that it was a joy to drive in Raceroom.
  19. Josemanuelrm
    Josemanuelrm New Member
    valencia
    65Coins
    Hi, I wanted to ask. I currently have Forza Motorsport, and the 2DOF simulator movements don't match the car... it jerks around for no reason. However, I have the same settings in F1 2024 and Aseto Corsa, and they work fine.
    I have the settings in SimTools v3, where I move the axes, and they work fine, but they don't work in the game. Has something similar happened to you?
    thanks
    153,884Coins
    +11,154 / 57 / -2
    Has the required in-game settings been made:
