SimTools v3 Public Beta
  1. FLORIN ROMANIA
    FLORIN ROMANIA Member
    România
    810Coins
    Rpm number I tried several settings, but I couldn't get it to work correctly at all, I also tried assetto corsa, grid, grid legends but with these it crashes and simtools closes
  2. yobuddy
    51,532Coins
    PM sent...
  3. james wheeler
    - 143Coins
    So I've been using v1.2 for a long time. But wanted to upgrade to v3. However after downloading the demo of both v3 and live4speed to test with, as well as all required plugins. I have run into an issue.
    I use the server interface and copied the setup from my v1.2
    Then set up just a pitch dof with only 25 % force and 25 boundary to play it safe.
    With the power off I downloaded the slider plugin to check the virtual axis. When it looked good I powered on the seat. Once I hit the test button my seat goes all the way forward and tries to pass my physical safety stops.
    I exited v3 and tried the seat again using v1.2 to rule a seat problem out however it operates as it should so that leads me to believe I am doing something wrong or the program has a fundental difference in the interface setting.
    What might it be?
    153,830Coins
    +11,151 / 57 / -2
    Please post pictures of your Interface Settings, as the format has changed long ago.
    Please see the:
    QuickStart Guide:
    https://simtools.us/wp-content/uploads/2024/02/QuickStart-Guide-for-SimTools3.pdf
    And
    SimTools v3 Manual:
    https://simtools.us/wp-content/uploads/2024/02/SimTools-v3.pdf
  5. james wheeler
    - 143Coins
    They are the same. Is my problem that I didn't put an "a" behind the axis?
    153,830Coins
    +11,151 / 57 / -2
  7. deeph46
    deeph46 Member
    641Coins
    2DOF, 3DOF
    Hi Yobuddy,
    Just wondering, any update on the RC-Rider?
  8. Jokester323
    Jokester323 New Member
    33Coins
    Hello so im getting an error saying
    DEBUG error!
    Program: J:\Simtools3\wow64ext.dll
    Module:J:\Simtools3\wow64ext.dll
    File:
    Runtime check failure #3 - the variable 'basicaddrrss64' is being used without being initialized l.
  9. Adrianstealth
    Adrianstealth Active Member
    director
    england
    160Coins
    SCN6, 4DOF
    Appolgies for sounding a bit dense
    Cannot get this to work
    Simtools v3. New install new PC etc
    All ok at Simtools v3 startup scn6 actuators move etc & now fine under testing
    Simtools v3 downloaded the msfs2020 within Simtools v3 plugins selection
    The mafs2029 plug in clicked twice does start mafs2020 but zero motion
    I’ve assigned basic axis pitch roll now turned up but zero movement
    msfs2020 does run motion when I try using sim commander software so it does output but sim commander not great for flight sims
    any ideas of how to get it to work ?
  10. Adrianstealth
    director
    england
    160Coins
    SCN6, 4DOF
    Has anyone got msfs2020 to work with Simtools 3 ????
  11. yobuddy
    51,532Coins
    We have collected all the parts we need for the project, and have tested a few things too. We hope to get a working version out this fall.
    This usually comes down to the version of Sim-connect your using. My guess is Sim Commander uses a different version is all. Please check your add/remove files in windows to see how many versions you have installed.
  12. Adrianstealth
    director
    england
    160Coins
    SCN6, 4DOF
    Working now thanks
    but cannot get the msfs2020 plug in to work
    Simtools 3 & installed msfs2020 plug in through the Simtools 3 interface
    the sadness is sapping my Will
  13. Adrianstealth
    director
    england
    160Coins
    SCN6, 4DOF
    just tried it with ams2 , simtools not receiving input from the games
    all the motion works when i test actutors and adjust park postions etc
    yes i put in some pitch roll etc into the first 2 axis, the ones that are working and simetools 3 activate at start up
    simetools 3 successfully starts the game from pressing the plugin twice etc
    is there something I've missed out???????????????????????????????????????????????????????????????????
    153,830Coins
    +11,151 / 57 / -2
  15. Adrianstealth
    director
    england
    160Coins
    SCN6, 4DOF
    Here
    massive thanks for reply
    interface one ( com 6 ) axis 1a
    Interface two (com 5 ) axis 2a
    bott work nicely at startup
    +on the test mode they move no probs
    zero movement in game
    Simtools 3 boots up/starts the game no problem , tested with msfs2020 & ams2
    Both completely dead motion
    frustrating
    Any suggestions appreciated
  16. yobuddy
    51,532Coins
    I suggest turning the speed and acceleration on the interface config all the way up while your setting up the rig, and setting the output rate to 1. The last thing to check for is what the min/max settings look like for ams2. (If for any reason the min/max values got zeroed out for the plugin, then there will be no motion)
  17. Adrianstealth
    director
    england
    160Coins
    SCN6, 4DOF
    thanks yobuddy
    nope none of things worked
    I tried output of 1 on each axis then 2 , 3 , 4 , 10
    the min max I fiddled and put different figures in
    nothing shows in those “input” boxes above isn’t that a life feed from the sim ?
    I pressed capture too but nothing showed in those boxes , all whilst msfs2020 was running with a plane flying
    zero movement
    there’s nothing coming from each sim
    I know my setup works with everything including ams2 & mafs2020 using sim commander software so I know not a hardware or connection to pc issue
    Is my somehow blocking the feed from sim to Simtools 3 ?
  18. Adrianstealth
    director
    england
    160Coins
    SCN6, 4DOF
    It’s a new pc with clean install of windows 10 & working with everything else great , VR etc
    is simtools V3 not working because I’m using windows 10 maybe ? ???????
    PS i have one drive switched off if that makes any difference
    is there any patching I need to do in the game(s) so simtools v3 supplies physical motion ?
  19. deeph46
    deeph46 Member
    641Coins
    2DOF, 3DOF
    Nice!!, looking forward for the updates
  20. Adrianstealth
    director
    england
    160Coins
    SCN6, 4DOF
    AMS2 now working
    my problem is msfs2020 specific
    Zero feed to motion )-:
