ESP32 SMC3
Discussion in 'DIY Motion Simulator Projects' started by azizalfirdaus, May 23, 2025.
Tags:
  1. azizalfirdaus
    azizalfirdaus New Member
    1Coins
    Hello I'm from Indonesia and i excited to join this community and share my journey with motion simulation. I'm relatively new to sim racing but have been diving deep into the technical side of things.
    About 4 months ago, I purchased a 2DOF platform + Traction Loss system from my friend . I have to be honest - I'm terrible with mechanical stuff! While my friend could fabricate alumunium profile and adjust DC motre with ease, I struggled with even basic mechanical adjustments.
    The platform came with the classic Arduino UNO + SMC3 setup, and initially, everything worked great with SMC3Utils. However, as I started diving deeper into tuning and understanding the system, I began to notice some limitations of the UNO platform:
    This got me thinking: "What if we could run SMC3 on ESP32?" The ESP32 have 240MHz dual-core processor vs UNO's 16MHz, 4MB flash memory vs UNO's 32KB
    I am not good at coding, I can only make the LED turn off or on, LOL. So thanks to Claude AI, I understand a little more about what C++ is.
    But here's where the 3-month journey of frustration began...
    I started by trying to port the SMC3 code directly, thinking "ESP32 is just a faster Arduino", and immediately asked Claude AI to convert the original code, but I immediately ran into a lot of problems:
    • SMC3Utils couldn't communicate properly
    • Feedback logic is different because esp32 uses 3.3v
    • PWM signals were wrong
    • Timing was completely off
    • Direct timer manipulation: Too complex and unreliable
    • Motors behaved erratically
    • Legacy analogWrite(): Limited functionality
    • LEDC PWM: Too different from UNO's timer behavior
    • MCPWM API: Powerful but initially confusing
    The breakthrough came when I stopped trying to make ESP32 "better" than UNO and focused on making it behaviorally identical. Key realizations:
    1. Preserve UNO's 0-1023 ADC range by mapping ESP32's 12-bit to 10-bit
    2. Maintain exact 250µs loop timing that SMC3 depends on
    3. Emulate UNO timer limitations rather than "improving" them
    4. Focus on behavioral compatibility, not hardware similarity
    The Final Solution
    After 3 months of experimentation, I achieved 100% behavioral compatibility:
    • SMC3Utils works identically to UNO version
    • All existing parameter sets transfer directly
    • Same PID response characteristics
    • Drop-in replacement capability
    I now have a working ESP32 SMC3 firmware that maintains full backward compatibility. And I've only been able to test it on my specific setup (Cytron drivers in the new MODE_CYTRON).
    I need your help, please test this firmware in mode 1 or 2 and please give me feedback. or maybe you want to try to develop this firmware yourself with AI then discuss it here, because it seems like it still needs a lot of features like filters, anti-haunting, soft start, etc. 107402 2.png 3.png
  2. azizalfirdaus
    1Coins
    • Winner Winner x 4
  3. Thick8
    Thick8 Just some random guy
    South Carolina USA
    321Coins
    3DOF, DC motor
    Can an ESP32 drive 3 or 6 motors at 20Khz? Or does it suffer the same issues as an Uno?
  4. Joe Cortexian
    1,087Coins
    The bulk of the time in the PID loop is spent on analog input processing. Additionally, an Arduino Uno lacks sufficient pins to handle six axes, so you would need a Mega (or similar microcontroller) to provide enough I/O for six motors. This is why using two Unos for six axes is a practical solution.
    Regarding the 4 kHz loop speed, consider what this means. Assuming a geared motor (not a lead screw), let’s estimate a top speed of 60 RPM, which translates to 1024 counts per revolution × 60 revolutions per minute ÷ 60 seconds = 1024 counts per second. According to the Nyquist-Shannon sampling theorem, to accurately reconstruct a signal, you should sample at least twice its highest frequency, or 2 kHz in this case. A 4 kHz sampling rate is sufficient even if the motor runs at 120 RPM (2048 counts per second), which is likely beyond its typical operating range. Thus, a 4 kHz PID loop provides ample performance for this application.
    This is not to say that the SMC code doesn’t have issues. A bug in the PID calculation was recently resolved and if you don’t have that fix you are missing out.
  5. Thick8
    South Carolina USA
    321Coins
    3DOF, DC motor
    Thank you. This information is very helpful. So the real consideration for the PWM is noise. My wife can hear the motor whine up to 16Khz so I run them at 25Khz. It would be nice to have all 6 run at that speed on 1 board. I've ordered an ESP32 board to test this ino file on my P3 rig.
  6. Gadget999
    12,007Coins
    it uno is fast enough for reading a potentiometer
    just use 2 or 3 for more axis
    cheap and simple
  7. azizalfirdaus
    1Coins
    With a lot of resources from ESP32 I'm developing the auto tune feature to setup all parameters in smc3, so we don't have to bother to set it, whatever your platform configuration should be able to set it automatically, but this is not perfect wait for it to be really stable then I will share it here
  8. azizalfirdaus
    1Coins
    Look at the end of the video when I close and reopen smc3utils, all parameters have changed
  9. Joe Cortexian
    1,087Coins
    . Looks promising. Is there a mathematical basis for this or does it basically search for the parameters like an optometrist looking for the best prescription ?
    Maybe stick on GitHub to share it.
  10. Thick8
    South Carolina USA
    321Coins
    3DOF, DC motor
    I've downloaded your sketch to an Arduino Nano. Using a DR P3 rig with IBT-2 boards. So mode 2. I need to wire it into the control box. May be able to do it today. I'll let you know how it works. HAve you tried using Klaus Schmidinger's version 2.1 with parking and soft stop as the base for you sketch?
    EDIT: SMC3 is not seeing the Nano. I used USBDeview to verify the board is recognized. When I plug it in, USBDview shows that it's connected for a moment, then it disconnects. Thoughts?
  11. Joe Cortexian
    1,087Coins
    Overview
    The Arduino Nano ESP32 and the classic Arduino Nano are distinct boards with different capabilities. The Nano ESP32 combines the familiar Nano form factor with the powerful ESP32-S3 chip, offering Wi-Fi and Bluetooth capabilities, more processing power, and memory compared to the classic Nano. However, the classic Nano, based on the ATmega328P, remains a simpler, more power-efficient option for basic projects and educational purposes.
  12. Thick8
    South Carolina USA
    321Coins
    3DOF, DC motor
    Oops. Guess I should have specified that I bought the Nano ESP32.
  13. azizalfirdaus
    1Coins
    I am adding some features from the members here, wait until I am sure this is really stable. upload_2025-6-16_20-26-33.png
  14. azizalfirdaus
    1Coins
    I don't have a github account, I just try to explore Claude AI, so I determine the work logic flow and Claude AI is the one who completely writes this code, then I correct it
    This is my auto tuning algorithm, so basically it analyzes the relationship between the feedback targets by defining parameter limits such as response time, overshoot, Oscillation Count, PWM Utilization Analysis.
    This is Decision Logic Flow
    Step Response Test => Calculate Metrics (Response Time, Overshoot, Oscillations, Precision) => Performance Scoring (Speed, Smoothness, Stability, Precision) => Strategy Selection (Conservative vs Aggressive) => Parameter Adjustment (Within Adaptive Bounds) => Validation & Relationship Check => Apply to Motor & Send to SMC3Utils
    Strategy Selection (Conservative vs Aggressive) has not been implemented well in this code.
  15. azizalfirdaus
    1Coins
    00:27:09.255 -> > tm1
    00:27:09.255 -> Manual trigger: Motor 1 auto-tuning
    00:27:09.255 -> Starting Motor 1 auto-tuning...
    00:27:09.255 -> Adaptive bounds calculated
    00:27:09.255 -> Kp: 80-280
    00:27:09.255 -> PWMmax: 35-140
    00:27:09.255 ->
    00:27:09.255 -> AUTO-TUNING: Feature Override
    00:27:09.255 -> Anti-hunting temporarily disabled
    00:27:09.255 -> Reason: Prevents error signal corruption
    00:27:09.255 -> Soft start/stop temporarily disabled
    00:27:09.255 -> Reason: Enables clean step response analysis
    00:27:09.255 -> Features will restore after auto-tuning
    00:27:10.257 ->
    00:27:10.257 -> State: INITIALIZING
    00:27:10.257 -> Phase 1: Safety Check & Parameter Validation
    00:27:10.289 -> State: DETECTING_PERIOD
    00:27:10.289 -> Phase 2: Period Detection
    00:27:10.289 -> Initial target: 400
    00:27:15.302 -> Period 1: 2.71s
    00:27:17.954 -> Period 2: 2.72s
    00:27:17.954 -> Period detection complete: 5.43s
    00:27:17.954 -> State: COLLECTING_DATA
    00:27:17.954 -> Phase 3: Data Collection
    00:27:17.954 -> Target period: 5.43s
    00:27:20.423 -> Progress: 0/5 cycles, 50 samples
    00:27:20.730 -> Cycle 1: 624 → 400
    00:27:23.403 -> Progress: 1/5 cycles, 110 samples
    00:27:23.510 -> Cycle 2: 400 → 624
    00:27:26.211 -> Cycle 3: 624 → 400
    00:27:26.345 -> Progress: 3/5 cycles, 170 samples
    00:27:29.160 -> Cycle 4: 400 → 624
    00:27:29.357 -> Progress: 4/5 cycles, 230 samples
    00:27:32.054 -> Cycle 5: 624 → 400
    00:27:32.054 -> Data collection complete
    00:27:32.054 -> Final: 283 samples, 5 cycles
    00:27:32.054 -> State: ANALYZING
    00:27:32.054 -> Phase 4: Analysis
    00:27:32.054 -> === ANALYSIS RESULTS ===
    00:27:32.054 -> Grade: C (55.5%)
    00:27:32.054 -> Stability Index: 0.24
    00:27:32.054 -> Conservative Mode: YES
    00:27:32.054 -> Response: 317ms - TARGET MET
    00:27:32.054 -> Overshoot: 20.8% - NEEDS WORK
    00:27:32.054 -> Oscillations: 118 - NEEDS WORK
    00:27:32.054 -> Precision: 14.0 counts - NEEDS WORK
    00:27:32.054 -> ===========================
    00:27:32.054 -> State: OPTIMIZING
    00:27:32.054 -> Phase 5: Parameter Optimization
    00:27:32.054 -> Current grade: C
    00:27:32.054 -> Stability index: 0.24
    00:27:32.054 -> Applying conservative optimization (stability-first)
    00:27:32.054 -> === OPTIMIZED PARAMETERS ===
    00:27:32.054 -> Motor 1
    00:27:32.054 -> PID: Kp=89 Ki=4 Kd=17 Ks=3
    00:27:32.054 -> PWM: Min=18 Max=70 Rev=80
    00:27:32.054 -> Control: Deadzone=6
    00:27:32.054 -> Changes made: 8 parameters
    00:27:32.054 -> ===============================
    00:27:32.054 -> === BEFORE/AFTER COMPARISON ===
    00:27:32.054 -> Parameter | Before | After | Change
    00:27:32.054 -> ----------|--------|-------|--------
    00:27:32.054 -> Kp | 140 | 89 | -51
    00:27:32.054 -> Ki | 4 | 4 | 0
    00:27:32.054 -> Kd | 0 | 17 | +17
    00:27:32.054 -> Ks | 3 | 3 | 0
    00:27:32.054 -> PWMmin | 25 | 18 | -7
    00:27:32.054 -> PWMmax | 70 | 70 | 0
    00:27:32.054 -> PWMrev | 80 | 80 | 0
    00:27:32.054 -> Deadzone | 0 | 6 | +6
    00:27:32.054 -> =====================================
    00:27:32.054 -> State: VALIDATING
    00:27:32.985 -> State: COMPLETING
    00:27:33.021 -> Copying Motor 1 → Motor 2
    00:27:33.021 ->
    00:27:33.021 -> AUTO-TUNING: Restoring User Preferences
    00:27:33.021 -> Anti-hunting restored to enabled
    00:27:33.021 -> Soft start/stop restored to enabled
    00:27:33.021 -> All features restored to user preferences
    00:27:33.021 -> System ready with optimized parameters
    00:27:33.021 ->
    00:27:33.021 -> === AUTO-TUNING COMPLETE ===
    00:27:33.021 -> Parameters saved to EEPROM
    00:27:33.021 -> System ready - Enhanced performance
    00:27:33.021 -> ===========================
    00:27:34.239 -> State: IDLE
  16. Shibaracing
    Shibaracing New Member
    6Coins
    Nice work! I was building a esp32s3 controller for servo motor, feel much simple.
  17. Thick8
    South Carolina USA
    321Coins
    3DOF, DC motor
    I'm going to test this on my rig tomorrow and let you know.
