Question Trying to run AC Servo with Arduino (code help)
Discussion in 'New users start here - FAQ' started by arda057, Apr 20, 2025.
  1. arda057
    arda057 New Member
    12Coins
    2DOF, AC motor, Arduino
    Hi all,
    In this forum there is a great tutorial for 2 RC Servo to get started. As a newbie i cannot share the link but i'm copy-paste the tutorial content.
    I set the Surge 50% Sway 50% for both axis in simtools with the above RCModelSimToolsMode.ino and everything works fine with the LFS.
    Code for RCModelSimToolsMode.ino
    Code:
    // RC Model Servo
    // Original code By EAOROBBIE (Robert Lindsay)
    // Completely mangled by aarondc
    // For free use for Sim Tool Motion Software
    #include <Servo.h>
    //#define DEBUG 1                                    // comment out this line to remove debuggin Serial.print lines
    const int kActuatorCount = 2;                       // how many Actuators we are handling
    // the letters ("names") sent from Sim Tools to identify each actuator
    // NB: the order of the letters here determines the order of the remaining constants kPins and kActuatorScale
    const char kActuatorName[kActuatorCount] = { 'R', 'L' };
    const int kPins[kActuatorCount] = {4, 5};                       // pins to which the Actuators are attached
    const int kActuatorScale[kActuatorCount][2] = { { 0, 179 } ,    // Right Actuator scaling
                                                    { 179, 0 }      // Left side Actuator scaling
    const char kEOL = '~';                              // End of Line - the delimiter for our acutator values
    const int kMaxCharCount = 3;                        // some insurance...
    Servo actuatorSet[kActuatorCount];                  // our array of Actuators
    int actuatorPosition[kActuatorCount] = {90, 90};    // current Actuator positions, initialised to 90
    int currentActuator;                                // keep track of the current Actuator being read in from serial port
    int valueCharCount = 0;                             // how many value characters have we read (must be less than kMaxCharCount!!
    // set up some states for our state machine
    // psReadActuator = next character from serial port tells us the Actuator
    // psReadValue = next 3 characters from serial port tells us the value
    enum TPortState { psReadActuator, psReadValue };
    TPortState currentState = psReadActuator;
    void setup()
        // attach the Actuators to the pins
        for (int i = 0; i < kActuatorCount; i++)
            actuatorSet[i].attach(kPins[i]);
        // initialise actuator position
            updateActuator(i);
        Serial.begin(9600); // opens serial port at a baud rate of 9600
    void loop()
    // this code only runs when we have serial data available. ie (Serial.available() > 0).
    void serialEvent() {
        char tmpChar;
        int tmpValue;
        while (Serial.available()) {
            // if we're waiting for a Actuator name, grab it here
            if (currentState == psReadActuator) {
                tmpChar = Serial.read();
                // look for our actuator in the array of actuator names we set up
    #ifdef DEBUG
    Serial.print("read in ");
    Serial.println(tmpChar);
    #endif
                for (int i = 0; i < kActuatorCount; i++) {
                    if (tmpChar == kActuatorName[i]) {
    #ifdef DEBUG
    Serial.print("which is actuator ");
    Serial.println(i);
    #endif
                        currentActuator = i;                        // remember which actuator we found
                        currentState = psReadValue;                 // start looking for the Actuator position
                        actuatorPosition[currentActuator] = 0;      // initialise the new position
                        valueCharCount = 0;                         // initialise number of value chars read in
                        break;
            // if we're ready to read in the current Actuator's position data
            if (currentState == psReadValue) {
                while ((valueCharCount < kMaxCharCount) && Serial.available()) {
                    tmpValue = Serial.read();
                    if (tmpValue != kEOL) {
                        tmpValue = tmpValue - 48;
                        if ((tmpValue < 0) || (tmpValue > 9)) tmpValue = 0;
                        actuatorPosition[currentActuator] = actuatorPosition[currentActuator] * 10 + tmpValue;
                        valueCharCount++;
                    else break;
                // if we've read the value delimiter, update the Actuator and start looking for the next Actuator name
                if (tmpValue == kEOL || valueCharCount == kMaxCharCount) {
    #ifdef DEBUG
    Serial.println(actuatorPosition[currentActuator]);
    #endif
                    // scale the new position so the value is between 0 and 179
                    actuatorPosition[currentActuator] = map(actuatorPosition[currentActuator], 0, 255, kActuatorScale[currentActuator][0], kActuatorScale[currentActuator][1]);
    #ifdef DEBUG
    Serial.print("scaled to ");
    #endif
                    updateActuator(currentActuator);
    // write the current Actuator position to the passed in Actuator
    void updateActuator(int thisActuator) {
        actuatorSet[thisActuator].write(actuatorPosition[thisActuator]);
    I want to transition my motion rig from small 9 V RC servos (driven via Servo.h) to full‑blown T3D‑L20A AC servos on an Arduino Uno, under SimTools (LFS).
    I think the only way to run AC from Arduino is using 5V PULS/SIGN pins.
    I’m looking for advice on exactly what changes I need to make—in both driver settings and Arduino code—to get smooth, proportional motion and true return‑to‑center behavior when the user lets go of the throttle or steering.
    Specs: 1KW AC Servo 80AST-A1C04025
    Driver: T3D-L20A-RABF (17 bit Absolute Encoder) (i cannot share the manual link)
    Current Setup
    1. SimTools
      Same as RC Servos.
      Serial @ 9600 baud sends ASCII frames:
      Rxxx~Lyyy~
    2. Ardunio - Driver Setup
      COM+ (pin 31) → 5 V (common anode)
      D2 → PULS+ (pin 25)
      GND → PULS– (pin 9)
      D3 → SIGN+ (pin 24)
      GND → SIGN– (pin 8)
      D4 → DI1/SON (pin 16, active‑LOW enable)
    3. Driver panel parameters
      P‑004 = 1 // Speed control mode
      P‑025 = 3 // Pulse‑speed command source
      P‑035 = 0 // Pulse + direction (default)
      P‑036 = 0 // Normal direction (LOW=CW)
      P‑048 = 0 // Speed command direction
    I'm not good at coding the Arduino either. So i try some code with the AI, like this:
    Code:
      Dual‐AC‐Servo Pulse‐Speed Control for T3D Series
      Prerequisites on each T3D driver (via front panel):
        • P‑004 = 1   // Speed control mode
        • P‑025 = 3   // Pulse‐speed as command source
        • E‑SET       // Save parameters to EEPROM
    #include <Arduino.h>
    // — SimTools parsing (unchanged) —
    volatile int actuatorRaw[kActuatorCount] = {127, 127};
    int currentActuator = -1, valueCharCount = 0;
        char c = Serial.read();
            if (c == kActuatorName[i]) {
              actuatorRaw[i] = 0;
              valueCharCount = 0;
              break;
        else if (currentState == psReadValue) {
          if (c != kEOL && valueCharCount < 3) {
            int d = constrain(c - '0', 0, 9);
            actuatorRaw[currentActuator] = actuatorRaw[currentActuator] * 10 + d;
            valueCharCount++;
          } else {
            actuatorRaw[currentActuator] = constrain(actuatorRaw[currentActuator], 0, 255);
    // — Pin assignments for two drivers —
    const int pulsPin[kActuatorCount]   = { 2, 5 };  // PULS+
    const int dirPin[kActuatorCount]    = { 3, 6 };  // SIGN+
    const int enablePin[kActuatorCount] = { 4, 7 };  // DI1/SON (active LOW)
    // Timing & speed mapping
    const unsigned int PULSE_WIDTH_US = 500;    // minimum ON‐time of each pulse
    const float MAX_RPM = 3000.0;               // driver’s rated speed (r/min)
    const float MAX_FREQ = MAX_RPM * (2500.0*4) / 60.0;
    //   2500*4 pulses per rev for a 17‑bit encoder in QEI = 10000; 10000 * RPM/60 = pulses per second
    unsigned long lastStepTime[kActuatorCount] = {0,0};
    void setup() {
      Serial.begin(9600);
        pinMode(pulsPin[i],   OUTPUT);
        pinMode(dirPin[i],    OUTPUT);
        pinMode(enablePin[i], OUTPUT);
        digitalWrite(pulsPin[i],   HIGH);  // idle HIGH (no pulses)
        digitalWrite(dirPin[i],    LOW);   // default CW = LOW
        digitalWrite(enablePin[i], LOW);   // enable servo (active LOW)
    void loop() {
      unsigned long now = micros();
        int raw = actuatorRaw[i];
        int delta = raw - 127;            // center at 127
        if (abs(delta) < 5) continue;     // dead‑band ±4 units
        // direction pin: LOW = CW, HIGH = CCW (P‑048 = 0 default)
        bool cw = (delta > 0);
        digitalWrite(dirPin[i], cw ? LOW : HIGH);
        // map |delta| (0…128) → 0…MAX_FREQ pulses/sec
        float freq = (abs(delta) / 128.0) * MAX_FREQ;
        if (freq < 1) continue;           // too slow to bother
        // compute interval between pulses
        unsigned long interval = (unsigned long)(1e6 / freq);
        // time to fire next pulse?
        if (now - lastStepTime[i] >= interval) {
          digitalWrite(pulsPin[i], LOW);
          delayMicroseconds(PULSE_WIDTH_US);
          lastStepTime[i] = now;
    Problems
    - Spins at “idle”
    Even raw=127±1 still produces a small delta, so you get a faint pulse rate and drift.
    - Never returns to centre (i guess there is no concept as centre in AC Servos)
    - Too slow and do not respond the Sway or Surge (Responds to Axis1a, Axis2a test in simtools but again too slow)
    I also tried to mapping logic with position mode but no luck in there.
    Basically what i want is achieving same RC Servo code effect with my new AC Servos.
    My main question is: how or where can i learn the AC Servo coding, that's the main problem for me right now.
    Thanks in advance.
  2. Qui
    Qui New Member
    - 154Coins
    Which arduino circuit are you using, uno r3 can control 4 motors with 16bit
