Pointer's wiper-motor simulator project...
Discussion in 'DIY Motion Simulator Projects' started by pointer4, Oct 24, 2009.
  1. pointer4
    pointer4 Member
    Hungary
    276Coins
    New plan,
    enough were from the pneumatics, cannot move gently and fast enough. For a airplane, sure this is the perfect solution. For car, unfortunately not the luckiest one. I spent many super hour in him, but for comfortable usage, i have to rebuild it.
    Thanx for Thanos! :D
  2. pointer4
    pointer4 Member
    Hungary
    276Coins
    Re: Pointer's simulator project...
    i have a basic question :D
    I need this stabilizator only, to prevent the seat left-right rotation? stab.JPG
    Or it has, an other function?
    Because what pivot i use, can't rotate :)
    P1020794.JPG .
    And some updates :)
  3. pointer4
    pointer4 Member
    Hungary
    276Coins
    Next tiny upgrade :D (is on temporary place) with http://www.symprojects.com/
    http://www.youtube.com/watch?v=Bx62rL86nuc&feature=player_embedded
    And a massive wheel holder plan
    Wanek do it for me :D
  4. Frakk
    Frakk Active Member
    328Coins
    Excellent! The second video looks much more fluid and accurate.
    What type of gauge can you control with that RevBurner? In the documentation I only see 1 signal wire. Do you know what type of signal it is?
  5. pointer4
    pointer4 Member
    Hungary
    276Coins
    Any gauge what you found in car tuning shops. (not diesel)
    In a real car, the ignition coil give a saw-signal (i hope my technical translate was understandable). Depends on the number of cylinders. You can switch beetween 4-6-8 cylinder, booth place (software and the RPM gauge).
    And in the software give you a chance to finetune it.
    Watch out, this true only for the tuning components only. The factory meters many times works another way.
    És kapd be, hogy ezt nem bírod MSN-en megkérdezni :p
  6. pointer4
    pointer4 Member
    Hungary
    276Coins
    Almost finish :D
  7. pointer4
    pointer4 Member
    Hungary
    276Coins
    The Hardware is done :D
    http://www.youtube.com/watch?v=Fg_la_IzrZ4
  8. Schnullerbacke
    Schnullerbacke New Member
    Photographer / Videographer
    Germany near Munich
    369Coins
    Hi man,
    excellent work :clap: :thbup: !!! Looks very good.
    Please let me know which size the screens have. I'm planning to set up three screens as well and I want to take 3x 32 FullHD LG. At the moment I'm not sure wether the frames will disturb the feeling of immersion... what do you think about it ?
    I've also got the rpm meter revburner - but at first I will use my SLI Pro. As far as I know, both devices WON'T work together, hmm ?
  9. pointer4
    pointer4 Member
    Hungary
    276Coins
    Thank You! :D
    - This is three 32 FullHD TV, running at Ati Eyefinity (5870). Working good, with 5760*1080 resolution.
    - I was afraid of the frames to, but at the first moment, as if they would not have been there.
    - SLI and REVburner work together, i never saw an any kind of compatible problem. (but i never succeed to start SLI under the LFS, i tryed everything... in EKsim forum a jerk barked me down...)
  10. pointer4
    pointer4 Member
    Hungary
    276Coins
    Ohh, i almost forget.
    When you choose a TV, pay attention to the input-lag. Not every TV fast enough as a monitor.
    In our days, some TV-s have special 'Gaming' mode, to reduce this input-lag. Google first it, about your chosen TV!
    Use a CRT monitor and the LCD in clone mode, run the test util, and shoot a photo :D
    Use a preferred resolution and refresh rate!! Different screen-modes have a different results.
  11. egoexpress
    egoexpress Active Member
    Germany - Frankfurt/M
    421Coins
    Well done! :clap:
    Imho a little bit more action would be better though...
    Btw, is the simulator yours, or from TronicGr? The video title is confusing.
    Regards
  12. pointer4
    pointer4 Member
    Hungary
    276Coins
    You're right, i corrected it. :D
    I say thank you for it otherwise, how you dealt with my topic, and avatar. :thbup:
  13. pointer4
    pointer4 Member
    Hungary
    276Coins
    The sign of my respect :rofl:
  14. Frakk
    Frakk Active Member
    328Coins
    Good job! Let's see some action! :D
  15. Deleted member 4120
    Deleted member 4120
    hi,
    can you send me the setup??
    lfs and iracing
    thanks
  16. fredspeed
    fredspeed New Member
    Northern Norway
    418Coins
    Like Interview I will be glad if you shared some profiles, because there are not too many profiles to download for viper-powered-seat-movers. (ofcourse it is a good lesson making them by yourself, but it helps to see what others do). Do you play any simbin-games, or have profiles for it?
    btw: Good job on your sim!!! :thbup:
    Regards Fred
