Question (I'm working on a 2DOF) The motor is only moving in one direction. Please help
Discussion in 'Motor actuators and drivers' started by riki99, Feb 1, 2025.
  1. riki99
    riki99 New Member
    korea
    27Coins
    Hello, I'm a beginner who has burned out three IBT-2 modules. I'm currently testing a 250W 75RPM wheelchair motor with a current below 18.5V. Previously, I failed twice by recklessly testing it under load (using 24V), which caused the modules to burn out. Now, I've detached the motor and am experimenting with it. However, I'm facing an issue where the potentiometer ratio in SMC3UTIL doesn't match, and when I manually adjust it, the motor only moves when the green line is below the blue line in the sine wave graph. When the blue line rises above the green line, the motor doesn't move downward but simply stops. Could I have burned out the IBT-2 again? I really need some help with this.
    152,665Coins
    +11,103 / 56 / -2
    Can you please post a picture of your SMC3 settings.
  3. riki99
    riki99 New Member
    korea
    27Coins
    It only moves in one direction
    152,665Coins
    +11,103 / 56 / -2
    I would suspect the control hardware may have a fault.
    That aside how did your arrive at the SMC3 settings you have, particularly at this early stage where you are just getting it going? I would have expected something closer to the settings in the SMC setup instructions, with refinement of settings coming after basic movement is established and the hardware set up on the rig,
  5. riki99
    riki99 New Member
    korea
    27Coins
    Thank you. I will purchase new control hardware and give it another try.
  6. Dhenz Dosmiltres
    Dhenz Dosmiltres New Member
    - 44Coins
    riki, assuming all your settings at SMC3 are correct, this might be your problem as why your motor is turning only in one direction. The pot must be directly connected to the shaft or with your configuration must have a 1:1 gear ratio.
  7. Attyla.pl
    Attyla.pl Active Member
    Polska
    1,341Coins
