SimTools v3 Public Beta
  1. yobuddy
    51,530Coins
  2. Stahlwolle
    Stahlwolle Member
    268Coins
    I tried but there is an error message:
    The device does not support symbolic links...
    Ah, OK, got it, hard drive was formatted exfat
  3. Stahlwolle
    Stahlwolle Member
    268Coins
  4. Michael Pleym
    Michael Pleym Member
    258Coins
    Please disregard this post. Actually it was sth wrong with the USB-cable from the seatmover to my pc. Now I have connected the cable directly to the motherboard and it works again. :)
    I'm now running out of USB ports on my pc though. :-(
    Michael
  5. mhchong
    mhchong EK99
    freelancer
    malaysia
    - 120Coins
    After i created interface for my 2dof, when run 'test settings', Axis2a start at wrong position, by right it should at the middle, but it went up to 80%. For Axis1a no problems. Im using windows 11 in non English. Would like to ask, Simtools V3 still have this bug - 'SimTools Language setting bug - Change to English Local' ?
  6. yobuddy
    51,530Coins
    What do your parking location settings look like buddy?
    This problem has be resolved, with the last of the fixes (including the serial interface plugin) being pushed out this week.
  7. mhchong
    mhchong EK99
    freelancer
    malaysia
    - 120Coins
    I not yet reach the game motion setting or parking location. I test Axis motion in interface.
    * in SMC3 utilities it works fine.
  8. yobuddy
    51,530Coins
    I just pushed the update for the serial interface, give it 5mins or so, and then restart SimTools and you should receive the updated serial interface.
    Also, be sure the SMC3 utilities app is closed before running SimTools.
    Let me know how it goes,
    Chat soon buddy...
  9. mhchong
    mhchong EK99
    freelancer
    malaysia
    - 120Coins
    Hi, Thanks. Will reinstall serial interface tmr, and update status here.
  10. mhchong
    mhchong EK99
    freelancer
    malaysia
    - 120Coins
    Tested. It works fine now. Thank you.
  11. peter stolmeier
    peter stolmeier Member
    558Coins
    Simtools 3 has been working great with my rig and Thanos AMC controller. I'm moving over to a new more powerful computer and it's not responding now.
    I know I've set it up correctly mechanically because sim racing studio works as expected but when I hit test on simtools I get no response at all.
    I try not to jump to a forum first thing, but with "nothing" as a starting point I'm not sure what I'm even troubleshooting so I'm hoping you guys can point me in the correct direction.
    153,818Coins
    +11,150 / 57 / -2
    Can you please post pictures of all settings, so we have some idea of you may have done or not done.
    If changing computers I presume you re-registered SimTools, but want to ensure that is the case.
  13. peter stolmeier
    558Coins
    Yes, I am registered once again.
    I've uninstalled and reinstalled a few times so currently I don't have most settings. I figured I'd work until I got one motor to respond before I put it all back in.
    Here's the settings as they currently are
    Here's the settings from the still working older computer.
    I apricate you taking the time to look at it. I don't think it's an issue here though because my system has an "active" state it will switch to when I press "test settings" and currently nothing happens on the new computer. as a reminder it does work with another sim program and works in simtools on the old machine.
  14. peter stolmeier
    558Coins
    found it.
    after re-reading what you said I searched for what more settings you may want to see. I had not set up this one.
    153,818Coins
    +11,150 / 57 / -2
    Well done, I am glad you got that sorted and can move on to refinement then having some fun :thumbs
  16. peter stolmeier
    558Coins
    I was hoping to import my settings. I see the export wizard but it's a little unclear how the import works.
  17. peter stolmeier
    558Coins
    Simtools 2 and 3 are similar enough in most cases to use one guide for the other but that's not the case with loading a backup. When I do a search about it I get instructions for the plugin updater for 2 but I don't know what the equivalent for 3 is so I'm still looking for guidance.
    I actually suggest adding an "import wizard" next to the export one for clarity to new comers.
  18. yobuddy
    51,530Coins
    Hi Peter,
    I will make this more clear in the next update to the manual, thanks for the feedback.
    Launch SimTools v3, and then drag-drop the file onto the gui to install.
  19. VFX Pro
    VFX Pro Member
    Los Angeles
    431Coins
    Motion platform, 6DOF
    Does anyone know if Assetto Corsa Evo will have a SimTool 3.x plugin soon?
  20. Joe Cortexian
    1,537Coins
    I came here to find out. I did some research and apparently it’s the same protocol as AC and ACC. But you can’t believe everything you read in the internet.
