MSFS 2024?
Discussion in 'SimTools Plugins' started by Tim Herschbach, Nov 20, 2024.
  1. Tim Herschbach
    Tim Herschbach Member Gold Contributor
    585Coins
    Does anyone know where I can get a plugin for msfs 2024 or... is anyone working on one? Or how difficult is it to make one? I have the "How to" page bookmarked but was asking before I jumped into it. I'm not sure if this is something that takes a few hours or days. Wondering if I could just port the 2020 version over?
  2. Guyotine
    Guyotine New Member
    - 1Coins
    3DOF, SCN6
    I have the same question
    153,914Coins
    +11,156 / 57 / -2
    It is already out for SimTools v3: https://www.xsimulator.net/community/threads/simtools-v3-public-beta.17329/page-101#post-252232
  4. frsim09
    frsim09 Member
    Ariège, France
    604Coins
    Thanks Noorbeast for the V3 plugin, but will there be one for ST V2 please?
    153,914Coins
    +11,156 / 57 / -2
    I can't say for sure but doubt it, given SimTools v3 in in the final stages of Beta testing and that you can install v2 and V3 on the same PC and use the same license to use both.
  6. Guyotine
    Guyotine New Member
    - 1Coins
    3DOF, SCN6
    Hi! I'm asking for help. I've tried everything and I don't understand the origin of my problem. Let me explain: I can't feel movements on a game. MFS2020 and MFS2024. All other games work without problems. My configuration: Windows 11, Prosimu 3M SCN6, Simtoolsv3. I was working with SRS before, and I didn't have the problem. But the movements were not optimal. Prosimu told me that it was no longer compatible. So I came to Simtools. I uninstalled/reinstalled simtools, the mfs plugin, windows... But nothing changes. I noticed that when I install the mfs plugin, I have no values in the axis management. I then manually set the values, despite this no movement felt. I'm really lost, and I hope that a simtools genius can help me... Thanks in advance.
    153,914Coins
    +11,156 / 57 / -2
  8. Guyotine
    Guyotine New Member
    - 1Coins
    3DOF, SCN6
    153,914Coins
    +11,156 / 57 / -2
  10. frsim09
    frsim09 Member
    Ariège, France
    604Coins
    Ok what a shame !, thanks, i will install the STV3
    Is there a data transfer tool between V2 and V3 to reduce set-up time?
    153,914Coins
    +11,156 / 57 / -2
    SimTools v3 is a significant rewrite, so no plugin compatibility with v2, and many other improvements/refinements.
    Please see the SimTools v3 Quickstart Guide and Manual: https://www.xsimulator.net/community/faq/simtools-v3.401/
  12. iamcanadian2
    iamcanadian2 Member
    floating docks
    surrey bc canada
    90Coins
    Motion platform, 6DOF
    Dang, I was hoping for a Version 2 plugin for MSFS2024, Everything else is working perfect on version 2. Version 3 is learning to walk again UGH! For a guy who is dislexic not easy, But thanks for the work involevd.
  13. Keith
    Keith Active Member
    Electrician
    Canada, Saskatchewan
    154Coins
    Is anyone having issues with the min and max tuning settings making no difference? I can set everything to zero but I still have tons of motion.
    153,914Coins
    +11,156 / 57 / -2
    Can you also please try setting the min and max at say 150, and let us know the outcome.
    The reason is that the higher the min and max value the smoother the motion, but over a greater range.
  15. Keith
    Keith Active Member
    Electrician
    154Coins
    Here are my settings. Maybe it's not saving properly or something.
  16. noorbeast
    153,914Coins
    +11,156 / 57 / -2
    Can you please add a picture of the Min/Max in flight, where the Motion Input values are visible.
  17. Keith
    Keith Active Member
    Electrician
    154Coins
    Every time I close things down and fire back up the min and Max tuning settings revert to this. I tried setting all these to 150 then I hit that save button where the mouse pointer is sitting. I have tried deleting the plugin and reinstalling. Still same thing
  18. VFX Pro
    VFX Pro Member
    Los Angeles
    431Coins
    @noorbeast I dont' receive any data from MSFS 2024, ST3 doesn't show any values in the mix/max. Is there a settings that needs to be changed in the game to output telemetry, am I missing something? I can't find anything online about it...
  19. VFX Pro
    VFX Pro Member
    Los Angeles
    431Coins
    I have the same problem, no data from MS 2024. @noorbeast, do you think it is related to the using the Windows Store vs the Steam version, since they might have a different installation paths?
    I have the Steam version and it installs it here C:\Program Files (x86)\Steam\steamapps\common\Limitless
    which is very strange. I was expecting something like C:\Program Files (x86)\Steam\steamapps\common\microsoft\flightsimulator2024\....
    153,914Coins
    +11,156 / 57 / -2
    Please post to the official v3 thread for SimTools dev visibility and advice.
    Also be aware of the ground and air settings: https://www.xsimulator.net/community/threads/simtools-v3-public-beta.17329/page-104#post-253008
