Showroom Smitty's Rotary Servo 6DOF build (Complete!)
Discussion in 'DIY Motion Simulator Projects' started by smitty, Dec 15, 2021.
  1. azm
    azm New Member
    65Coins
    This looks fantastic! Now I know where to get some info in case I start building one
  2. Kenshiro27
    Kenshiro27 Active Member
    67Coins
    remarkable and efficient engineering work; very beautiful machine
    Honestly very impressive
    Good flight:thumbs
  3. smitty
    smitty Active Member
    916Coins
    I've gotten a few requests for all my designs, I'm not too keen on giving it all away, but you can poke thru my 3D eDrawings model here. You will need SolidWorks eDrawings viewer.
  4. prophet.id
    prophet.id BOSeTAMPER's Rotary Servo 6dof Build
    214Coins
    Where do you source the tube bending?
  5. mafli
    mafli New Member
    Frankfurt, Germany
    51Coins
    See his post
    „We're having the raw steel plate & tube cut & bent by job shops, so that wont be an issue. Plus one of my friends on the build runs a machine shop so there wont be much we can't do!“
  6. prophet.id
    214Coins
    Can you share the job shop for the tube works please?
  7. smitty
    916Coins
    https://vr3.ca/
    i sent them the solidworks model of the tubing and 3 days later it was on a pallet on a truck!
  8. prophet.id
    214Coins
    Thanks!
    What tube size are you using on your built?
  9. smitty
    916Coins
    4130 steel, mostly 2.00 x .065 and some 1.00 x .120
  10. Manuel Gonzalez
    Manuel Gonzalez New Member
    New York
    127Coins
    Amazing!
  11. GettinBetter
    CAD Engineer
    Kent, UK
    433Coins
    I have a question, if you were to make another one, what would you change?
    I mean it looks perfect from an outsiders perspective (well mine anyway) but as the user, you will have indepth knowledge, about little things, that you would do differently if there were that "next" time.
  12. smitty
    916Coins
    Not a whole lot!
    • One thing i was thinking about, would be to drop the seat/pedals about 100mm, (red lines) while keeping the bottom tube in the same spot. this would also lower the upper part of the bent tube and monitor. It's not hard to get in/out but this would make it easier. Lowering CG is never bad.
    • The tube at the purple arrow is a weak spot. the whole forward pedal/monitor part of the tubes comes to this point, and there isnt much there to prevent bending. on frames #2 and #3 we did add some thin gusseting under the tube to help. My frame doesnt have the gusset and it hasnt been a problem, but i get some resonant vibration from that frame section bouncing up and down.
    • A softer chair maybe? i covered this hard plastic chair with 1" foam but it can still be a bit rough. i've looked at other sim seats but many are just too wide to clear my heli collective. other seats that were the right width didnt have the shoulder harness cutouts that i need. i keep looking but i havent found a good replacement yet.
    Other than that, it's been pretty much maintenance-free for almost 2 years now, and im in it nearly every night
  13. prophet.id
    214Coins
    By the way, what is your sheet metal's thickness and alloy? 1011 ?
  14. smitty
    916Coins
    various - 1/4" on the base and servo brackets, 11GA for pedal/joystick/seatbelt brackets, 14GA on the stuff holding the monitor. all generic "cold rolled steel", so its probably 1018
  15. prophet.id
    214Coins
    Wow... so even 4130 steel 2.00 x .065 tube alone is not rigid enough? Is it flexing during motion (vibrate) or more flexing during braking (pressure from the feet)?
  16. GettinBetter
    CAD Engineer
    Kent, UK
    433Coins
    Great info
    Two yrs, and how are the bearings on the end of the rods holding up, have you had a close inspection?
    It was one of the reasons I upped to M16.
  17. Wiley
    Wiley New Member
    22Coins
    Motion platform, 6DOF
    May I ask which servo (server) cabinet you bought, it looks to everything nicely
  18. smitty
    916Coins
    Its plenty rigid, theres just a wee bit of vibration. if i wanted to fully "overbuild" it, there should be some triangulation tube going from the "dashboard" tube to alongside the seat on the right side (i enter on left side)
    rod ends are fine, they are 1/2" high-misalignment type with 16000lb load rating. i just put a drip of oil on em once.
    NavePoint rack
    with 3 of these for mounting
  19. Alask
    Alask New Member
    16Coins
    Is there any chance you have a rough cost estimate with the current version? Looks insane to be fair :D
  20. smitty
    916Coins
    The 11th motor!
    Using yet another VPForce motor, i made a motorized trimwheel. I always kind of hated the simple potentiometer trim wheel, it worked, but everytime the msfs autopilot moved the trim in game, touching the trim wheel sometimes meant a violent change as the peripheral sent a new number to the game.
    Now, i can use the autopilot or stick trim buttons and it moves the wheel. or, i can move the physical wheel and it updates in game.
    also got a used VirtualFly TQ3+ from ebay, its such a nice unit
