FlyPT Mover 3.7.0.17
  1. SilentChill
    20,596Coins
    tried this and the send values look good just no movement
  2. pmvcda
    15,547Coins
    So bit values. You used
    R0.A1.T
    That is turns
    R0.A1.B
    Is bits
    R0.A1.P
    Is position in mm or º
    So it should be:
    x 0 <R0.A6.B> 5000 <13>x 1 <R0.A1.B> 5000<13>
    Here R0 is the rig key
    A1 to A6 is the actuators
    T, B or P as above
  3. pmvcda
    15,547Coins
    Ok, don't remember if it really was bits or position...
    If position use:
    x 0 <R0.A6.P>>> 5000 <13>x 1 <R0.A1.P>>> 5000<13>
    The number of > is the number of decimals (minus 1)
    If you have <50>>>, it will write 50.00
    the number or < is the minimum number of digits before the decimal
    For <<<<50>>> you get 0050.00
  4. SilentChill
    20,596Coins
    Yeah I have tried T, B and P but none of them work. Maybe I have something else setup wrong but I cant see anything.
  5. GTakacs
    GTakacs Member
    430Coins
    I'm confused.....
    I'm using 0.3.6.0 with a special dll that fixed the positioning so OpenKneeBoard also gets moved around correctly (It was wrong in iRacing due to orientation being different/swapped).
    The 0.3.7.0 was supposed to have that fixed but since I was already fixed I never upgraded to it. Now there is a 0.3..8.0 version that is supposed to have the order of translations match that of FlyPT (rotation first, lateral second).
    Are you saying any of these versions of OXRMC are not doing it correctly today with Mover 3.5.3?
    Will there be a fix for 3.5.3? Or is the issue only impacting Mover 3.7? I will try tonight and report back. I'll also post the profile that I'm testing with so you can see what I have.
    Also, I have reduced my monitor resolution and use 100% scaling for now so I don't have the issue with the positioning and size of fields/text but let me know if you ever could repro and fix? you may need a 4k monitor to actually see the issue.
  6. SilentChill
    20,596Coins
    with this it moves about a 10th of a turn
  7. pmvcda
    15,547Coins
    I'm lost right now, sorry. Have to make some tests...
  8. SilentChill
    20,596Coins
    No problem :) when i move the sliders it does slightly turn the actuator.
  9. khairul nizam
    khairul nizam dadima
    Retails
    Malaysia
    71Coins
    2DOF, DC motor
    In your old setup in the serial section, the data type is decimal. In your new setup, you are using binary, and Ascii. Could that be your problem?
  10. PeterW
    PeterW alias Wickie
    Dipl. Ing. Mb (FH)
    1,755Coins
    Hi Craig,
    maybe I am completely wrong, but If I remember correctly, the insectatec Odrive firmware was expecting encoder counts ? So if you have set your AMT 102 to 8192 counts per Revolution and you want 400mm travel (10mm ballscrew) you had to send 400/10x8192 = 327680 counts. This are integers and not decimals.
    So if I understand the output rules correctly you should write : x 0 <<<<<<R0.A6.P> 5000 <13>x 1 <<<<<<R0.A1.P> 5000<13>
  11. arminglf
    arminglf New Member
    130Coins
    Firstly, thank you very much @pmvcda for your work, this is awesome, I can finally play EA WRC!
    Question for anyone, have you guys been able to get telemetry for Dirt Rally 2.0? I tried Automobilista 2 and EA WRC and they work fine, but DR2 I can't get telemetry data although I have exactly the same parameters compared to the old Mover that is still working fine.
    Any ideas? thanks.
  12. arminglf
    arminglf New Member
    130Coins
    Did you find any fix for this? I have the exact same issue, only if I set the display to 100% then it looks fine, but in my case I use a TV and the display needs to be at 200% so even worse. If I set the percentage to 100% and then open Mover, I can later change it to 200% and it's still fine.
  13. hexpod
    hexpod http://heXpod.xyz
    berlin
    7,770Coins
    DC motor, 6DOF
    0.3.8.0 with Mover 3.5.3 should be fine
  14. pmvcda
    15,547Coins
    @PeterW , insectatech still exists? It wad
    You have to patch DR2, I have a new script to get some extra data.
    Use the pen button on the source to apply the patch.
    You can also use the joystick to do it.
    I will add all the files and instructions latter for when those don't work.
  15. pmvcda
    15,547Coins
    Like @hexpod says.
    For the new Mover it will work also, but I had some bugs already corrected for the new release. (almost ready)
    For the monitor I'm checking it right now...
  16. arminglf
    arminglf New Member
    130Coins
    Thanks!
  17. SilentChill
    20,596Coins
    No that doesn't do anything either :( Sure it will be something simple somewhere going to try some more now
    I have not seen Insectatech since October 2021
  18. SilentChill
    20,596Coins
    ascii is enabled so I guess it should work
  19. pmvcda
    15,547Coins
    ascii and decimal are the same
    Reality is that bytes are converted to their ascii representation.
    @SilentChill , could it be a . and , decimal separator problem? How was it showing in the olkd Mover compared to the new one?
  20. pmvcda
    15,547Coins
    Mover 3.7.0.2
    Download link in the first post of this thread.
    DONT USE THE THANOS OUTPUT
    That is a test I made that I left there (forgot to disable). Far from the real thanos output
    Worked on scaling problem. Think it's better, but...
    Solved bugs in OXRMC (inverted yaw and filters)
    Added possibility to specify location of game if not found by Mover
    Added WASHL, WASHE and WASHLT filters:
    WASHL is a linear wash where you specify the speed it goes back to zero (per sample)
    WASHE is an exponential wash where you specify the speed it goes back to zero (per sample)
    WASHLT is the same as WASHL, but we set speed in mm/s or º/s​
    Update connect/disconnect info in diagram
    Added some icons
    Solved connect/Disconnect on the menu of the diagram
    Added VTOLVR, still WIP (MOD is not available yet, need to check some vars causing crash in the MOD)
    Other small bugs everywhere
