News GoPro 2 VideoRide (sneak peek) - releasing next week!
Discussion in 'News' started by yobuddy, Aug 8, 2024.
  1. yobuddy
    51,357Coins
    What is the GoPro2VideoRide application?
    The GoPro2VideoRide application is able to create an instant video ride from a GoPro video. A user can simply drag-drop the mp4 file into the GoPro2VideoRide app, select the settings desired, and it will dump and remix all the telemetry, gravity, gyro, speed and gps data for you. It also process the video to a fixed frame rate so it will play perfectly with the telemetry.
    The following GoPro cameras are supported by this app. (Should other actions cameras be found that support the GoPro GPMF telemetry file format, they may also work with this application.)
    • GoPro MAX
    • GoPro Hero 8
    • GoPro Hero 9
    • GoPro Hero 10
    • GoPro BONES (Vehicle speed is unavailable)
    • GoPro Hero 11 (Speed output reduced from 18 to 10 fps with this model)
    • GoPro Hero 12 (Vehicle speed is unavailable)
    The GoPro 2 VideoRide Application Documentation can be found here:
    https://simtools.us/wp-content/uploads/2024/08/GoPro2VideoRide.pdf
    Here is a little preview of it in action.
    • Winner Winner x 3
  2. yobuddy
    51,357Coins
    The GoPro2VideoRide app has now been released! :thumbs
    • Winner Winner x 3
  3. Chris_Beeves
    2,145Coins
    Where can it be found?
  4. yobuddy
    51,357Coins
    Its now included in the SimTools v3 installation, or it will get installed when you update SimTools v3 to the current version.
    Take care!
  5. yobuddy
    51,357Coins
  6. Gilberto Marques
    Gilberto Marques New Member
    - 529Coins
    Could you provide an example video to test? I tried with several GoPro videos but it always gives an error, it could be a link via Google Drive or something else, it would help a lot
  7. Gilberto Marques
    - 529Coins
  8. Gilberto Marques
    - 529Coins
    I tested it with over 20 videos from the GoPro Hero 8, 9, 10, 11, and 12 in various formats and resolutions, but it always gives errors. I would like to test it in SimTools before investing in the purchase of a GoPro. If it's possible to provide an example video just to test in VideoRide Player, I believe others are also having the same problem. Without a video already tested, it's not possible to proceed with the tests and adjustments in the simulator.
    If the developer could provide a sample, it would help a lot.
