SIMHUB MOTION FOR SMC3
Discussion in 'Commercial Simulators and Peripherie' started by Silyn, Jun 6, 2024.
  1. Silyn
    Silyn Member
    44Coins
    3DOF, DC motor, AC motor, Arduino, 4DOF
    Wotever has done the unthinkable and released SMC3 support in a very short period of time.
    This is (mostly) working on my DOFreality H3, and it feels incredible.
    Be sure to set axis resolution to 10 bit
  2. MatteKarla
    MatteKarla Member Gold Contributor
    20Coins
    As of yesterday there is also support for 2DOF.
    He has also added built in support for using OpenXR Motion Compensation and having SimHub sending data as a virtual tracker. So no need for adding controller/tracker to your simulator.
  3. Silyn
    Silyn Member
    44Coins
    Which is amazing for us with 1000W+ of bass shakers buzzing the unit too
  4. itsumairu
    itsumairu Active Member
    Psychologist
    Indonesia
    440Coins
    This is a great news! thanks for sharing.
    I've been test it, but I confuse how to limit my axis angle movement?
    I got my DIY motion system always off without limit the angle
    • Disagree Disagree x 1
  5. Silyn
    Silyn Member
    44Coins
    I'd recommend joining the discord and posting your config, Wotever has been extremely responsive
  6. itsumairu
    Psychologist
    Indonesia
    440Coins
    Ok, I'll try to ask him there
  7. itsumairu
    Psychologist
    Indonesia
    440Coins
    #update I've contact Wotever and he said that he will add the axis limit in next release. can't wait for it.
  8. Silyn
    Silyn Member
    44Coins
    I made a video on my H3, and I set a limiter :)
  9. itsumairu
    Psychologist
    Indonesia
    440Coins
    Yeah, I did every limit setting there, but no axis limit as in simtools that works on my diy build.
    Wotever give me this picture. He will add it to the next releases.
  10. ProjectF1
    ProjectF1 Member
    Electrician
    303Coins
    hello, I can't find the settings for the position of the platform at start-up, can you give me the adjustment parameter because I would like, to facilitate access, for it to be in the low position and not in the middle
    thank you, have a good day
  11. Silyn
    Silyn Member
    44Coins
    The system moves to idle (centered) position when games start?
  12. ProjectF1
    ProjectF1 Member
    Electrician
    303Coins
    yes, the platform moves to the middle position when you stop the game
  13. Silyn
    Silyn Member
    44Coins
    What is the problem?
  14. ProjectF1
    ProjectF1 Member
    Electrician
    303Coins
    I would like that when I start my simulator, the platform is in the low position (to be able to climb on it more easily, I'm starting to get old
  15. itsumairu
    Psychologist
    Indonesia
    440Coins
    yes, you can do it with simhub. there's a section that control the "parking position". just like mine, I can get in and out easily now.
  16. itsumairu
    Psychologist
    Indonesia
    440Coins
    This is my rig setup, it move to idle/ready position from "parking" position when the game is start or when the motion is enabled. and if we close the game, it move to parking position again.
  17. ProjectF1
    ProjectF1 Member
    Electrician
    303Coins
    thank you very much, I will look at these settings this evening!
  18. ProjectF1
    ProjectF1 Member
    Electrician
    303Coins
    I found the parameter for the parking position, thank you for your help
  19. izolyator
    izolyator Member
    276Coins
    2DOF, 3DOF, Arduino
  20. Silyn
    Silyn Member
    44Coins
    Yup, for all 3/4 dof based, no 6dof Stewart platforms yet
