3-DOF Simulator Need some Help
Discussion in 'DIY Motion Simulator Projects' started by Mr_Harleyking, Apr 9, 2024.
  1. Mr_Harleyking
    Mr_Harleyking New Member
    Germany (near Basle CH)
    47Coins
    Hello there,
    After some time researching and compiling information, I would now like to get started.
    My material that I will use:
    H-Bridge (Can´t Add links yet)
    Sensors (Can´t Add links yet)
    Material I will most likely use:
    Power supply (Can´t Add links yet)
    I found these motors, (not ordered yet) unfortunately i can't find the power in watts, does anyone have experience with these motors?
    What current do they need? Unfortunately I can't find anything.
    Motor picture:
    Many thanks in advance.
    151,668Coins
    +11,045 / 56 / -2
    If a search fails to find the specifications you may need to try emailing the manufacturer.
  3. Attyla.pl
    Attyla.pl Active Member
    Polska
    1,334Coins
    151,668Coins
    +11,045 / 56 / -2
    The motors should be powerful enough for a range of rig designs, it really depends on how easy the brakes are disabled.
  5. Mr_Harleyking
    47Coins
    Thank you very much.
    Most of the used motors here are between 250-350W or?
    151,668Coins
    +11,045 / 56 / -2
    That range should suit most sensible designs.
  7. Mr_Harleyking
    47Coins
  8. Mr_Harleyking
    47Coins
    Now that I'm allowed to post links, here's my list of components:
    - 2x motors (left and right)
    - 2x H-bridge 100A
    - 1x H-bridge 43A
    - 3x Hall sensor
    A "Eurobox" is to serve as the control cabinet.
    Here is my plan, sorry it is in German.
    Since the motor needs less power for the yaw movements, which one can you recommend? A cordless screwdriver motor? Or something more powerful?
    Thank you
  9. Mr_Harleyking
    47Coins
    After a long break, I will do my best to finally finish my simulator.
    This is my test to see if everything fits into the control cabinet.
    I also want to plan the bracket for my seat. You can find a sketch of this in the appendix.
    What do you think?
    Thank you very much for your support :)
    151,668Coins
    +11,045 / 56 / -2
    Just be aware the mounting point for the uni joint needs to be determined with you onboard, along with all peripherals, please see the FAQs here: https://www.xsimulator.net/communit...-of-gravity-to-balance-a-motion-simulator.55/
