Showroom 3DOF DC Brush motor actuators
Discussion in 'DIY Motion Simulator Projects' started by m50b20, Feb 22, 2024.
  1. m50b20
    m50b20 Member
    100Coins
    Something clunking sometimes in left actuator, i can't realize what exactly.
    Everything else still in place )))
  2. m50b20
    m50b20 Member
    100Coins
    Forgot to mention, after 2 hours of playing IBTs and motors stay cold
  3. Juah
    Juah New Member
    - 133Coins
    Excellent work, very clean and with few elements, congratulations, a question if you can, but what type of potentiometers are you using? I'm trying with softpots but in addition to wearing out they are also unstable in my opinion.
  4. m50b20
    m50b20 Member
    100Coins
    Thanks !
    P3022 360 Hall pots
    Very precise and do not wear at all
  5. m50b20
    m50b20 Member
    100Coins
    New steering wheel (hoverboard motor)
    Crazy powerful (i'm using it on 45% max)
    Sorry for my outfit ))
  6. m50b20
    m50b20 Member
    100Coins
    Soooo...
    Everything works ok, but there is some major and minor problems - it is ok, it was first attempt )
    Bought 3 italian wormgear reducers 050 size and matching motors
    • Optimistic Optimistic x 1
  7. workfayer
    workfayer New Member
    Brazil
    89Coins
    2DOF, 3DOF, Arduino
    What an interesting project, I didn't believe that dc motors with brushes and bts would have enough strength to carry out an assembly like this, congratulations on the project.
  8. Michail
    Michail Member Gold Contributor
    731Coins
    May I ask you how many amps your motors have and how many voltages each power supply has.
    I have set my to 21V because I have read, that the bit-2 are safety driven in the range between 18 -21V.
    I has issues with my rig when in parking location and I step in the simulator. So I hope to give more voltage can safe the problem.
    has the location issue as well the simtools v3? Is this only a simtools issue or smc3utils as well?
  9. m50b20
    m50b20 Member
    100Coins
    Mine are 21 too, 13.2 amps each psu
    How is your rig driven ? Wormgear or ballscrew ?
  10. Michail
    731Coins
    I found the solution!
    The parking location getting below the Clip limit cause of the inertia when load. So pwmrev Set 200 tries to get out of the clip limit. So setting slightly higher values of the parking location works for me.
    I have similar values.. 13.4A 24V 75 rpm common wheelchair motors here in the forum. I dont know if it ballscrewd or wormgesr driven.
    Thank you Anyway for your Quick reply!
  11. m50b20
    m50b20 Member
    100Coins
    Can't run Simtools V3 with FlyPT ESP32 code, V2 is working nice (((
  12. mafli
    mafli New Member
    Frankfurt, Germany
    51Coins
    Do you might have videos of your rig? The youtube content seems to be unavailable "This video is private".
    Thanks!
