Radical (stupid?) idea for 2DOF platform
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by niterida, Feb 25, 2024.
  1. niterida
    niterida Member
    Geraldton, Western Australia
    852Coins
    153,884Coins
    +11,154 / 57 / -2
    I presume you mean a design with the pivot at the very front and motors at the rear.
    If so that is not likely to be cost effective, compared to a traditional pivot under the user, as your design would require far more powerful motors.
    Have a play with SimCalc to help get your head around the tradeoffs between design Vs physics between those two design options: https://www.xsimulator.net/communit...e-linear-speed-and-forces-of-your-design.270/
  3. niterida
    niterida Member
    852Coins
    Yes
    Yes I realise that but it has other benefits for my situation.
    I was also hoping that not requiring much movement would help ??
    Will use that to see how much power I need - I do understand the differences but have my reasons for not wanting the usual pivoting setup
    Cheers :)
  4. niterida
    niterida Member
    852Coins
    First simcalc attempt :
    Does that look right for my inputs ?
    The pivot will be right at the front and at the same level as the motors.
    The rods will be little short ones basically ending where the X and -Z lines are in the drawing.
    And how do I read the outputs ?
    I read the Help box and it would seem to me that it is indeed feasible ??
    153,884Coins
    +11,154 / 57 / -2
    Marginally, as torque efficiency of levers is most effective at right angles and drops off rapidly after about 38 degrees, so the less movement from zero the more efficient torque utilisation.
    Apologies but SimCalc will give a false indication here, as it presumes the mass is evenly located over the pivot, like a seesaw, where in your case all the mass is behind the pivot, like a wheelbarrow:
  6. Gadget999
    12,132Coins
    move the pivot to below the cog
  7. niterida
    niterida Member
    852Coins
    Yes I understand thats what you should do, but I have my reasons for not wanting to do that.
    I am however having a rethink to see if I can move it and still keep my reasons for not moving it, if that makes sense :think
  8. niterida
    niterida Member
    852Coins
    How about this with either DC Motors or SCN5 or 6 actuators at the foot. Given that I only want 100mm of travel at the motor end I assume this would be a better solution ?
    If so DC motors or linear actuators ? Personally would prefer linear if they will work, but scared off by the cost :(
  9. niterida
    niterida Member
    852Coins
  10. niterida
    niterida Member
    852Coins
    153,884Coins
    +11,154 / 57 / -2
    Yes, that design would allow you to properly balance the rig.
  12. niterida
    niterida Member
    852Coins
    With DC Motors and short levers at the front ??
  13. noorbeast
    153,884Coins
    +11,154 / 57 / -2
