Actuator brush+ ibt2 diy 4dof psu fire
Discussion in 'DIY Motion Simulator Projects' started by Stefzouille, Jan 13, 2024.
  1. Stefzouille
    Stefzouille Member
    595Coins
    2DOF, DC motor, 4DOF
    Oh yes okay. Actually, I understand better there though. There is a lever arm which allows you to reduce the force required. My system is really different since I am in direct gear without a lever arm.. But this system seems very interesting all the same
  2. Stefzouille
    Stefzouille Member
    595Coins
    An important thing too, you have to think about the current return. Because changes of direction consume a lot but with the weight on top, it sends current back to the power supplies, what have you planned to protect the PSU?
  3. m50b20
    m50b20 Member
    100Coins
    No, this arm is controversial - it reduces your motor power ~2 times - the push arm is two times smaller than driving arm - that give me hope my motors will be enough. Direct gear (mine too) is 1:1 of course
  4. m50b20
    m50b20 Member
    100Coins
    Brake resisor with FR120 mosfet
  5. m50b20
    m50b20 Member
    100Coins
    Or you can use just big enough diode but you need your motor driver be capable of two times more volts than your motor is working or it will die )
  6. Stefzouille
    Stefzouille Member
    595Coins
  7. m50b20
    m50b20 Member
    100Coins
    Black thing on the bottom is a fuse ?? Or what is it ?? I can't realize
  8. Stefzouille
    Stefzouille Member
    595Coins
  9. Stefzouille
    Stefzouille Member
    595Coins
    Hello, following some problems, so I switched to two dof, load test at 80 kg after a minute a little smell of burning I stop everything I open the power supply and there disaster... :(
  10. m50b20
    m50b20 Member
    100Coins
    What kind is your PSU ?
  11. Stefzouille
    Stefzouille Member
    595Coins
    24v 1000w:
  12. Stefzouille
    Stefzouille Member
    595Coins
    Erf, psu on fire, There was smoke everywhere...
