Aircores & Ardurino Controller
Discussion in 'DIY peripherals' started by wimpo`, Jun 15, 2010.
  1. wimpo`
    wimpo` Member
    metselaar
    nederland, twente, vroomshoop
    178Coins
    could you provide a schematic of some sort i want try it with my air-core ;D
  2. herctrap
    herctrap Member
    Ilion / Pylos
    243Coins
    ok i just keep posting
    the tacho is a stepp motor
    the speedometer is controlled by the cluster input one single cable no aircore
  3. wimpo`
    wimpo` Member
    metselaar
    178Coins
    then wat is the speedometer?
  4. Jadran
    Jadran Member
    Racing game:LFS,Simbin (Race07,GTREvo,RaceOn)
    Osijek,Croatia
    3,207Coins
    WOOW :clap:
    Is it possible to make with Arduino Duemilanove http://arduino.cc/en/Main/ArduinoBoardDuemilanove or just with Arduino MEGA ?
    p.s.
    I have Arduino Duemilanove,Arduino Sensor Shield V4 digital analog module & servo(booth buy on eBay) and BMW cluster E36 .
    BUT I do not know programming :? ,only wiring connect and load the program to Arduino chip :yes:
  5. wimpo`
    wimpo` Member
    metselaar
    178Coins
  6. herctrap
    herctrap Member
    Ilion / Pylos
    243Coins
    you just need the chip from the arduino
    the atmega328 is the big in the middle in the left side of my breadoard the one with the red dot
    i will use it with it only
    but i dont have the parts for connecting it to the pc and be able to uplod code on it
    send a back photo of the cluster
  7. Jadran
    Jadran Member
    Osijek,Croatia
    3,207Coins
    Hi!
    I have old board with ATMEGA 168-20PU :?
    In attachment is picture of the back and some diagram(pinout) and shematic of BMW E36 cluster
  8. herctrap
    herctrap Member
    Ilion / Pylos
    243Coins
    ok what wlse do you have
    resistors
    transistors?
    and wich
  9. Jadran
    Jadran Member
    Osijek,Croatia
    3,207Coins
    Nothing :D ,cluster,connectors of cluster, Arduino Duemilanove and Arduino Sensor Shield V4.
    Tomorrow I will buy everything what I need (but what?),can you write here pls :D
  10. herctrap
    herctrap Member
    Ilion / Pylos
    243Coins
    lets wait tonicgr to tell us the difference between the can clusters and no can clusters
    so we will be sure if your cluster can run as mine
  11. Jadran
    Jadran Member
    Osijek,Croatia
    3,207Coins
  12. Frakk
    Frakk Active Member
    328Coins
    About 5 seconds of google search will tell you that CAN is a serial communication protocol. It will accept serial commands and values then control the gauges accordingly.
    In a no can cluster you have to figure out what type of signals are needed for the gauges.
  13. Jadran
    Jadran Member
    Osijek,Croatia
    3,207Coins
    I manage to run lights (some others depending + or - like ABS,high beam,L-R turn signal...but when they connect those bright),display below km/h and fuel needle only with 12V power but other,speed needle,RPM needle,fuel needle(to work) and temp needle without some other hardware is difficult to do :?
    http://www.youtube.com/watch?v=6n_TccrYwsc
  14. herctrap
    herctrap Member
    Ilion / Pylos
    243Coins
    just take some npn transistors like 2n3904
    some 1K 2K resistors
    and some pontesiometers
    and a breadboard that would make your life easier
  15. Jadran
    Jadran Member
    Osijek,Croatia
    3,207Coins
  16. herctrap
    herctrap Member
    Ilion / Pylos
    243Coins
    yes linear
    bigger = better
  17. herctrap
    herctrap Member
    Ilion / Pylos
    243Coins
    untill to make the how to post
    http://www.youtube.com/watch?v=Q2Ym7Q0MooM
  18. Jadran
    Jadran Member
    Osijek,Croatia
    3,207Coins
    WOW!!! Nice :clap:
    But 200km/h not enough for LFS or Race 07 :D ___ joke
  19. Jadran
    Jadran Member
    Osijek,Croatia
    3,207Coins
    If someone needs Audi A3 cluster pinout ;D
  20. herctrap
    herctrap Member
    Ilion / Pylos
    243Coins
    any update on the aircores??????
