Showroom Smitty's Rotary Servo 6DOF build (Complete!)
Discussion in 'DIY Motion Simulator Projects' started by smitty, Dec 15, 2021.
  1. sxyeah
    sxyeah New Member
    - 2Coins
    I'm from China. This 750-watt motor costs about US$50 brand new in China, US$30 second-hand, and US$14 second-hand for a 50-speed reducer. Almost all servo motors and industrial equipment in the world are produced in China.
  2. sxyeah
    sxyeah New Member
    - 2Coins
    Yifeng Electronics AASD, Yichuan Electric. Taizhou Yichuan Electric Co., Ltd. was established on April 18, 2014. The legal representative is Chen Guodong. The company's business scope includes: manufacturing and sales of motors, power electronic components, and instruments; research and development of industrial automatic control systems, etc.
  3. sxyeah
    sxyeah New Member
    - 2Coins
    could you please share me this project? STP or SKP
  4. smitty
    smitty Active Member
    936Coins
    The upgrade to make the Thrustmaster TPR force feedback is complete! Finished the last parts finally. The hollow bolts make tensioning the cable very easy. IMG_6272.jpeg IMG_6271.jpeg IMG_6274.jpeg IMG_6273.jpeg IMG_6275.jpeg IMG_6276.jpeg
    • Like Like x 5
  5. RP39
    RP39 New Member
    42Coins
    @smitty This looks awesome! Have you measured, how heavy this beast (the upgraded rudder) now is? Mind sharing the CAD-files?
  6. smitty
    936Coins
    The motor itself is most of the weight, its 1.1kg. I have cad files in a knowledgebase thread on the vpforce discord, there is a link to that here https://vpforcecontrols.com/
  7. RP39
    RP39 New Member
    42Coins
    Thanks mate!
  8. smitty
    936Coins
    here's an example of some good & bad STOL landings!
  9. flipflop
    flipflop Member Gold Contributor
    Swansea
    382Coins
    3DOF, Arduino
    Loved the bad landing :grin
    Fantastic project guys. Thanks for sharing it.
  10. smitty
    936Coins
    some bad driving in BeamNG
  11. Mirage
    Mirage New Member
    28Coins
    I was thinking about maybe making something similar to your design in the future, and while I'm no mechanical engineer, I was thinking, if it tilts past a certain angle, won't those yellow bars (forgive my terminology) hit the cranks/bend the fastening? That may have been addressed in an earlier post and I missed it, possibly when the limits of the motor angles were being calculated. Or is it just not a problem due to the tilt not being too much for it to handle?
  12. smitty
    936Coins
    yes, while powered off (or e-stop that cuts power), you can grab the cockpit and move it places where the rods hit the crank arms. its at very great tilt angles like 45 degrees and extreme translations.
    while powered up, the limits in flypt keep roll and pitch to +/-28deg, yaw 20deg, and XYZ translations to +/-100mm. i could possibly go more, i did not test extreme position collisions, but as you translate away from center, you lose rotation angle capability. also adding yaw+pitch can exceed the flypt limits also, so it . in all my flying/driving/crashing, the rods and cranks have never interfered.
  13. smitty
    936Coins
  14. Thanos
    Electronics Engineer
    2,907Coins
    Hey, I got a super good deal for one of these hexapods for my workshop, that I couldn't pass...
    Needs a few extra bits and bolts, but yes, I love it so far!!
  15. smitty
    936Coins
    Rotary for the win! Small footprint, quieter, (I dont know what all that clanking is, it should be a lot quieter!)
    What ratio is the gearboxes?
  16. Thanos
    2,907Coins
    It's missing a few bits and bolts...
    I found it in a storage sale (owner left the country), so it's a bit beat up.
    But for the $2k I paid, I also got the cockpit with several expensive items in it, even VR headset!!
    It's 50:1 reduction... was using Thanos controller before..
  17. smitty
    936Coins
    cool! just checking on the ratio since you were doing a "speed" test and looked slow, it will definitely go faster than that.
  18. Thanos
    2,907Coins
    Definitely.... after I secure the rods with proper attachments and use real motion data!! The self test of the controller is somewhat speed restricted, to avoid damage...
  19. Thanos
    2,907Coins
    I might need you soon to share with me some FlyPT examples profiles... too busy to build one from scratch :p
  20. smitty
    936Coins
    look in your discord :) #MSFS & #other channels
    wish we could upload .mover files here but it only accepts txt, zip, pdf and some images
