F1 motion sim - upgrading 2DOF to 3DOF
Discussion in 'Commercial Simulators and Peripherie' started by early_m, Dec 31, 2023.
  1. early_m
    early_m Active Member
    Chelmsford
    869Coins
    I built my 2DOF F1 motion sim many moons ago and it has been an absolute joy to use. I've been tweaking it over the years and I'm very happy with it's performance.
    The 2DOF came about as a learning tool, with the end goal of building a 6DOF. The 6DOF is still the dream but I wanted to see if I could create a 3DOF by reusing as much of the 2DOF as possible, which I've managed to achieve.
    The design is complete in 3D, so now the fun begins....
  2. early_m
    Chelmsford
    869Coins
  3. early_m
    Chelmsford
    869Coins
    This is the base setup, in a 120 degree Y orientation for maximum stability
    The motors now have levers both sides to distribute weight across the motor, with a 'n' shaped bracket to span the motor
    The pot feedback method has been changed from gears to belt drive to allow for the additional lever
  4. early_m
    Chelmsford
    869Coins
    Wired up
  5. poumpouny
    poumpouny Member
    93Coins
    So you're 3rd DOF will be heave ? i've also built my 2Dof but since Heave is already well supported by the 2D (event if it's not real heave but pitch ) i would better ad traction loss for my rig upgrade, especially in racing game !
  6. early_m
    Chelmsford
    869Coins
    Awesome, good luck with your build
    • Funny Funny x 2
  7. early_m
    Chelmsford
    869Coins
    Cockpit installed.
    The bottom part of the frame (previously used for the u-joint) is no longer required, so is reused and repositioned on the sides for the motor mount
  8. early_m
    Chelmsford
    869Coins
  9. early_m
    Chelmsford
    869Coins
  10. early_m
    Chelmsford
    869Coins
    • Like Like x 5
    • Winner Winner x 3
  11. soon jae _Lee
    soon jae _Lee New Member Gold Contributor
    republic of korea
    - 63Coins
    2DOF, SCN6
    The fluid movement and heave are fantastic !!
    I can't find it in the "mantis-simulators.co.uk" product category, but I think it will be launched soon.
    From the perspective of selling two products, I think the biggest point of comparison between the two products is Heave.
    You experienced a heave at 2dof and a heave at 3dof...
    After all, the heave in 3dof feels better, right^^?
    I would appreciate it if you could tell me what the difference is from a developer's perspective.
    For those of you who already have an "F1 League", I was wondering if you would consider selling the lower driveshaft for it??
    (This is a Google translation. Please excuse any incorrect expressions.)
  12. nnelsonn
    nnelsonn New Member
    307Coins
    3DOF, DC motor
    good work!!
    Which motors do you use?
  13. yura999
    yura999 New Member
    327Coins
    Hello, congratulations, great job. I wanted to ask you how many kilograms of gasolifts you have? And one more question. How do you get in and out of the seat? If you can take a photo or video? Thanks.
  14. early_m
    Chelmsford
    869Coins
    I use 200N on each motor which works well for my 75kg body weight.
    Here's a video demonstrating access
  15. Michail
    Michail Member Gold Contributor
    721Coins
    Can you share a link to the gaslifts you are using? And how you calculate that 200N is enough or not to stiff?
  16. early_m
    Chelmsford
    869Coins
    Got them off Amazon. No calcs, just trial and error
  17. Michail
    721Coins
    Amazon link?
  18. early_m
    Chelmsford
    869Coins
  19. Michail
    721Coins
    Last question: how long are your gas lift? How long is the stroke of the gas lift?
  20. early_m
    Chelmsford
    869Coins
    420 total length - 170 stroke.
