Bug Simtools v3 issues
Discussion in 'SimTools DIY Version' started by FLORIN ROMANIA, Dec 17, 2023.
  1. FLORIN ROMANIA
    FLORIN ROMANIA Member
    România
    786Coins
    Greeting Today when I opened my computer, I received the following message,
  2. FLORIN ROMANIA
    România
    786Coins
    I tried to put the email address and activation key but it tells me that the key is incorrect, I can only open simtools in demo mode
  3. yobuddy
    50,804Coins
    Looks like a general .net framework error of some kind.
    I don't have enough info to tell one what's wrong, but a re-installation may fix the issue.
  4. FLORIN ROMANIA
    România
    786Coins
    But until today it worked perfectly, may be from some pc update?
  5. yobuddy
    50,804Coins
    It's really hard to say without more info, but did you by any chance install a new antivirus?
    It's all I can think of off hand, as I have not seen a invalid class error before.
  6. FLORIN ROMANIA
    România
    786Coins
    No, I did not install any antivirus for fear of affecting my simtools in any way
  7. yobuddy
    50,804Coins
    Doing a google search for "invalid class error", leads me to the idea that this issue is caused by either Windows Management Instrument (WMI) service not being started, or the WMI service is corrupted.
    As I have not seen this before, I would start with simply reinstalling SimTools v3 and see what happens.
  8. FLORIN ROMANIA
    România
    786Coins
    Greeting. I reinstalled simtools. appeared The message in the first photo, after which I entered the email and the code sent by SimTools, Then I got the message from the second photo IMG_20231218_205525.jpg
  9. yobuddy
    50,804Coins
  10. FLORIN ROMANIA
    România
    786Coins
    Greeting. Before I download simtools again, I still need to change the region? Or the issue has been solved?
  11. yobuddy
    50,804Coins
    I would still change it, just to make sure it's not in the picture.
  12. FLORIN ROMANIA
    România
    786Coins
    Greeting. We redid all the necessary installation steps
  13. FLORIN ROMANIA
    România
    786Coins
    I don't know what I'm doing wrong
  14. yobuddy
    50,804Coins
    You defiantly want this one checked.
    Is the date and time correct on your PC?
  15. FLORIN ROMANIA
    România
    786Coins
    The date and time are correct. What to check in net framework 3. 5?
  16. FLORIN ROMANIA
    România
    786Coins
    And how to check? Does he need an update to the framework?
  17. yobuddy
    50,804Coins
    Have you tried the .net repair tool I linked above?
    No, it looks ok from here anyway.
    Maybe to prove it's not windows defender misfiring, maybe install avg free antivirus (as it will disable windows defender.)
    Although, you will not want to run it as admin under normal usage, can you register SimTools v3 if you run it as admin?
  18. FLORIN ROMANIA
    România
    786Coins
    System.Management.ManagementException: Invalid class
    at System.Management.ManagementException.ThrowWithExtendedInfo(ManagementStatus errorCode)
    at System.Management.ManagementObjectCollection.ManagementObjectEnumerator.MoveNext()
    at SimTools.Cls_Reg._GetProcessorId()
    at SimTools.Cls_Reg._GetUnique()
    at SimTools.Cls_Reg._CheckLicense(String Key, String ID)
    at SimTools.Frm_SimTools.Registration_ClickedButton(Button_Type ButtonClicked)
    at MyRegBox.MyRegBox.Pic_Check_MouseClick(Object sender, MouseEventArgs e)
    at System.Windows.Forms.Control.OnMouseClick(MouseEventArgs e)
    at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
    at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
    mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.8.9181.0 built by: NET481REL1LAST_C
    SimTools
    Assembly Version: 3.0.0.0
    Win32 Version: 3.0.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/SimTools.exe
    HgmPSUpleedJAWeuZxbYBMkkKRJL
    Assembly Version: 0.0.0.0
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System
    Win32 Version: 4.8.9206.0 built by: NET481REL1LAST_B
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Drawing
    Win32 Version: 4.8.9037.0 built by: NET481REL1
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    Game_PluginAPI_v3
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/Game_PluginAPI_v3.DLL
    Axis_PluginAPI_v3
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/Axis_PluginAPI_v3.DLL
    Interface_PluginAPI_v3
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/Interface_PluginAPI_v3.DLL
    Microsoft.VisualBasic
    Assembly Version: 10.0.0.0
    Win32 Version: 14.8.9037.0 built by: NET481REL1
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    MyCrashButtons
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyCrashButtons.DLL
    MyVibeButtons
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyVibeButtons.DLL
    MyTuningButtons
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyTuningButtons.DLL
    System.Configuration
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Core
    Win32 Version: 4.8.9200.0 built by: NET481REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    System.Xml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    Accessibility
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
    Tool_AddonAPI_v3
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/Tool_AddonAPI_v3.DLL
    Default_AxisPlugin
    CodeBase: file:///C:/Users/Desktop/AppData/Local/SimTools3/AxisPlugins/Default_AxisPlugin.dll
    Default_InterfacePlugin
    CodeBase: file:///C:/Users/Desktop/AppData/Local/SimTools3/InterfacePlugins/Default_InterfacePlugin.dll
    VirtualOutputAPI_v3
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/VirtualOutputAPI_v3.DLL
    Default_VirtualPlugin
    CodeBase: file:///C:/Users/Desktop/AppData/Local/SimTools3/VirtualPlugins/Default_VirtualPlugin.dll
    GameDash_PluginAPI_v3
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/GameDash_PluginAPI_v3.DLL
    Default_GameDashPlugin
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Users/Desktop/AppData/Local/SimTools3/Dash/Plugins/Default_GameDashPlugin.dll
    CSCore
    Assembly Version: 1.2.1.2
    Win32 Version:
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/CSCore.DLL
    MyDropBox
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyDropBox.DLL
    MyTextBox_MinMax
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyTextBox_MinMax.DLL
    MyDashControl
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyDashControl.DLL
    MyButton
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyButton.DLL
    MyTextBox
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyTextBox.DLL
    MyPicMenu
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyPicMenu.DLL
    MyOneClick
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyOneClick.DLL
    MyScrollBar
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyScrollBar.DLL
    MyCheckBox
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyCheckBox.DLL
    MyTuningScrollBar
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyTuningScrollBar.DLL
    MyOnOffSlider
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyOnOffSlider.DLL
    MyRepoButton
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyRepoButton.DLL
    MyParkingLocation
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyParkingLocation.DLL
    MyProfileComboBox
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyProfileComboBox.DLL
    MyLoadButton
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyLoadButton.DLL
    MyBannerStopButton
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyBannerStopButton.DLL
    MyNotifyMarker
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyNotifyMarker.DLL
    MyRadioButton
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyRadioButton.DLL
    MyExport
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyExport.DLL
    MyNewName
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyNewName.DLL
    MyUpDown
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyUpDown.DLL
    MyMessageBox
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyMessageBox.DLL
    MyRepoInstall
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyRepoInstall.DLL
    MyMainMenu
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyMainMenu.DLL
    MyPatchingNotes
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyPatchingNotes.DLL
    MyAxisLimiting
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyAxisLimiting.DLL
    MyFolderBrowser
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyFolderBrowser.DLL
    MyTopMenu
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyTopMenu.DLL
    MyRegBox
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyRegBox.DLL
    MySaveButton
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MySaveButton.DLL
    MyDatePicker
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyDatePicker.DLL
    MyTextPrompt
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyTextPrompt.DLL
    System.Management
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
    System.IO.Compression.FileSystem
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.IO.Compression.FileSystem/v4.0_4.0.0.0__b77a5c561934e089/System.IO.Compression.FileSystem.dll
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.IO.Compression/v4.0_4.0.0.0__b77a5c561934e089/System.IO.Compression.dll
    Network_GameDashPlugin
    CodeBase: file:///C:/Users/Desktop/AppData/Local/SimTools3/Dash/Plugins/Network_GameDashPlugin.dll
    Serial_GameDashPlugin
    CodeBase: file:///C:/Users/Desktop/AppData/Local/SimTools3/Dash/Plugins/Serial_GameDashPlugin.dll
    Virtual_GameDashPlugin
    CodeBase: file:///C:/Users/Desktop/AppData/Local/SimTools3/Dash/Plugins/Virtual_GameDashPlugin.dll
    enabled.
    For example:
    <configuration>
    </configuration>
  19. FLORIN ROMANIA
    România
    786Coins
    this is the full mesage
  20. FLORIN ROMANIA
    România
    786Coins
    Yes, I have run Net repair tool. When I downloaded simtools Windows defender was disabled. After running net repair tool do I need to download simtools again or should it have worked properly?
