2dof 24v 250w wheelchair motors
Discussion in 'DIY Motion Simulator Projects' started by xFFBx Tearier, Dec 8, 2023.
  1. xFFBx Tearier
    xFFBx Tearier ffb Tearier Gold Contributor
    184Coins
    Excited to be posting this. Should be testing out the sim this weekend, and wanted to get a build thread started. So far this is what I’ve had to buy:
    • x1 arduino Uno R3 (rexqualis off brand)
    • x2 IBT-2 BTS7960 43amp
    • x2 24v 250w 13.4a 75rpm wheelchair motors
    • x1 24v 1000w 42amp power supply (have voltage set to 18.5v, to protect the ibt2’s)
    • x2 “motoforti” tie rods
    • x3 8ft 2x4’s from the local hardware store.
    • x1 Mazda Miata driveshaft(cut and welded flare plate to one end)
    I was lucky enough to be able to purchase everything on Amazon, short of the wood and driveshaft.
    The motors are hooked up and have been tested with SMC3, just have to join the motion platform to the base, and I’ll be on my way to getting on it for the first time.
    Here are a few pics from earlier this week. Any tips or questions are 100% welcomed!
    Crossing my fingers I’m able to get the simtools without forking out another $50. Is the 30 day account minimum 100%? (I finished the sim way faster than expected lol)
  2. xFFBx Tearier
    184Coins
    Got it all mounted up. Putting together the lever arms and control arms now!
  3. xFFBx Tearier
    184Coins
    just got everything done. hooked it up to SMC3 and got movement! but now my problem is the motors are spinning freely, even when i shut down SMC3. is this a pot sensor issue?
    152,700Coins
    +11,092 / 56 / -2
    The pot provides positional feedback. I presume it is connected to the motor and correctly wired but want to confirm that is indeed correct?
  5. xFFBx Tearier
    184Coins
    they are connected to the arduino, but not mounted to the motors no. thats what made me think was causing the uncontrolled movment. but the rig continues to move even in "monitor" mode, and when i close out of SMC3Utils. i have to disconnect power to stop it.
    working on the pots now. The first 80% of movent barely moves the green line, and the last 20% shoots the line straight to the top. assuming thats just bad wiring on my end?
    152,700Coins
    +11,092 / 56 / -2
    Please connect the pot shaft to the motor shaft and also post pictures of all of your SMC3 settings.
  7. xFFBx Tearier
    184Coins
    Ended up ordering some new pot sensors. I was trying to use some really cheap ones that came in my arduino kit. Couldn’t get them to work properly. Have to wait a couple of days for shipping now, in the meantime what’s everyone using for lever arms? Right now I’ve got 1.5in steel tube I cut a hole, and slot in. It works, but I’d like something a little more durable and better looking lol. Thank for any help.
  8. xFFBx Tearier
    184Coins
    Got it moving around. Got in it, and it’s a little unbalanced. Make sure y’all don’t make the center of gravity too high!
  9. xFFBx Tearier
    184Coins
    just go the new POT sensors in. got one hooked up, and it works! but can i adjust the sensitivity of them? they are super slow. a 90 degree turn only barely makes the green line in SMC3 move. (at least is even movement now)
  10. Employee4Life
    Employee4Life New Member
    80Coins
    Nice to hear! I have no idea about technically calibrating the pot.meters to be more sensitive. I can only imagine some sort of gearing, like bicycle sprocket sizes. This ofcourse depend on how you mounted it.
    I have a 1:1 ratio. Hope it works out. The shaft from the motor will only operate in half a revolution on my build so I hope the pots are sensitive enough for this.
    Postet a photo of my current assambely for some clearification :)
  11. xFFBx Tearier
    184Coins
    had some time today to mess with the rig. got it moving around with smc3, and was just tweaking with it to get it smooth. after some trial and error, i got it smooth enough to where i wanted to hop in it and see how it felt. well for some reason when i put my weight on the motors they act like they can not support my weight. they drop all the way to max limit bottom and shuts the motor off. after a couple of tries i managed to snap a tie rod because the extra movement broke the pot mount, resulting in endless spinning of the motor.. face palm.. anyone else have any issue like this? ill post a picture of my SMC3 settings right below this.
  12. xFFBx Tearier
    184Coins
  13. noorbeast
    152,700Coins
    +11,092 / 56 / -2
    How long is the CTC distance on the leaver?
  14. xFFBx Tearier
    184Coins
    I have come back to the rig after a couple years lol.
    after double checking the wiring, I powered on the system in smc3.
    got the pots centered, and connected to the motors.
    Now the problem im having, only 1 motor has power and motion.
    even though both pots move correctly when i manually move the motion platform.
    i have replaced the Ibt-2 twice, aswell as checking wiring again.
    any help would be great!
    152,700Coins
    +11,092 / 56 / -2
    Can you please post pictures of all SMC3 settings running the Sine test for both motors.
    Do double check any soldered wiring.
    Many members have reported quality issues with IBT2s, so while written with another problematic board in mind it would be wise to check the IBT2:
    https://www.xsimulator.net/community/faq/monster-moto-testing-before-use.158/
  16. xFFBx Tearier
    184Coins
    i have a new build, with a much better understanding
    well i just checked the boards again. aaaand i finally got 2 to work.
    with settings for both motor 1 and motor 2 set as the same. i was able to get movement out of both motors.
  17. xFFBx Tearier
    184Coins
    now for the kicker. Motor number 2's upwards movement is super slow... im assuming thats a bad IBT2..
    and motor number 2 is super twitchy, even sitting at rest.
  18. noorbeast
    152,700Coins
    +11,092 / 56 / -2
    That could be the case, many others have reported IBT2 clone quality issues, even with brand new boards.
    You may want to consider budget alternatives:
    https://www.xsimulator.net/community/faq/reasonably-priced-100a-motor-controllers.412/
    https://www.xsimulator.net/community/faq/cytron-md13s-for-smc3.358/
  19. xFFBx Tearier
    184Coins
    heres SMC3 with each motor runnig sine. super easy to see motor number two slacking on the upward motion.
  20. xFFBx Tearier
    184Coins
    any ideas on what could be cause motor number 1 to be so twitchy?
