Show me your Universal Joints
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Psionic001, Feb 9, 2019.
Do you make your own Joints or buy after market
  1. Designed and Built my own joints
    32.0%
  2. Purchased after market
    60.0%
  3. Found another way to use joints
    4.0%
  4. I don't use joints
    4.0%
  1. Dirty
    All the way up front.
    7,964Coins
    Thanks, appreciate the compliment :)
    They are designed for a nominal load of 1000N (~220 lbs) and I have tested them up to 4000N (PETG@285°C) This is the extension load, btw. In compression they should easily hold much more than that.
    Also, I have designed them around metric ball bearings. I think it was these:
    ...which are dirt cheap and are available from a hundred vendors here in Europe. If you guys over in the US use inch or other units for typpical off-the-shelf bearings you may have to adapt the design slightly. And if you are OK with smaller diameter bearings, you can significantly increase the range of movement by reducing the size of the "arches". Even a millimeter (~40/1000 ") will make a noticeable difference.
    It you choose to go with those, build a single prototype first and see if it suits your needs. And let me know if you run into issues 'cause I am not using those myself. I went with the single-sided ones.
    Dirty :)
  2. Gianny
    Gianny New Member
    8Coins
  3. pmvcda
    15,666Coins
    Anyone wants to try flexure joints?
    Flexure joints are impressive, no gaps and solid. When looking for high precision and repetition, it's the best solution
    Here's some info:
    https://ris.utwente.nl/ws/portalfiles/portal/17709852/4927.pdf
    They are not in the maket we need to go the DIY course, but might be easier to build compared to a conventional ujoint.
    And an application of that:
  4. Yeti86
    Yeti86 New Member
    132Coins
    i got myself a drive train axle here from a VW t4 that i was planning for the build.
    it would have had two u-joints and could have been cut and welded just fine.
    but settled on regular bearing blocks as shown, the advantage of that is that i used one bigger shaft on one side, so i could drill and tap a setscrew. that allowed me to balance the center of gravity by sliding the other side along.
  5. cfischer
    Colorado
    2,789Coins
    Wow that is super interesting. Thanks for posting!
    Im super intrigued by both the uv joint and the motor flexure in that video. Really cool stuff.
  6. pmvcda
    15,666Coins
  7. issalig
    issalig New Member
    Europe
    57Coins
  8. issalig
    issalig New Member
    Europe
    57Coins
    For some reason, the image is not shown in the post before.
    I have uploaded it again as an attachment.
  9. Dude
    Dude Simonaut
    81Coins
    Hey Guys
    I'm in the beginning phase of my own project, a spaceship simulator. This topic helped me a lot to come to my solution, so thanks a lot already!
    To keep things cost effective but not cheap, i came up with the following construction. It's a combination of an aluminium cross block for 3d printing or automation, two 20mm steel pipes and 4 heavy duty ball bearings.
    All in all costs: $45. Can provide links if it's allowed/wanted.
  10. hexpod
    hexpod http://heXpod.xyz
    berlin
    7,783Coins
    DC motor, 6DOF
    If you are aiming a 6-dof you need to allow a slight rotation on vertical axis on the actuator.
  11. Dude
    Dude Simonaut
    81Coins
    Just aiming for 2-dof. The simulator will be a closed cabin. I'll open a thread as soon as there is more to show than the gathered material.
