The Start To My 3 Dof DIY Build
Discussion in 'DIY Motion Simulator Projects' started by brandon hager, Oct 24, 2023.
  1. brandon hager
    brandon hager New Member
    Springfield MO
    71Coins
    Hi everyone im brandon. this is my diy 3 dof that im building out of 1in square tubing and using jazzy wheelchair motors 20230519_012020.jpg
    20230519_233757.jpg at this point i had to take a break and get more square tube
    then built out more to the cockpit. and in the middle of building it out my order got delivered.:thumbs
    but the only bad part is i forgot to get more pics of building out the steering hoop.
    couldnt help but set it up and test out the new toys Snapchat-716233236.jpg 20231010_095003.jpg
    then my motors and power supply's showed up. and pulled it back down to work more on the two lower parts
  2. brandon hager
    Springfield MO
    71Coins
    got the front motors puut on and had to lift the cockpit 2in. for the front to clear
    got more two come working on the control box also.
  3. Halloween2go
    Halloween2go Active Member Gold Contributor
    1,407Coins
    Nice work B! Kind of looks like my garage setup too!.. keep pluggin away my friend! DMAX
  4. brandon hager
    Springfield MO
    71Coins
    thanks DMAX
  5. Boneheaded
    Boneheaded New Member
    16Coins
    Nice build friend, what's the size of the U-Joint you had used? I plan on building mine in the upcoming year, just getting all the supplies first, and learning how to weld haha! Hope to see more of it soon.
