Forza Motorsport (8)
Discussion in 'Other Racing Games' started by Pascal75, Oct 5, 2023.
  1. Pascal75
    Pascal75 New Member
    germany
    16Coins
    2DOF, Motion platform
    Hi at all,
    just for information. The old Forza Motorsport 7 Game Plugin works great with the new Forza Motorsport!
    Only the wind support is missing.
    BR
    Pascal.
  2. izhangt
    izhangt Member Gold Contributor
    - 91Coins
    How u patch it?
  3. m0dus
    m0dus New Member Gold Contributor
    USA
    - 76Coins
    3DOF, SCN6
    seconding this. Original Forza 7 settings / IP loopback don't seem to carry over by default, how did you patch the game?
  4. Pascal75
    Pascal75 New Member
    germany
    16Coins
    no patch needed, Telemetry settings in FM: Data on, IP 127.0.0.1, UDP 4123, Format Dashboard
  5. Yinger
    Yinger New Member
    54Coins
    I tried this last night with no luck. When I launched the game the chair shimmied like it was receiving data but then did not respond in race. Any addition information or settings?
  6. izhangt
    - 91Coins
    OK, but u just patch plugin of motorsport 7, but game engine don't work, so what exactly U do to make it work?
    Thx
    153,914Coins
    +11,156 / 57 / -2
    You can check if data is being transmitted in the top row of the Tuning Center.
    If it is the issue will be refining the associated motion profile.
  8. izhangt
    - 91Coins
    Can u explain what we have to do with plugin of forza 7 to active game engine, I can use it with forza 7 game with motion , but I don't have game engine activated with new forza. It's not an ip thing... It's a patch thing. And no, in the top row there is no data
    153,914Coins
    +11,156 / 57 / -2
    It was @Pascal75 giving setup advice:
    I was suggesting the Tuning Center as a quick and easy way to verify if it worked or not.
  10. Pascal75
    Pascal75 New Member
    germany
    16Coins
    Clear the ip and udp in the Plugin. Only in FM 127.0.0.1 and 4123. Then it works fine
    I use Simtools V3beta
  11. izhangt
    - 91Coins
    how u clear the ip and udp in the plugin in v3? don´t see the option
  12. izhangt
    - 91Coins
    I see now, let's try
  13. izhangt
    - 91Coins
    Don't work for me, also don't work forza horizon 5 with v3, and I can play with v2. It's problem of njmotion that has to put game plugins for the machine exclusive?
  14. Pascal75
    Pascal75 New Member
    germany
    16Coins
    click on the network-symbol and press reset
  15. Pascal75
    Pascal75 New Member
    germany
    16Coins
    Horizon 5 works fine under V3beta, including wind sim and Motorsport works also great.
  16. izhangt
    - 91Coins
    Forza horizon 5 works and also fm7 but no luck with forza motorsport m, it's not detected by simtools v3, u reset and then close? Or reset and put IP and port, and then close
  17. izhangt
    - 91Coins
    when u say "FORMAT DASHBOARD" its an option in simtools? or it is in forza motorsport ? couse in forza i only see the ip, the port, and two options: SLED or ACELERATION.
    I got the microsoft version of the game,
  18. p00ky
    p00ky Active Member
    Self Employed Laser Cutter
    Wales
    392Coins
    Here's the settings & Im using Gamepass so the game is through Microsoft. Works well...... well better than the game :D
    They need to sort out their optimization, lets just say.
  19. izhangt
    - 91Coins
    i got the spanish language, so i think the problem is i have to put dashboard and ingame is called car aceleration maybe
  20. p00ky
    p00ky Active Member
    Wales
    392Coins
    Yeah, I think there are only 2 options so just try it and give it a go. Worked for me with no messing about.
