3dof from scrap metal
Discussion in 'DIY Motion Simulator Projects' started by Hell167, Sep 17, 2023.
  1. Hell167
    Hell167 New Member
    117Coins
    DC motor, Arduino
    So I got most of the metal for free and thought to myself I could diy a sim rig out of recycling metal shelf. Just a simple one with traction loss. Trying to do this with spending as little money as possible.
    Couldn't find a scrap drive shaft so i had to buy a power steering universal joint. Only 1" but seems to hold up ok at least for now.
    3d printed a few parts. just some gt2 belt gears at a 1:1 ratio to connect the pot to the motor.
    The seat I got for free from expired Rollercoaster seats. Seat rails/sliders are from an old gmc van.
    Got most of the electronics off aliexpress. Which is looking like it will turn out to be a bad idea. The motors don't have enough holding power and is being back driven sloping down the front of the rig. I seem to be having issues with either the clone arduino uno r3 or the h bridge ibt2s as I can only get the motors to turn in one direction. Looks like the money I "saved" is wasted.
    Pretty much got the frame built. Mostly welded. May still have to make some adjustments. Like the pedal area incline is too high. Might need to extend the shifter bracket a bit closer to the rear.
    Right now, trying to figure out the electronics and software part of the project and having some issues.
    Steering wheel and shifter are thrustmasters
    I'm hoping oculus quest 2 will pair well with this.
    This will basically only be for assetto corsa on pc.
    All and all a pretty fun project. Considering the lack of correct tools and so much free handing, it still looks ok. Lol
    153,890Coins
    +11,154 / 57 / -2
    I am looking forward to following along and see how it all comes together.
  3. Hell167
    Hell167 New Member
    117Coins
    DC motor, Arduino
    Replaced the arduino with a legit one. Fixed my issue of the motor only moving in one direction. However it also looks like I will need to replace 2 h bridges.
    I can connect through smc3 tools but haven't been unable to connect through simtools for some reason
    153,890Coins
    +11,154 / 57 / -2
  5. Hell167
    Hell167 New Member
    117Coins
    DC motor, Arduino
    New h bridges came. Installed and everything works fine in smc3 utilities. However I still can't get any connection to sim tools game engine.
    Hopefully @noorbeast can help.
    153,890Coins
    +11,154 / 57 / -2
    Interface Type - Serial
    ComPort = check the Arduino ComPort, you can find it in Windows Device Manager.
    Note this -> BitsPerSec - 500000
    Data Bits - 8
    Parity - None
    Stop Bit -1
    Output Bit Range - 10
    Output Type - Binary
    Interface Output - [A<Axis1a>][B<Axis2a>]
  7. Hell167
    Hell167 New Member
    117Coins
    DC motor, Arduino
    That worked thanks. Didn't have enough time to fully test it out this morning but at least that's connected.
  8. Hell167
    Hell167 New Member
    117Coins
    DC motor, Arduino
    I am getting some vibration in the pot readings (not completely steady green line in smc utility) causing the motor to wiggle back and forth just a tiny bit. Is there a setting I can tone down? Is this because I'm using a belt instead of gears for the pot? Could there be interference in the wiring? Or is this normal?
    153,890Coins
    +11,154 / 57 / -2
    You can try setting a dead zone in SMC3.
  10. Hell167
    Hell167 New Member
    117Coins
    DC motor, Arduino
    Deadzone fix that right up. Burnt a h bridge board. What's going on? Also motors are extremely hot.
    153,890Coins
    +11,154 / 57 / -2
    It could be a design or hardware issue, or a combination of both.
    How well balanced is the rig, with you in it: https://xsimulator.net/community/faq/find-the-center-of-gravity-to-balance-a-motion-simulator.55/
    What motors are use, where are they placed and what lever CTC distance is being used across what degree of rotation (effective torque utilization drops off rapidly over 38-40 degrees up and down)?
  12. Hell167
    Hell167 New Member
    117Coins
    DC motor, Arduino
    This is the motor I'm using. It might not be powerful enough I guess? It seems to be struggling. 12v 50:1 120rpm
    The rocker arms are 95mm long. At rest it should sit parallel to the floor. Max turn up or down shouldn't be higher than 45 degrees
    The motors are mounted to the front. Balance has been redone and is good now.
  13. noorbeast
    153,890Coins
    +11,154 / 57 / -2
    That is about 7nm, which is pretty week.
    Do you mean the holes on the levers are 95mm apart (CTC), if so try around 50-60mm.
  14. Hell167
    Hell167 New Member
    117Coins
    DC motor, Arduino
    153,890Coins
    +11,154 / 57 / -2
    Something like wheelchair motors would likely be a better choice.
  16. Hell167
    Hell167 New Member
    117Coins
    DC motor, Arduino
    153,890Coins
    +11,154 / 57 / -2
    Yes something like that, but do have a play with the design aspects as well, as that is equally important.
  18. Airbas72
    Airbas72 Member
    - 7Coins
    3DOF, Arduino
    hi I installed a shielded wire on the potentiometers, and I also had twitching due to the play of the potentiometer
    153,890Coins
    +11,154 / 57 / -2
    Just wondering if you have made further project progress?
  20. Hell167
    Hell167 New Member
    117Coins
    DC motor, Arduino
    Not really, it's been cold and wet so haven't spent much time in the garage. It will continue though and I will continue to post as I progress
