Slider Bug
Discussion in 'X-Sim² profiles' started by Nima, May 24, 2010.
  1. Nima
    Nima Member Gold Contributor
    Glaser
    Bad Zwischenahn
    532Coins
    hi,
    yesterday i have make a f1 profil with spleeendid.with slider and after this work hi have send it to my and i have open on my profiler the slider on one side in the math setup are delite.than i load it again and than is work correct.this is all times after load a other profil with slider.
    you can test it.you mast load 2 times you mast have on both axis in the math setup the same yellow sliders.
  2. splendiddd
    splendiddd Active Member
    CCTV security
    Netherlands
    812Coins
    Thank you again for your time and knowlege Niels! and helping me create a proper profile. When i have time to test it properly, i will post my version.
    Regards,
    Rob
  3. Nima
    Glaser
    Bad Zwischenahn
    532Coins
    hi rob,
    nice work with you.do you can load the profil?
  4. ledfoot
    ledfoot Member
    IT Manager
    Toronto, Canada
    22Coins
    I have also seen this happen.
  5. splendiddd
    CCTV security
    Netherlands
    812Coins
    Sorry do not have time till friday to test it again, i will let you know ;)
