SimTools v3 Public Beta
  1. 930175620
    930175620 New Member
    65Coins
    After I installed this sequence setting, the actions of Pitch, ROLL, Sway, and Surge are all wrong, or they are coupled with each other. I can't tell what he's doing. I use a THANOS controller.
  2. lVlemphiz
    lVlemphiz Member Gold Contributor
    Automotive Engineer
    252Coins
    3DOF, AC motor, SCN6
    Hey just wanted to update. The small window UI occurs after selecting the AMC plugin in the Interface menu. I've repeated it on different pcs. It's the AMC plugin and when you select it in the interface.
    I'd love to use Simtools 3.0 but I can't read it that small unless I get out my rig. So I've defaulted to SimRacingStudio until someone can clean that up. It's been killing my eyes trying to use it.
    I know it's not priority (I thought more people would be using the Thanos AMC but guess not?)...but if someday someone wants to fix that I'm providing info on how and when it occurs
  3. Djalma Ribeiro
    Djalma Ribeiro Member
    Drone Pilot
    Cuiabá, Brazil
    168Coins
    @yobuddy is this something that can be fixed?
  4. yobuddy
    50,827Coins
    The problem occurs when the game is sending UDP packets, where only one app can collect the data at a time, or you have a port conflict.
    So you need to let the game send the data to the first app, and then relay the data to the other.
  5. yobuddy
    50,827Coins
    Are you using the app on a TV? Anyway, I can fix this shortly.
  6. yobuddy
    50,827Coins
    @930175620,
    Looks like the axis output order may be wrong in the plugin.
    Please follow the Gray axis order. (Red is thano's order)
    (And I will fix the axis order pictures in the 3D axis plugins.)
    Thanks for beta testing!
  7. yobuddy
    50,827Coins
    Axis output order pictures fixed for both the 3d Rotating and Linear Axis plugins. :thumbs
  8. yobuddy
    50,827Coins
    Do you have your options set to update interface plugins?
    Taking a look back, I believe this has previously been fixed.
    Maybe uninstall the plugin, re-start simtools v3, and reinstall the plugin.
  9. Djalma Ribeiro
    Drone Pilot
    Cuiabá, Brazil
    168Coins
    Profile Intensity still has no effect.
  10. Mu-KwangKim
    South, Korea
    - 689Coins
    The image of Rotating has changed, but Linear hasn't changed. ;)
  11. yobuddy
    50,827Coins
    It does actually work, but still needs to be turned up, adjusted.
    Open the virtual output slider plugin and take a look at heave while racing.
    Adjust the intensity slider and you will see it work.
    No worries thou, I will adjust it shortly. ;)
  12. yobuddy
    50,827Coins
    This is what you should see??
  13. Mu-KwangKim
    South, Korea
    - 689Coins
    I deleted the plug-in and reinstalled it, but the image doesn't change.
  14. yobuddy
    50,827Coins
    Try deleting the plug-in, restart simtools, then reinstalled it.
    Let me know buddy!
  15. lVlemphiz
    Automotive Engineer
    252Coins
    Yeah I have a 4k 55 inch display.
  16. yobuddy
    50,827Coins
    SimTools update posted with new vibe testing to avoid confusion :thumbs
  17. Mu-KwangKim
    South, Korea
    - 689Coins
    Oh. Changed.
    Plugin Remove,
    SimTools Restart,
    Plugin Reinstall.
    It has to be in the right order.
    Good job.
    p.s. But, All the settings are gone. HaHaHA~ OTL...
  18. yobuddy
    50,827Coins
    Depending on the settings in your options for interface plugins, plugins should auto update.
    I will check that the auto update is still working for interface plugins when I get some time
    Seems both of you guys didn't get a auto update.
    Take care!
  19. Nicki9knuckles
    Nicki9knuckles Active Member
    Web Developer
    740Coins
    3DOF, DC motor, Motion platform
    Is anyone playing Elite Dangerous on SimTools v3? I am not able to get any motion, and no values are showing in the min/max tuning. I tried uninstalling the plug-in and reinstalling. I also did that as an administrator but no change. Is there some in-game setting that needs to be changed maybe?
  20. 930175620
    65Coins
    I think there are still problems in the order of the axis. I have installed a new order settings. But the action is completely confused. For detailed reference, you can refer to the video.
