My new 3 dof
Discussion in 'DIY Motion Simulator Projects' started by el_marius90, Mar 23, 2023.
  1. el_marius90
    el_marius90 Simracer simulador 2dof
    Electricista
    Madrigueras
    - 928Coins
    hello group, a year ago I created a 2 dof, which I have enjoyed a lot, now I am creating a 3 dof which I really want and enthusiasm, I want to share my experience with all of you.
  2. el_marius90
    Electricista
    Madrigueras
    - 928Coins
    First I want to share the images of my work 2 dof
  3. el_marius90
    Electricista
    Madrigueras
    - 928Coins
    now start with the 3 dof, I'm with the structure, that's how I carry it...
  4. el_marius90
    Electricista
    Madrigueras
    - 928Coins
    We continue with the structure and anchorage of motors
  5. el_marius90
    Electricista
    Madrigueras
    - 928Coins
    third engine anchored
  6. el_marius90
    Electricista
    Madrigueras
    - 928Coins
    a little more paint and ready to start with the electronics
  7. el_marius90
    Electricista
    Madrigueras
    - 928Coins
    Hello, I have a problem with the third motor, I'm in smc3, the first two motors move perfectly but the third motor only moves a little to one side and there it stops and no longer responds, could it be the source? or rather a matter of parameters, I'll give you an image of my configuration in smc3, the motors are wheelchair 24v 75rpm 250w
    152,676Coins
    +11,089 / 56 / -2
    If you swap the pots controlling positional feedback between motors, does the issue follow or not?
  9. el_marius90
    Electricista
    Madrigueras
    - 928Coins
    Thanks for your answer, I haven't tried that, this afternoon when I get home from work I'll try and tell you, thanks.
  10. el_marius90
    Electricista
    Madrigueras
    - 928Coins
    Hello, I checked what you told me and it's still the same, the motor does turn but only to one side and then I can't make it come back
    152,676Coins
    +11,089 / 56 / -2
    Can you please post a SMC3 picture after the change.
  12. el_marius90
    Electricista
    Madrigueras
    - 928Coins
    I have already solved it, the problem was in the wiring, I had mistakenly put a cable where it should not have, thanks
  13. el_marius90
    Electricista
    Madrigueras
    - 928Coins
    hello, after solving the problem I had, I mounted the seat on the structure and began to do the first movement tests, then I find that it is very unstable, it has a lot of play and I think it is because the motors are too far forward. Do you recommend putting the motors as close to the cardan as possible?
    152,676Coins
    +11,089 / 56 / -2
    What are you using for the universal joint?
    If there is play best to work out where it is from.
    Moving motors closer to the pivot point also means they have to be able to produce enough torque, as the closer you get the more torque required.
  15. el_marius90
    Electricista
    Madrigueras
    - 928Coins
    that's what i'm using, i think the motors are strong enough to be in a wheelchair, what do you think? a lot of separation and exerting little force near the cardan.
  16. noorbeast
    152,676Coins
    +11,089 / 56 / -2
  17. el_marius90
    Electricista
    Madrigueras
    - 928Coins
    Lo tengo casi terminado, ayer hice algunas pruebas, hay que ajustar algo, pero estoy muy contento con él.
  18. el_marius90
    Electricista
    Madrigueras
    - 928Coins
    I would like to know how I can limit the axes in simtools, you can see it in some section of the manual. or I can see it in some section of simtools, within the application
    152,676Coins
    +11,089 / 56 / -2
    There is SimTools Axis Limiting in the interface, but in my view in most cases axis range should be defined by the control hardware/software.
  20. el_marius90
    Electricista
    Madrigueras
    - 928Coins
    do you mean smc3?
