2dof-wiper-motor-car-simulator-by-DERIY-(SATO)
Discussion in 'DIY Motion Simulator Projects' started by DERIY, Apr 26, 2010.
  1. pim
    pim New Member
    system engineer
    nederland, brabant
    380Coins
    2DOF, SCN5, SimforceGT
    Hey Deriy,
    what are the length and withe measurements of your sim?
    thanks,
    pim
  2. bvillersjr
    bvillersjr Active Member
    Ohio, USA
    438Coins
  3. DERIY
    DERIY Member
    RUSSIA
    - 52Coins
    Length of my simulator 1400mm
    Width: 750 mm.
    Honestly, never seen this design. :)
    But if an idea occurred to several people. So this idea is correct. :thbup:
    Here is a video I came across while I Thinking my simulator project. http://www.youtube.com/watch?v=BT_Xnu-gAJU
  4. egoexpress
    egoexpress Active Member
    Germany - Frankfurt/M
    421Coins
    I've added some brightness to your vid, as it has been so dark that I couldnt see anything.
    http://www.youtube.com/watch?v=phfZ9HbnFcs
    I like your design very much :thbup:
    However, I think you need some additional hours to tweak the motion profiles still.
    Regards
  5. DERIY
    DERIY Member
    RUSSIA
    - 52Coins
    The best I managed to configure profile in GTR evo.
    Effect of presence is phenomenal !!!
    In Live for Speed cannot achieve this result. (
    I think this is a matter of time.
    Thanks for the correction, video!
  6. egoexpress
    421Coins
    I dont get good results of LFS either. Thats why I dont like LFS. However, just my personal opinion.
    Btw, you can easily add some brightness and contrast to a vid with PocketDivXencoder (freeware) for example.
    The best approach to a good profile is to tweak each effect one by one, starting with longitudinal g-forces, then lateral g-forces, and finally adding some vertical g-forces (bumps, road surface). The actuators/leavers shouldnt reach end position. If they do, increase the maximum value in the Profiler math table for the corresponding effect a little.
  7. egoexpress
    421Coins
    Could you capture another GTRevo video without music please? It is easier to rate the game/chair syncro with game sounds only.
    Btw, you could increase game immersion a lot if you'd mount the screen onto the seat/platform.
  8. DERIY
    DERIY Member
    RUSSIA
    - 52Coins
    OK !
    A little later I will make another video with GTR.
    Instead mount the monitor on the platform, I want to buy now are 3d video glasses.
    And use freetrakir during the game.
  9. DERIY
    DERIY Member
    RUSSIA
    - 52Coins
    This is another video with the GTR Evo.
    http://www.youtube.com/watch?v=rQma0UMt5fw
    http://www.youtube.com/watch?v=zPqxCFR3TiI
  10. John05
    John05 New Member
    - 19Coins
    Hello Deriy, Do you have instructions available for assembling the simulator with the motors and other hardware?
    John
  11. DERIY
    DERIY Member
    RUSSIA
    - 52Coins
    Hi John!
    Sorry no.
    Instruction has not yet written, and I doubt that in the near future I will write.
    This process is very tedious and time consuming.
    But a small drawing can be draw. Since the desired dimensions.
  12. DERIY
    DERIY Member
    RUSSIA
    - 52Coins
  13. DERIY
    DERIY Member
    RUSSIA
    - 52Coins
    Hi all!
    Yesterday found a way to use a chair in the game Gran Turismo 5 Prologue.
    Today soldered electronics, configure profile, and a little ride.
    I really like the result.
    Watch Video!
    http://www.youtube.com/watch?v=H4J-Gplye4A
  14. splendiddd
    splendiddd Active Member
    CCTV security
    Netherlands
    812Coins
    How did you get motiondata from the ps3? i am confused...
  15. tronicgr
    tronicgr
    FROM THE SCREEN!!!!!! WOW!!! :lol:
    That's the most creative piece of work I seen lately!!! :clap:
  16. Frakk
    Frakk Active Member
    328Coins
    It is a nice try and all the respect for trying such an unusual way to do it!
    Unfortunately this method is going to be way too unreliable and slow.
    There is delay from the system to be displayed on the screen. The screen itself will delay the light emitted and the photocells are particularly slow and low bandwidth. Then you have the joystick controller going into the PC and the processing time for that. Transmitting the data to the AMC and getting the motors to move to that position also takes time. All in all we are looking at delays adding up to a significant amount. Not to mention the amount of noise and error introduced in all the conversions, math and communications.
    I also noticed that your seat bottoms out in its motion range almost all the time. You have very limited motion because of this.
    Keep up the good work and thank you for sharing! :cheers:
  17. DERIY
    DERIY Member
    RUSSIA
    - 52Coins
    I fully agree with you ,colleague :)
    Are there other ways to plugging controller to ps3, to avoid delays?
    I am satisfied with this method, because I'm not a pretentious, and another way I think does not exist yet..
  18. wannabeaflyer
    wannabeaflyer Active Member
    UK - London area
    973Coins
    Hi Deriy would like to complement you on an excellent piece of work , big thanks for sharing your design with the x-sim commuity . can i ask few questions 1 ( did u make your own seat ) 2 ( did you have to modify your wiper motors to get the speed equal in both directions, again excellent workmanship and ni ce compact good looking design :)
  19. DERIY
    DERIY Member
    RUSSIA
    - 52Coins
    Hi wannabeaflyer !
    Sorry, I did not understand the first question.
    I did not modify motors
    The motors have two speeds.
    At slow speed, they rotate in both directions equally.
    At high speeds, the difference in speed is very noticeable.
    Therefore, I use a low speed.
    To increase the torque and force, I am applying to motors 14-16 volts.
    I am glad that you liked my design!
  20. egoexpress
    421Coins
    The speed difference can be equalised by rotating the motor housing a little.
    Thanos made a how-to video:
    Regards
